8
7
4
5
6
2
3
1
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2899
INITIAL RELEASE
1/17/2014
JHSU
E
F
F
D
FIRST
POSITION
INDICATOR
B
PRELIMINARY
A
2X
.125 3.18 THRU
.075 1.91
SEE NOTE 13
E
E
.370
C
A
+.005
+0.13
9.40
- .015
- 0.38
.030 0.77
D
D
.180 4.57
.550 13.97
.250 6.35
.020 0.51
.300 7.62
INSERTION
DEPTH
.235±.025 5.97±0.64
.025 0.63
ACCEPTS .062" PCB
.125 3.18 TYP
A
C
SECTION A-A
C
F
_ _A_ _DSSH-S288
CONTACT MARKINGS
1 3 5 ... 45 47... 99
2 4 6 ... 46 48... 100
B
B
CONTACT ID
NOTES:
SCALE 4:1
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
CONTACTS NOT
2. CONTACT MATERIAL: SEE PART NUMBER CODING
SHOWN FOR CLARITY
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL.
8. CONTACT RATING: 3 AMP
DRAWN DATE NAME
9. CONTACT RESISTANCE: 30 MILLI OHM MAX
UNLESS OTHERWISE SPECIFIED:
6/24/2011 JH
10. INSULATION RESISTANCE: 5000 MEGA OHM MIN
DIMENSIONS ARE IN INCHES [MM]
11. DURABILITY: 500 CYCLES MIN
TITLE
TOLERANCES:
ANGULAR:
30'
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
EDGECARD .125" PITCH, HP
.XX= .02 [.5]
.XXX= .005 [.13]
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
PART NUMBER
.XXXX= .0005 [.013]
_ _A_ _DSS_-S288
14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062" TEST BLADE.
CAGE CODE DWG. NO.
SIZE
INTERPRET DIMENSIONS AND
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062" PCB
TOLERANCING
C
54453
C12338
16. MODIFICATION: CARD EXTENDER BEND FOR .062" PCB
PER: ASME Y14.5M-2009
RoHS COMPLIANT
CUSTOMER COPY
A
Pb
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
SCALE: 2:1
8
7
6
5
4
3
2
A
REV
A
SHEET 1 OF 3
1
FILE NAME: C12338, _ _A_ _DSS_-S288
8
7
4
5
6
2
3
1
F
F
E
E
D
2X
C
.125 3.18 THRU
2X .245 6.22
_ _A_ _DSSS-S288
_ _A_ _DSSN-S288
D
D
A
2X .095 2.41
D
2X #4-40
THREADED INSERTS
C
C
L±.015
(L= DIM 'A' + .190[4.83])
B
B
_ _A_ _DSSB-S288
_ _A_ _DSSI-S288
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
DATE
NAME
6/24/2011
JH
TITLE
PART NUMBER
_ _A_ _DSS_-S288
SIZE
CAGE CODE
C
54453
SCALE: 1.5:1
3
2
A
DWG. NO.
REV
C12338
A
SHEET 2 OF 3
1
8
PART NUMBER
F
E
D
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_A06DSS_-S288
_A10DSS_-S288
_A14DSS_-S288
_A15DSS_-S288
_A18DSS_-S288
_A22DSS_-S288
_A24DSS_-S288
_A25DSS_-S288
_A28DSS_-S288
_A30DSS_-S288
_A31DSS_-S288
_A32DSS_-S288
_A35DSS_-S288
_A36DSS_-S288
_A40DSS_-S288
_A43DSS_-S288
_A44DSS_-S288
_A49DSS_-S288
_A50DSS_-S288
7
4
5
6
2
3
A±.008[0.20]
B±.008[0.20]
C±.015[0.38]
D±.010[0.25]
E±.020[0.51]
F±.015[0.38]
INCH
0.625
1.125
1.625
1.750
2.125
2.625
2.875
3.000
3.375
3.625
3.750
3.875
4.250
4.375
4.875
5.250
5.375
6.000
6.125
INCH
0.875
1.375
1.875
2.000
2.375
2.875
3.125
3.250
3.625
3.875
4.000
4.125
4.500
4.625
5.125
5.500
5.625
6.250
6.375
INCH
1.035
1.535
2.035
2.160
2.535
3.035
3.285
3.410
3.785
4.035
4.160
4.285
4.660
4.785
5.285
5.660
5.785
6.410
6.535
INCH
1.295
1.795
2.295
2.420
2.795
3.295
3.545
3.670
4.045
4.295
4.420
4.545
4.920
5.045
5.545
5.920
6.045
6.670
6.795
INCH
1.555
2.055
2.555
2.680
3.055
3.555
3.805
3.930
4.305
4.555
4.680
4.805
5.180
5.305
5.805
6.180
6.305
6.930
7.055
INCH
0.875
1.375
1.875
2.000
2.375
2.875
3.125
3.250
3.625
3.875
4.000
4.125
4.500
4.625
5.125
5.500
5.625
6.250
6.375
MM
15.88
28.58
41.28
44.45
53.98
66.68
73.03
76.20
85.73
92.08
95.25
98.43
107.95
111.13
123.83
133.35
136.53
152.40
155.58
MM
22.23
34.93
47.63
50.80
60.33
73.03
79.38
82.55
92.08
98.43
101.60
104.78
114.30
117.48
130.18
139.70
142.88
158.75
161.93
MM
26.29
38.99
51.69
54.86
64.39
77.09
83.44
86.61
96.14
102.49
105.66
108.84
118.36
121.54
134.24
143.76
146.94
162.81
165.99
MM
32.89
45.59
58.29
61.47
70.99
83.69
90.04
93.22
102.74
109.09
112.27
115.44
124.97
128.14
140.84
150.37
153.54
169.42
172.59
MM
39.50
52.20
64.90
68.07
77.60
90.30
96.65
99.82
109.35
115.70
118.87
122.05
131.57
134.75
147.45
156.97
160.15
176.02
179.20
1
MM
22.23
34.93
47.63
50.80
60.33
73.03
79.38
82.55
92.08
98.43
101.60
104.78
114.30
117.48
130.18
139.70
142.88
158.75
161.93
F
E
D
PART NUMBER CODING
_ _ A_ _DSS _ - S288
C
MATERIALS (INSULATOR / CONTACT)
MOUNTING STYLE
E = PBT/PHOSPHOR BRONZE
H=
.125" DIA. CLEARANCE HOLES (PAGE 1)
OPERATING TEMP: -65°C TO +125°C
I=
#4-40 THREADED INSERT (PAGE 2)
PROCESSING TEMP: WAVE/MANUAL SOLDER
S=
.125" DIA. SIDE MOUNTING (PAGE 2)
N=
NO MOUNTING EARS (PAGE 2)
B=
OPEN CARDSLOT(PAGE 2)
R = PPS/PHOSPHOR BRONZE
C
PROCESSING TEMP: 260°C FOR 120 SECS MAX
G = PA9T/PHOSPHOR BRONZE
NUMBER OF POSITIONS
(CONTACTS PER ROW)
PROCESSING TEMP: 260°C FOR 20 SECS MAX
H = PBT/BERYLLIUM COPPER
PLATING
ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE
A = PPS/BERYLLIUM COPPER
B
CONTACT SURFACE
TERMINATION
B=
.000010" GOLD
OPERATING TEMP: -65°C TO +150°C
C=
.000030" GOLD
.000100" PURE TIN, MATTE
S=
.000010" GOLD
.000010" GOLD OVERALL
.000030" GOLD
J = PA9T/BERYLLIUM COPPER
M=
** E =
(CONSULT FACTORY FOR OTHER MATERIALS)
B
.000100" PURE TIN, MATTE, OVERALL
G=
.000010 GOLD
.000005" GOLD
Y=
.000030" GOLD
.000005" GOLD
** OVERALL PURE TIN ONLY AVAILABLE ON MATERIAL CODES E, R AND G
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
DATE
NAME
6/24/2011
JH
TITLE
PART NUMBER
_ _A_ _DSS_-S288
SIZE
CAGE CODE
C
54453
SCALE: 2:1
3
2
A
DWG. NO.
REV
C12338
A
SHEET 3 OF 3
1
很抱歉,暂时无法提供与“ECA06DSSH-S288”相匹配的价格&库存,您可以联系我们找货
