UTG62020PN
UTG62020PN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONNPLGHSGMALE20POSINLINE
UTG62020PN 数据手册
UTG Series The plastic circular connector with metal locking UTG provides the complete answer to the need for economical lightweight and robust metal coupling Flammability rating Rapid and secure locking Intermateable and interchangeable Complete range of contacts UL94-V0 compliant Locks with audible positive «click» With UTO, UTP and UTS series Trim Trio contacts #16 Connection Technologies UTG Series Layout Shell size Contact # 16 (Ø 1,6) Mixed power / signal versions 10 10-4 4 x #16 (Ø 1,6) 10-3 3 x #16 (Ø 1,6) Group C 250V 10-3W3 3 x #16 (Ø 1,6) 3 x #20 (Ø 1,0) 12 12-8 8 x #16 (Ø 1,6) 122G1 3 x #12 (Ø 2,4) 14 14-12 12 x #16 (Ø 1,6) 14-8 4 x #12 (Ø 2,4) 4 x #16 (Ø 1,6) 16 16-19 19 x #16 (Ø 1,6) 18 18-23 23 x #16 (Ø 1,6) 2 18-7 Group C 380V 7 x #16 (Ø 1,6) 18-7 34 2 x #12 (Ø 2,4) 5 x #16 (Ø 1,6) UTG Series Shell size Contact # 16 (Ø 1,6) Mixed power / signal versions 20-28 28 x #16 (Ø 1,6) 20-20 20 x #16 (Ø 1,6) Group C 660V 20 22 22-35 35 x #16 (Ø 1,6) 24 24-48 48 x #16 (Ø 1,6) 24-7 7 x #8 (Ø 3,6) 2 x #16 (Ø 1,6) 24-11 4 x #8 (Ø 3,6) 7 x #16 (Ø 1,6) Contact identification positions shown are for mating face of pin contact connectors and wire face of socket contact connectors. 3 UTG Series Specifications Connector type / Part number Shell size 10 Contacts number* Female insert Male insert Female insert 4 #16 UTG6104PN UTG6104SN UTG0104P UTG0104S 2 + ground #16 UTG6103PN UTG6103SN UTG0103P UTG0103S 3 #20 + 3 #16 UTG6103W3PN - - - 8 #16 UTG6128PN UTG6128SN UTG0128P UTG0128S 3 #12 UTG6122G1PN UTG6122G1SN UTG0122G1P UTG0122G1S 12 #16 UTG61412PN UTG61412SN UTG01412P UTG01412S 4#12 + 4 #16 - UTG6148SN UTG0148P - 19 #16 UTG61619PN UTG61619SN UTG01619P UTG01619S 23 #16 UTG61823PN UTG61823SN UTG01823P UTG01823S 7 #16 UTG6187PN UTG6187SN UTG0187P UTG0187S 2 #12 + 5 #16 UTG6187PN34 UTG6187SN34 UTG0187P34 UTG0187S34 28 #16 UTG62028PN UTG62028SN UTG02028P UTG02028S 20 #16 UTG62020PN UTG62020SN UTG02020P UTG02020S 35 #16 UTG62235PN UTG62235SN UTG02235P UTG02235S 48 #16 UTG62448PN UTG62448SN UTG02448P UTG02448S 7 #8 + 2 #16 UTG6247PN UTG6247SN UTG0247P UTG0247S 4 #8 + 7 #16 - UTG62411SN UTG02411P - 14 18 20 22 24 *Contacts supply separately For IP65 waterprotected version (for only receptacle) add «H» behind N or S. Ex. UTG0103PH 4 Panel mounting receptacle Male insert 12 16 Cable plug UTG Series Dimensions Cable Plug - UTG6 B ØD ØC Pin contact Socket contact B Shell size ØA B max ØA±0.2 Pin contact 10 21.6 12 24.8 14 28.0 16 31.2 18 34.3 31.8 / 33.0 20 37.5 31.8 / 35.3 22 47.0 24 50.1 Socket contact ØC±0.15 23.9 / 26.75 31.8 23.9 23.9 / 29.0 24.9 31.8 26.2 ØD±0.15 10.9 12.2 13.8 15.1 17.0 18.3 19.9 21.5 22.4 24.0 25.6 27.2 28.5 30.4 31.7 33.5 ØE±0.2 19.1 Wall Mounting - UTG0 A max E H ØC J Ø Ø ØD Pin contact Socket contact B max Shell size A max Pin contact 10 12 14 ØG F Socket contact B±0.15 C±0.2 24.3 / 27.6 31.7 24.3 2.3 11.3 16 18 31.7 / 34.0 20 22 24 24.3 / 30.4 27.0 33.3 28.0 30.4 2.5 11.3 / 17.9 14.5 3.5 15.3 Panel cut ØD±0.15 ØE±0.2 F±0.25 15.0 18.3 19.0 22.2 ØG±0.1 ØH±0.1 ØJ±0.1 23.8 17.3 15.1 20.6 26.2 21.8 18.2 23.0 28.6 25.0 21.4 25.3 24.6 31.0 28.1 24.6 28.5 27.0 33.3 3.2 31.3 27.7 31.7 29.4 36.5 34.5 30.9 34.9 31.8 39.7 37.7 34.1 38.0 34.9 42.9 40.9 37.3 3.9 Note: all dimensions are in mm 5 UTG Series Specifications Connector type / Part number Shell size Contacts number* Male insert Female insert 4 #16 UTG1104P UTG1104S 2 + ground #16 UTG1103P UTG1103S 3 #20 + 3 #16 - UTG1103W3S 12 8 #16 UTG1128P UTG1128S 14 12 #16 UTG11412P UTG11412S 16 19 #16 UTG11619P UTG11619S 18 23 #16 UTG11823P UTG11823S 20 28 #16 UTG12028P UTG12028S 22 35 #16 UTG12235P UTG12235S 48 #16 UTG12448P UTG12448S 7 #8 + 2 #16 UTG1247P UTG1247S 10 24 *Contacts supply separately For IP65 waterprotected version (for only receptacle) add «H» behind N or S. Ex. UTG1103PH 6 Free hanging receptacle UTG Series Dimensions Free Hanging - UTG1 B ØD Pin contact Socket contact B Shell size ØA±0.2 10 19.5 12 23.5 14 27 ØA B max Pin contact 31.7 16 30.0 18 33.3 31.7 / 34.0 33.3 / 34.3 20 36.5 22 39.5 24 42.1 Socket contact ØD±0.15 24.3 / 27.6 15.0 24.3 22.2 24.3 / 30.4 28.5 25.9 34.9 19.0 25.3 31.7 38.0 7 UTG Series Accessories Cable Clamp Cable Clamp for Waterprotected (IP65) Applications Part number Shell size Part number Shell size Part number Shell size UTG10AC 10 UTG10PG 10 UTG10ST 10 UTG12AC 12 UTG12PG 12 UTG12ST 12 UTG14AC 14 UTG14PG 14 UTG14ST 14 UTG16AC 16 UTG16PG 16 UTG16ST 16 UTG18AC 18 UTG18PG 18 UTG18ST 18 UTG20AC 20 UTG20PG 20 UTG20ST 20 UTG22AC 22 UTG22PG 22 UTG22ST 22 UTG24AC 24 UTG24PG 24 UTG24ST 24 Metal Shrink Boot 8 Cable Gland for Waterprotected (IP65) Applications Dustcap (Receptacle) Dustcap with Chain (Receptacle) Part number Shell size Part number Shell size Part number Shell size UTG10AD 10 UTP10DC 10 UTP10DCG 10 UTG12AD 12 UTP12DC 12 UTP12DCG 12 UTG14AD 14 UTP14DC 14 UTP14DCG 14 UTG16AD 16 UTP16DC 16 UTP16DCG 16 UTG18AD 18 UTP18DC 18 UTP18DCG 18 UTG20AD 20 UTP20DC 20 UTP20DCG 20 UTG22AD 22 UTP22DC 22 UTP22DCG 22 UTG24AD 24 UTP24DC 24 UTP24DCG 24 UTG Series Plastic Protective Cap for Receptacle Part number Shell size 8500-5586A 10 8500-5587A 12 8500-5588A 14 8500-5589A 16 8500-5590A 18 8500-5591A 20 8500-5592A 22 8500-5593A 24 Gasket Part number Shell size UTFD12B 10 UTFD13B 12 UTFD14B 14 UTFD15B 16 UTFD16B 18 UTFD17B 20 UTFD18B 22 UTFD19B 24 9 UTG Series Contact Selector Guide Contact supplied separately Electrical characteristics: contact resistance #20 Ø1mm #16 Ø1.6mm Machined < 6mΩ Stamped & Formed < 6mΩ Machined < 3mΩ Stamped & Formed < 6mΩ Machined < 5mΩ Machined < 5mΩ #12 Ø2.4mm #8 Ø3.6mm Available platings (contact supplied separately) A 2μ Ni + 2μ Ag J Gold flash over 2μ Ni K Min 0.4μ gold over 2μ Ni Active part: Gold flash over Ni Crimp area: Nickel Active part: 0.75μ gold min over 2μ Ni Crimp area: 1.3μ tin over Ni Other: Nickel Active part: 0.75μ Au over Ni Crimp area: flash Au over Ni S31 S18 S25 S26 TK6 2-5μ Sn pre-plated D70 Superseded by S31 S6 Superseded by S18 Other platings on request (contact supplied separately) T T: 2μm Ni mini all over + 3 to 5 μm Sn all over D28 0.75μ gold over Ni Packaging Due to the wide variety of applications, contact packaging is offered for small series (bulk package) and high volume production (reeled contacts): Size contacts #20 (Ø1mm) & #16 (Ø1.6mm) • 25 pieces loose package (Stamped & Formed contacts) • 50 pieces bulk package (Machined contacts) • 1,000 pieces bulk package (Machined contacts) • 3,000 pieces reeled (Stamped & Formed contacts) Size contacts #12 (Ø2.4mm) & #8 (Ø3.6mm) • 100 pieces bulk package (Machined contacts) Note: 1,000 pieces bulk package available by adding 1000 at the end of the part number: e.g. RC16M23K1000 2,000 pieces reeled package available by adding K at the beginning of the part number: e.g. KRC16M23K 10 • 2,000 pieces reeled (Machined contacts) Size #16 only UTG Series Crimp Contacts Standard Version Contact size Type Machined #20 Ø1 mm #16 Ø1.6 mm #8 Ø3.6 mm Part number mm² Male 26-24 0.13-0.20 RM24W3K (1) Stamped & Formed 26-24 Machined 22-20 0.13-0.25 SM24W3- (2) 0.32-0.52 Female Max wire Ø Max insulator Ø RC24W3K - 1.58 max K 0.89-1.58 TK6 S25 (female) S26 (male) (1) SC24W3- (2) SC24WL3- - RM20W3K RC20W3K - (1) SM20W3- (1) SC20W3- 22-20 Machined 20-18 Machined 30-28 Machined 26-24 0.13-0.2 RM20M13- RC20M13- RM20M12- RC20M12- 0.35-0.5 - SM24WL3- Stamped & Formed (2) (2) 1.58 max K 1.17-2.08 TK6 S25 (female) S26 (male) - SM20WL3- SC20WL3- 0.50-0.93 RM18W3K RC18W3K 0.05-0.08 RM28M1- RC28M1- 0.55 RM24M9- RC24M9- SM24M1-(1) SM24ML1-(2) SC24M1-(1) SC24ML1-(2) Available plating 2.10 max K 1.1 K, J 0.8 1.6 K, J 0.89-1.28 Insulation grip S31, S18, TK6 Stamped & Formed 26-24 0.13-0.25 Machined 22-20 0.32-0.52 Stamped & Formed 22-20 0.35-0.5 SM20M1-(1) SM20ML1-(2) SC20M1-(1) SC20ML1-(2) 1.17-2.08 Insulation grip S31, S18, TK6 Machined 20-16 0.52-1.5 RM16M23- RC16M23- 1.8 3.2 K, J (1) 1.18 (1) 1.8 2.2 K, J Stamped & Formed 18-16 0.8-1.5 SM16M1SM16ML1-(2) SC16M1SC16ML1-(2) 3.0 No insulation grip S31, S18, TK6 Stamped & Formed 18-16 0.8-1.5 SM16M11-(1) SM16ML11-(2) SC16M11-(1) SC16ML11-(2) 2.0-3.0 Insulation grip S31, S18, TK6 Machined 16-14 1.5-2.5 RM14M30- RC14M30- 2.28 3.2 K, J 14 2.0-2.5 SM14M1-(1) SM14ML1-(2) SC14M1-(1) SC14ML1-(2) 3.2 No insulation grip S31, S18, TK6 22 0.13-0.4 82911457N- 82911456- 20 0.5 82911459N- 82911458- 18 0.75-1.0 82911461N- 82911460- 16 1.5 82911463N- 82911462- - 4.9 A, K 14 2.5 82911465N- 82911464- 12 4 82911467N- 82911466- 16 1.5 82913601A 82913600A 14 2.5 82913603A 82913602A 12 4 82913605A 82913604A - 6.5 A 10 6.0 82913607A 82913606A 8 10.0 82913609A 82913608A Stamped & Formed #12 Ø2.4 mm Wire size AWG Machined Machined (1) contact reeled (2) loose contact Exemple: RM24W3K - Size #20, Machined, AWG24 wire. Note: all dimensions are in mm 11 UTG Series Crimp Contacts (Continued) First Mate Last Break Contacts Contact size Type #16 Ø1.6 mm Machined Longer male contact (+1mm) #16 Ø1.6 mm Shorter female contact (-0.7mm) Machined Wire size Part number AWG mm² Male 30-28 0.05-0.08 26-24 0.13-0.2 RM28M1GE1RM24M9GE1RM20M13GE1RM20M12GE1RM16M23GE1RM14M30GE1- - - RC28M1GE7RC24M9GE7RC20M13GE7RC20M12GE7RC16M23GE7RC14M30GE7- 22-20 0.32-0.52 20-16 0.52-1.5 16-14 1.5-2.5 30-28 0.05-0.08 26-24 0.13-0.2 22-20 0.32-0.52 20-16 0.52-1.5 16-14 1.5-2.5 Female Color band Max wire Ø (mm) Max insulator Ø (mm) Front nt Rear Re 0.55 1.1 - Red 0.8 1.6 Red Red 1.8 Black Red 2.2 Blue Red 3.2 - Red 2.28 - - Red 0.55 1.1 - Blue 0.8 1.6 Red Blue 1.8 Black Blue 2.2 Blue Blue 1.8 3.2 - Blue 2.28 - - Blue 1.18 1.8 1.18 Available plating K, J K, J How to make FMLB / LMFB connection Contact 1 Contact 2 Standard male contact Standard female contact Longer male contact Standard male contact Standard female contact Shorter female contact 12 First Mate Last Break contacts should be chosen only if the cavity is not marked with the ground symbol. For cavities marked with the ground symbol, standard contacts will fulfill the same role as a first mate, last break contact used in a standard cavity. FMLB LMFB Ground symbol UTG Series Tooling Crimp Tool Table Standard contacts Contact size #20 Ø1 mm #16 Ø1.6 mm (1) loose contact Part number RM/RC 24W3K RM/RC 20W3K RM/RC 18W3K SM 24WL3S*(1) SC 24WL3S*(1) SM/SC 20WL3S*(1) RM/RC 28M1* RM/RC 24M9* RM/RC 20M13* RM/RC 20M12* RM/RC 16M23* RM/RC 14M30* SM/SC 24ML1*(1) SM/SC 20ML1*(1) SM/SC 16ML1*(1) SM/SC 14ML1*(1) SM/SC 16ML11*(1) Head* S20RCM RX20D44 S20SCM20 S16RCM20 SHANDLES S16RCM16 S16RCM14 RX2025GE1 S16SCM20 S16SCML1 S16SCML11 Part number Hand tool 82911457N* / 82911456* 82911459N* / 82911458* 82911461N* / 82911460* 82911463N* / 82911462* M317 82911465N* / 82911464* 82911467N* / 82911466* 82913601A / 82913600A #8 Ø3.6 mm Extraction tools * endurance of SHANDLES & Head tools = 50,000 cycles Contact size #12 Ø2.4 mm Handles* 82913603A / 82913602A 82913605A / 82913604A M317 82913607A / 82913606A 82913609A / 82913608A Tool with separate locator Positioner + locator setting 1-2 2 2 VGE10077A 3 3 4 3 3 4 VGE10078A 5 6/7 Extraction tools 51060210924 51060210936 * see page 169 for plating options and other contact details Specific contacts (First mate Last break contacts) Contact size #16 Ø1 mm Longer RM contact Part number* RM28M1GE1K RM24M9GE1K RM20M13GE1K RM16M23GE1K RM20M12GE1K RM14M30GE1K Hand tools (SHANDLES) head Tool with separate locator Hand tool Positioner + locator setting S16RCM20 - - - S16RCM16 S16RCM14 MH860 - MH86186 - 6/8 MH860 MH86164G M317 UH25 RC28M1GE7K #16 Ø1 mm Shorter RC contact RC24M9GE7K RC20M13GE7K RC20M12GE7K RC16M23GE7K RC14M30GE7K S16RCM20 S16RCM16 S16RCM14 4/6 5/6 Extraction tools RX2025GE1 5/7 6/8 3 * example of plating, for other plating consult us. Coaxial contacts Consult us 13 souriau-industrial.com contactindustry@souriau.com 14 WPNUTGEUSEN01 © Copyright SOURIAU 2014 - All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. UTG Series
UTG62020PN
物料型号:UTG系列,SOURIAU品牌的塑料圆形连接器,具有金属锁定机制。
器件简介:UTG系列提供了一种经济、轻量且坚固的金属耦合解决方案,符合UL94-V0的阻燃等级,具有快速且安全的锁定特性,锁定时有清晰的“咔哒”声,可与UTO、UTP和UTS系列互配。
引脚分配:文档提供了不同外壳尺寸对应的接触点数量和配置,例如10-4表示10个位置中有4个接触点,配置为4x#16(1,6)。
参数特性:包括接触点的识别位置、接触点数量、连接器类型/部件编号等详细信息。
功能详解:文档详细描述了UTG系列的规格,包括电缆插头和面板安装插座的男性插入件和女性插入件的部件编号。
应用信息:UTG系列适用于需要IP65防水版本的应用,并且提供了相应的配件,如电缆夹、金属收缩套、防尘帽等。
封装信息:提供了不同外壳尺寸的详细尺寸数据,包括针脚接触和插座接触的直径和其他相关尺寸。
UTG62020PN 价格&库存
很抱歉,暂时无法提供与“UTG62020PN”相匹配的价格&库存,您可以联系我们找货
