UTS718X2M3PNPT
UTS718X2M3PNPT
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    5 Position Circular Connector Receptacle for Male Contacts Panel Mount
UTS718X2M3PNPT 数据手册
1 2 DWG. NO. THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. USE MAXIMUM CURRENT (AMP) MAXIMUM VOLTAGE (VAC) MAXIMUM WIRE (mm) 2,4 POWER 44 600 6.3 1,3,5 SIGNAL 13 250 3.3 CIRCUIT S100044 PANEL SEAL WASHER 1.42 [36.1] .68 [17.2] MATING SIDE X 1.12 [28.5] .43 [10.9] X X .77 [19.5] THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. 1. MATES WITH UTS6__18X2M3S. 2. CIRCUITS 2 & 4 USE SEPARATELY. 3. CIRCUITS 1, 3, AND 5 USE 1.6mm TRIM TRIO PIN CONTACTS ORDERED SEPARATELY. 4. 4.1 4.2 MATERIALS: ALL RoHS COMPLIANT RECEPTACLE SHELL: POLYAMIDE UL94VO, COLOR-BLACK. WASHER: RUBBER 5. 5.1 5.2 5.3 5.4 5.5 5.6 MECHANICAL / ENVIRONMENTAL PERFORMANCE OPERATING TEMPERATURE: -40$TO +105°C. CORROSION: SALT SPRAY, 500 HOURS. DURABILITY: 250 MATE-UNMATE CYCLES. VIBRATION: SINUSOIDAL PER CEI 60512-4; 10-TO-2,000 Hz. THERMAL SHOCK: 5 CYCLES X 30-MINUTES: -40$TO +105°C. SEALING IN MATED CONDITION: IEC 60529-IP68: 10M WATER, 1-WEEK; DYNAMIC-IP69K: HIGH-PRESSURE WATER, DIN 40050. 6. 6.1 ELECTRICAL PERFORMANCE: DIELECTRIC WITHSTANDING VOLTAGE / INSULATION RESISTANCE 2200 VRMS MAX. BETWEEN CIRCUITS 2,4 / 5000 M Ohm MIN. @ 500 VDC. 1500 VRMS MAX. BETWEEN CIRCUITS 1,3,5 / 5000 M Ohm MIN. @ 500 VDC. 7 PACKAGED WITH SEALING WASHER SOURIAU LABEL INCLUDES PART NO.,QTY. & UL INFORMATION. 8. UL 1977 RECOGNIZED 9. POWER CONTACT RESISTANCE:
UTS718X2M3PNPT 价格&库存
很抱歉,暂时无法提供与“UTS718X2M3PNPT”相匹配的价格&库存,您可以联系我们找货
