ECM15DKLH
ECM15DKLH
    SULLINS
    CONN EDGECARD 30POS .156 WW
ECM15DKLH 数据手册
Female Card Edge .156” [3.96 mm] Contact Centers, .720” [18.29 mm] Insulator Height, .045” [1.14 mm] square / .031” [0.79 mm] X .062” [1.57 mm] Wire Wrap Sullins Female Card Edge SPECIFICATIONS • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board • PBT insulator • Molded-in key available • 3 Amps current rating per contact for contacts fully energized (for 5 Amps application, consult factory) • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 READOUT CANTILEVER CONTACT .188” [4.78] DUAL (D) HALF LOADED (H) TERMINATION TYPE .750” [19.05] .062” X .031” [1.57 X 0.79] POSTS, (KK) .750” [19.05] .750” [19.05] .031” X .062” [0.79 X 1.57] 90° TWISTED POSTS, (KL) .045” [1.14] SQUARE POSTS (WW) MOUNTING STYLE Ø.125” [3.18] #4-40 .250” [6.35] CLEARANCE HOLE (H) 78 NO MOUNTING EARS (N) THREADED INSERT (I) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .156” [3.96 mm] Contact Centers, .720” [18.29 mm] Insulator Height, .045” [1.14 mm] square / .031” [0.79 mm] X .062” [1.57 mm] Wire Wrap PART NUMBER OPTIONS E B M 43 D KK H - Sxxx MOUNTING STYLE (Opposite page) H = Clearance Hole N = No Mounting I = Threaded Inserts CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte = = = = Sullins Female Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures TERMINATION TYPE (Opposite Page) KK = .062” X .031” [1.57 mm X 0.79 mm] Post KL = .031” X .062” [0.79 mm X 1.57 mm] Post, Twisted 90° WW = .045” [1.14 mm] Square Post READOUT (Opposite Page) D = Dual Row H = Half Loaded CONTACT CENTERS M = .156” [3.96 mm] NUMBER OF CONTACT POSITIONS See Chart Below DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. E D B C .360 [9.14] .350 [8.89] INSERTION DEPTH .216 [5.49] .250 [6.35] .720 [18.29] REFER TO TERMINATION TYPE .188 [4.76] (WW) .198 [5.03] (KK, KL) .156 [3.96] TYP. A F 2 1 4 3 6 5 8 7 10 9 92 94 96 98 100 91 93 95 97 99 CONTACT MARKINGS 2 4 6 . . . 96 98 100 1 3 5 . . . 95 97 99 REFER TO MOUNTING STYLE INCHES MILLIMETERS POSITIONS/ CONTACTS A±.008 B±.008 C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 06/12 10/20 12/24 15/30 18/36 20/40 22/44 25/50* 28/56 30/60* 31/62* 36/72 43/86 50/100* 0.780 1.404 1.716 2.184 2.652 2.964 3.276 3.744 4.212 4.524 4.680 5.460 6.552 7.644 1.100 1.724 2.036 2.504 2.972 3.284 3.596 4.064 4.532 4.844 5.000 5.780 6.872 7.964 1.224 1.848 2.160 2.628 3.096 3.408 3.720 4.188 4.656 4.968 5.124 5.904 6.996 8.088 1.534 2.158 2.470 2.938 3.406 3.718 4.030 4.498 4.966 5.278 5.434 6.214 7.306 8.398 1.784 2.408 2.720 3.188 3.656 3.968 4.280 4.748 5.216 5.528 5.684 6.464 7.556 8.648 0.980 1.604 1.916 2.384 2.852 3.164 3.476 3.944 4.412 4.724 4.880 5.660 6.752 7.844 19.81 35.66 43.59 55.47 67.36 75.29 83.21 95.10 106.98 114.91 118.87 138.68 166.42 194.16 27.94 43.79 51.71 63.60 75.49 83.41 91.34 103.23 115.11 123.04 127.00 146.81 174.55 202.29 31.09 46.94 54.86 66.75 78.64 86.56 94.49 106.38 118.26 126.19 130.15 149.96 177.70 205.44 38.96 54.81 62.74 74.63 86.51 94.44 102.36 114.25 126.14 134.06 138.02 157.84 185.57 213.31 45.31 61.16 69.09 80.98 92.86 100.79 108.71 120.60 132.49 140.41 144.37 164.19 191.92 219.66 24.89 40.74 48.67 60.55 72.44 80.37 88.29 100.18 112.06 119.99 123.95 143.76 171.50 199.24 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 79
ECM15DKLH
1. 物料型号:文档中列出了多种型号选项,例如E B M 43 D KK H - Sxxx,具体型号取决于材料、接触类型和安装方式。
2. 器件简介:Sullins Female Card Edge连接器具有.156” [3.96 mm]接触中心、.720” [18.29 mm]绝缘体高度和.045” [1.14 mm]方形/.031” [0.79 mm]×.062” [1.57 mm]线绕。
3. 引脚分配:文档提供了详细的引脚分配图和标记,以及不同接触位置的尺寸数据。
4. 参数特性: - 可适应.062” ± .008” [1.57 mm ± 0.20 mm]的PCB板。 - PBT绝缘体。 - 3安培的电流额定值(对于5安培的应用,需咨询工厂)。 - 最大30毫欧姆的电阻。 - UL阻燃等级94V-0。
5. 功能详解:文档描述了不同类型的接触,如悬臂接触、双行(D)、半载(H)等,并提供了接触表面处理和整体镀层的详细信息。
6. 应用信息:文档提供了关于如何使用这些连接器的指导,包括操作/加工温度的参考。
7. 封装信息:提供了不同安装方式的详细信息,如无安装耳(N)、#4-40螺纹插入(I)等。
ECM15DKLH 价格&库存
很抱歉,暂时无法提供与“ECM15DKLH”相匹配的价格&库存,您可以联系我们找货
