8
7
4
5
6
1
2
3
REVISIONS
E
D
B
A
F
E
ECO. NO
DESCRIPTION
DATE
BY
A
2319
INITIAL RELEASE
05/17/11
EB
2451
UPDATED PN CODING TO INCLUDES MTL,
PLATING OPTIONS, CORRECTED BOM
TABLE, ADDED TOLERANCE .010 TO
CONTACT GAP DIM
9/21/2011
JH
.075 1.91
CARDSLOT
B
.030±.010 0.77±0.25
.180 4.57
A
F
+.005
+0.13
.370
9.40
- .015
- 0.38
.125 3.18
2X
C
REV.
E
.250 6.35
.610 15.49
.297 7.54
INSERTION DEPTH
.060 1.52
D
.190±.025 4.83±0.64
TAIL LENGTH
A
.025 0.64
.100 2.54 TYP
F
D
SECTION A-A
MP_ _-_100-_ _- DW- 5H_ _ _
CONTACT MARKINGS
1 3 5 ... 137 139
2 4 6 ... 138 140
.040 1.02 MIN
C
.200 5.08
ROW SPACING
C
.200 5.08
.100 2.54 TYP
A
D
2X .125 3.18
FOR MOUNTING STYLE
'1', '2', '5' OR '6'
RECOMMENDED PCB LAYOUT
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: SEE PART NUMBER CODING.
3. PLATING: SEE PART NUMBER CODING.
4. OPERATING TEMPERATURE RATING: SEE PART NUMBER CODING.
5. PROCESSING TEMPERATURE: SEE PART NUMBER CODING.
6. UL FLAMABILITY RATING: 94V-0.
7. DIELECTRIC WITHSTANDING VOLTAGE RATING: 750 VAC MIN. AT SEA LEVEL.
8. CURRENT RATING: 3 AMP PER CONTACT.
9. CONTACT RESISTANCE: 30 MILLIOHMS MAX.
10. INSULATION RESISTANCE: 5000 MEGOHMS MIN.
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH PART NUMBER AND LOT CODE.
13. ACCOMMODATES BOARD THICKNESS: .062 ± .008” [1.57 0.20].
14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062” [1.57mm]
15. WITHDRAWAL FORCE: 1 OZ MIN. PER CONTACT PAIR USING .062” [1.57mm] PCB TEST BLADE.
B
REF: _ _C_ _DRS_ (-S_ _ _)
CUSTOMER COPY
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
04/15/11
EB
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
A
EDGECARD, .100 CC, HP
PART NUMBER
SIZE
C
MP_ _-_100-_ _-DW-_H_ _ _
CAGE CODE
54453
SCALE: 3:1
2
DWG. NO.
C11701
SHEET 1 OF 3
1
REV
B
FILE NAME: C11701, MP_ _-_100_ _DW-_ H_ _ _, ( REF _ _C_ _DRS_-OMIT, S38, S81, S328)
8
7
4
5
6
1
2
3
2X #4-40 THREADED INSERTS
F
F
D
C
E
E
MP_ _-_100-_ _- DW- 6H_ _ _
MP_ _-_100-_ _- DW- 4H_ _ _
D
D
2X
.125 3.18
THRU
C
C
D
D
.250 6.35
.250 6.35
B
B
MP_ _-_100-_ _- DW- 1H_ _ _
MP_ _-_100-_ _- DW- 2H_ _ _
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
04/15/11
EB
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11701
SHEET 2 OF 3
1
REV
B
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
04/15/11
EB
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11701
SHEET 3 OF 3
1
REV
B
很抱歉,暂时无法提供与“MPL-0100-20-DW-4HK”相匹配的价格&库存,您可以联系我们找货
