1
2
DWG. NO.
NOTES:
S99697
1. MATES WITH UTS6_ _183G1S
THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC.
IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION.
CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION.
2. USES 1-TO-4 ea. SIZE-8, 3.6mm PIN CONTACTS.
(CONTACTS ORDERED SEPARATELY)
CONTACT TYPE: REFER TO SOURIAU BSD202333002
3. MATERIALS
3.1 HOUSING: POLYAMIDE UL94V0, COLOR-BLACK
3.2 ALL MATERIALS ARE RoHS COMPLIANT.
1.42
[36.1]
.68
[17.2]
4.
4.1
4.2
4.3
4.4
MECHANICAL PERFORMANCE
OPERATING TEMPERTURE: -40$TO 105 C
CORROSION: SALT SPRAY, 500 HOURS
DURABILITY: 250 MATE-UNMATE CYCLES
SEALING: WHEN MATED TO CABLE PLUG (NOTE-1):
IEC 60529-IP68: 10m WATER, 1-WEEK;
-IP69K: HIGH-PRESSURE WATER, DIN 40050
4.5 TYPICAL INSTALLATION: OUTLET BOX
RECOMMENDED TOOLS: 8-POINT 1 1/4 SOCKET; MAX. TORQUE 66 IN.-LB.
.57
[14.4]
1.12
[28.5]
X
X
X
X
X
6
X
.77
[19.5]
X
X
X
X
5. ELECTRICAL PERFORMANCE
5.1 DIELECTRIC WITHSTANDING VOLTAGE / INSULATION RESISTANCE
2200 VRMS MAX. BETWEEN CIRCUITS / 5000 MOhm MIN. @ 500 VDC
5.2 OPERATING VOLTAGE: 600 VAC MAX.
5.3 CIRCUIT USE:
B,C,D: 44 AMP MAX.
A: GROUND: FIRST MATE LAST BREAK
3/4 NPT
THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE
DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC.
4X 1.25
[31.8]
RUBBER WASHER IS BULK-PACKAGED:
LABEL INCLUDES SOURIAU P/N & QTY.
7.
UL 1977 RECOGNIZED.
8
MOLDING "VOID CORES" ARE INDICATED "X"
9
.43
[10.9]
PANEL CUTOUT IF APPLICABLE: TAP DRILL 59/64
OR .922 INCH (23.42mm) 3/4-NPT INTERNAL THREAD.
10. UNITED STATES PATENT 7,995,125
SCALE 1:1
SCALE 1:1
C
REVISED PER ECN 11721
B
REVISED PER ECN 11550
A
RELEASED PER ECN 11468
REV
DESCRIPTION
RSK
05-16-12
SSF
11-03-11
TJS
07-13-11
NPP
05-16-12
NPP
11-03-11
NPP
07-13-11
BY
DATE
CHKD
DATE
DRAWING TITLE
UTS RECEPTACLE, SIZE-18, NPT-3/4
CAT NO.
UTS7183G1PNPT
X
Option
LINEAR
Authorized SignatureMEASURE:
THIRD ANGLE PROJECTION
& Date
CAGE NO: 09922
APPROVAL
Client Drawing Approval
Approved with no Exceptions
Approved with Exceptions Noted
TOLERANCES
UNLESS OTHERWISE SPECIFIED
No. OF PLACES
INCH [mm]
Rejected
ONE
PLACE
#.1 [ #3]
The signature above indicates the client's authorized representative has
TWO PLACES
#0.02 [ #.5]
reviewed, understands, and concurrs with the requirements defined
herein If no signature is provided, placement of a purchase order by the
THREE PLACES
#0.010 [ #.25]
client is considered drawing acceptance.
ANGLES #1 $
Revision/Resubmission Required
SCALE 3:2
B
2
Company Name
CUSTOMER
INTERPRET THIS DRAWING IN ACCORDANCE
WITH ASME Y14.5M - 1994.
DRAWN:
CHKD :
DSGN :
MFG :
QC
DRAWING
DRAWING
07-05-11
TJS
07-05-11
NPP
07-05-11
NP
07-05-11
DH
07-05-11
BB
SCALE: 2:1
NO.
REV
C
S99697
www.souriau.com
1
1 OF 1
PRO-E
A
很抱歉,暂时无法提供与“UTS7183G1PNPT”相匹配的价格&库存,您可以联系我们找货
