CF14GT120R
CF14GT120R
    SEI
    AXIAL-D2.3X6MM
    插件电阻 - 120Ω ±2% 1/4W 0~-400ppm/℃
CF14GT120R 数据手册
CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Features: • • • • • • • • • • • • General purpose resistor ideal for commercial/industrial applications Flame retardant coatings standard Flameproof version available as CFF and CFFM Panasert available on selected sizes - contact Stackpole Auto sequencing/insertion compatible CFM (mini) ideal choice when size constraints apply Cut and formed product is available on select sizes - contact Stackpole Standard lead wire for CF and CFM is copper plated steel, with 100% tin over plate 100% tin plate on copper wire is available as type CFQ and CFQM 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications - CF Type/Code Size CF, CFQ CF, CFQ, PCF CF, CFQ CF, CFQ CF, CFQ 18 14 12 1 2 Maximum Maximum Power Rating (W) Working Overload @ 70ºC (1) Voltage (V) Voltage (V) 0.125 250 500 0.25 350 600 0.5 350 700 1 500 1000 2 500 1000 Dielectric Withstanding Voltage (V) 350 350 600 600 600 TCR (ppm/ºC) per Ohmic Range < 10 Ω 10 Ω to 9.99K Ω 10 K Ω to 99K Ω 100 K Ω to 999K Ω 1M Ω and above = = = = = ±400 ppm/ºC 0 ~ -400 ppm/ºC 0 ~ -500 ppm/ºC 0 ~ -850 ppm/ºC 0 ~ -1500 ppm/ºC Ohmic Range (Ω) and Tolerance 2% 5% 10 - 1M 1 - 22M 1 - 1M 1 - 22M 10 - 1M 1 - 22M 1 - 1M 1 - 10M 1 - 1M 1 - 10M (1) Lesser of √ P*R or maximum working voltage. Electrical Specifications - CFM Type/Code Maximum Maximum Power Rating (W) Working Size Overload @ 70ºC Voltage (V) (1) Voltage (V) Dielectric Withstanding Voltage (V) CFM, CFQM 14 0.25 250 500 350 CFM, CFQM, PCFM 12 0.5 350 600 350 CFM, CFQM 1 1 600 1000 600 TCR (ppm/ºC) per Ohmic Range < 10 Ω 10 Ω to 9.99K Ω 10 K Ω to 99K Ω 100 K Ω to 999K Ω 1M Ω and above = = = = = ±400 ppm/ºC 0 ~ -400 ppm/ºC 0 ~ -500 ppm/ºC 0 ~ -850 ppm/ºC 0 ~ -1500 ppm/ºC Ohmic Range (Ω) and Tolerance 2% 5% 1 - 1M 1 - 10M 1 - 1M 1 - 10M 1 - 1M 1 - 10M (1) Lesser of √ P*R or maximum working voltage. Electrical Specifications – CFF/CFFM Type/Code CFF CFFM (1) Lesser of √ P*R Maximum Working Maximum Overload Voltage (V) Dielectric Withstanding Voltage (V) 400 300 600 500 350 700 500 250 500 300 0.5 300 or maximum working voltage. 600 500 Size Power Rating (W) @ 70ºC 18 0.166 Voltage (V) (1) 200 14 0.25 300 12 0.5 14 0.25 12 Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 TCR (ppm/ºC) per Ohmic Range < 10 Ω 10 Ω to 9.99K Ω 10 K Ω to 99K Ω 100 K Ω to 999K Ω 1M Ω and above = = = = = ±400 ppm/ºC 0 ~ -400 ppm/ºC 0 ~ -500 ppm/ºC 0 ~ -850 ppm/ºC 0 ~ -1500 ppm/ºC Ohmic Range (Ω) and Tolerance 2%, 5% 1 - 2.2M 1 - 5.1M 1 - 2.2M www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Mechanical Specifications Type/Code Size A Body Length B Body Diameter 18 0.130 ± 0.012 3.30 ± 0.30 0.067 ± 0.012 1.70 ± 0.30 0.126 3.20 0.236 6.00 0.126 3.20 0.073 1.85 0.091 2.30 0.073 1.85 CF CFQ CFF 18 CF, CFF, CFQ, PCF CFFM 14 CFM CFQM CF CFF, CFQ 12 CFM, CFQM, CFFM CF, CFQ 1 CFM, CFQM CF, CFQ 2 ± ± ± ± ± ± 0.008 0.20 0.012 0.30 0.008 0.20 ± ± ± ± ± ± 0.008 0.20 0.012 0.30 0.008 0.20 0.130 ± 0.012 3.30 ± 0.30 0.067 ± 0.012 1.70 ± 0.30 0.335 ± 0.039 8.50 ± 1.00 0.106 ± 0.020 2.70 ± 0.50 0.236 6.00 0.433 11.00 0.354 9.00 0.591 15.00 0.091 2.30 0.177 4.50 0.138 3.50 0.197 5.00 ± ± ± ± ± ± ± ± 0.012 0.30 0.039 1.00 0.020 0.50 0.039 1.00 ± ± ± ± ± ± ± ± 0.012 0.30 0.020 0.50 0.020 0.50 0.020 0.50 C Lead Length (Bulk) 0.016 0.40 0.018 0.45 0.018 0.45 0.022 0.55 0.018 0.45 0.016 0.40 0.018 0.45 0.022 0.55 0.028 0.70 0.022 0.55 0.031 0.80 0.028 0.70 0.031 0.80 1.102 ± 0.118 28.00 ± 3.00 1.181 30.00 1.102 28.00 1.339 34.00 ± ± ± ± ± ± D - Lead Diameter 0.118 3.00 0.118 3.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.003 0.08 0.003 0.08 0.002 0.05 0.003 0.08 0.002 0.05 0.003 0.08 0.003 0.08 0.003 0.08 0.004 0.10 0.003 0.08 0.004 0.10 0.002 0.05 0.004 0.10 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Test Method MIL-STD 202, Method 308 JIS C5201-1, Short Time Overload IEC60115-1, 4.13 Resistance to JIS C5201-1, Soldering Heat IEC60115-1, 4.18 Rapid Change of JIS C5201-1, Temperature IEC60115-1, 4.19 JIS C5201-1, Endurance at 70°C IEC60115-1, 4.25.1 MIL-STD 202, Terminal Strength Method 211 JIS C5201-1, Damp Heat (Steady state) IEC60115-1, 4.24 Operating temperature range is -55C to +155C Current Noise Typical Result 1Ω ~ 91KΩ 0.15μ V/V Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 100KΩ ~ 910KΩ 0.32μ V/V 2 Test Limit 1MΩ ~ 22MΩ 0.54μ V/V 1Ω ~ 91KΩ 0.2μ V/V 100KΩ ~ 910KΩ 0.4μ V/V 1MΩ ~ 22MΩ 0.6μ V/V < ± 0.25% ≤ ± (0.75% + 0.05Ω) < ± 0.3% ≤ ± (0.5% + 0.05Ω) < ± 0.3% ≤ ± (1% + 0.05Ω) < ± 1% R < 100KΩ: ≤ ± (2% + 0.05Ω) R ≥ 100KΩ: ≤ ± (3% + 0.05Ω) < ± 0.2% ≤ ± (0.5% + 0.05Ω) < ± 1.5% R < 100KΩ: ≤ ± (3% + 0.05Ω) R ≥ 100KΩ: ≤ ± (5% + 0.05Ω) www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Power Derating Curve: Recommended Solder Profiles This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering – 100% Matte Tin / RoHS Compliant Terminations Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow – 100% Matte Tin / RoHS Compliant Terminations Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Recommended Lead Free Resistor Reflow Profile Single Pulse Power: Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Repetitive Pulse Information If repetitive pulses are applied to resistors, pulse wave form must be less than “Pulse limiting voltage”, “Pulse limiting current” or “Pulse limiting wattage” calculated by the formula below. Vp = K√P x R x T/t lp = K√P/R x T/t Pp = K2 x P x T/t Where: Vp: lp: Pp: P: R: T: t: K: [Vr: Pulse limiting voltage (V) Pulse limiting current (A) Pulse limiting wattage (W) Power rating (W) Nominal resistance (ohm) Repetitive period (sec.) Pulse duration (sec.) Coefficient: 0.8 Rated Voltage (V), Ir: Rated Current (A)] Note 1: If T > 10 → T = 10 (sec.), T / t > 1000 → T / t = 1000. Note 2: If T > 10 and T / t > 1000, “Pulse Limiting power (single pulse) is applied. Note 3: If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp). Note 4: Pulse limiting voltage (Current, Wattage) is applied at less than rated ambient temperature. If ambient temperature is more than the rated temperature (70°C), please decrease power rating according to “Power Derating Curve”. Note 5: Please assure sufficient margin for use period and conditions for “Pulse limiting voltage”. Note 6: If the pulse waveform is not square wave, please judge after transform the waveform into square wave according to the “Waveform Transformation to Square Wave”. Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Current Noise: Reel Packaging Specifications Type/Code Size CF, CFQ 18 CFF 18 Class A Max (1). 2.508 63.70 2.508 63.70 2.638 67.00 2.736 69.50 2.972 75.50 3.130 79.50 2.508 63.70 2.638 67.00 2.736 69.50 Tape 14 CF, CFQ, CFF 12 1 I CF, CFQ 0.250 6.35 2 14 CFM, CFQM, CFFM 12 CFM, CFQM 1 B Max C D (2) Unit 2.063 ± 0.079 52.40 ± 2.00 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm 0.197 ± 0.020 5.00 ± 0.50 13.504 343.00 0.394 ± 0.020 10.00 ± 0.50 0.197 ± 0.020 5.00 ± 0.50 Dimension "E": This is a non-critical dimension that does not have a tolerance in the standard. Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm). (1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component. The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component. (2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code. Contact Stackpole for more details. Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Radial Lead Taping Specifications (Pana-Sert PCF14) Symbol Description A Resistor body length C PANA-SERT Unit Symbol Description 0.256 ± 0.020 6.50 ± 0.50 inches mm L Cutout Length (1) Height of bending 0.098 ± 0.020 2.50 ± 0.50 inches mm P D Resistor body diameter 0.091 ± 0.008 2.30 ± 0.20 inches mm D0 Sprocket-hole diameter 0.157 ± 0.012 4.00 ± 0.30 F Resistor lead spacing H PANA-SERT Unit 0.433 max. 11.00 max. inches mm Resitor pitch (1) 0.500 ± 0.039 12.70 ± 1.00 inches mm P0 Sprocket-hole pitch (1) 0.500 ± 0.012 12.70 ± 0.30 inches mm inches mm P1 Sprocket-hole center to lead center 0.152 ± 0.028 3.85 ± 0.70 inches mm 0.197 ± 0.039 5.00 ± 1.00 inches mm P2 Sprocket-hole center to resistor center (1) 0.250 ± 0.051 6.35 ± 1.30 inches mm Height to bottom of resistor 0.748 ± 0.039 19.00 ± 1.00 inches mm T Thickness (chipboard and tape) 0.028 ± 0.008 0.70 ± 0.20 inches mm H0 Height to lead clinch 0.630 ± 0.020 16.00 ± 0.50 inches mm W Chipboard width (1) 0.709 + 0.039 / -0.020 18.00 + 1.00 / -0.50 inches mm H1 Height of resistor 1.122 max. 28.50 max. inches mm W0 Hold-down tape width 0.49 min. 12.50 min. inches mm h Resistor alignment 0 ± 0.079 (0 ± 5º) 0 ± 2.00 (0 ± 5º) inches mm W1 Sprocket-hole position 0.354 + 0.030 / -0.020 9.00 + 0.75 / -0.50 inches mm h1 Resistor alignment 0 ± 0.079 (0 ± 5º) 0 ± 2.00 (0 ± 5º) inches mm W2 Hold-down tape position 0.118 max. 3.00 max. inches mm I Lead protrusion 0.079 max. 2.00 max. Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. inches mm 8 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Ammo Packaging Specifications Type/Code Size CF, CFQ 16 CF, CFQ 14 CF, CFQ 12 CFQ 2 CFM, CFQM 14 CFM, CFQM 12 CFQ, CFQM 1 A B 2.953 ± 0.079 75.00 ± 2.00 C 2.756 70.00 3.937 100.00 ± ± ± ± 0.118 3.00 0.118 3.00 Unit inches mm inches mm 2.756 70.00 3.543 90.00 2.756 70.00 ± ± ± ± ± ± 0.118 3.00 0.118 3.00 0.118 3.00 inches mm inches mm inches mm 3.937 100.00 2.953 75.00 ± ± ± ± 0.118 3.00 0.118 3.00 10.039 ± 0.197 255.00 ± 5.00 inches mm inches mm Surface Temperature Rise Measurement Point Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 9 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Standard Color Codes 1 2 3 4 Color Band Description 5 Band 1st Band 2nd Band 3rd Band 4th Band 5th Band PRECISION - Have three significant-figure bands, a multiplier band and a tolerance band. Tolerances 1% or less. GENERAL PURPOSE - Have two significant-figure bands, a multiplier band and a tolerance band. Tolerances 2% or greater. Black Brown Red Orange Yellow Green Blue Violet Gray White Silver Gold Precision Nominal Nominal Nominal Multiplier Tolerance General Purpose Nominal Nominal Multiplier Tolerance - Nominal Multiplier Tolerance (%) 0 1 2 3 4 5 6 7 8 9 - 1 10 100 1K 10 K 100 K 1000 K 0.001 0.01 0.1 1 2 0.5 0.25 0.1 10 5 RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description CF CFM Carbon Film Leaded Resistor Mini-Carbon Film Leaded Resistor Package / Standard Termination Series RoHS Type Compliant Axial Axial YES YES Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 100% Matte Sn 100% Matte Sn Jan-04 (Taiwan, China) Jan-04 (Taiwan, China) Lead-Free Effective Date Code (YY/WW) 04/01 04/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 10 www.seielect.com marketing@seielect.com CF / CFM Series Stackpole Electronics, Inc. Resistive Product Solutions Carbon Film Resistor Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order C Product Series Description Standard Mini Flameproof Flameproof (mini) Panasert CF14 Panasert CFM12 Tin plating on CFQ copper wire CFQM Tin plating (mini) Tin plating on PCFQ copper wire Panasert Code CF CFM CFF CFFM PCF PCFM F 1 Power Rating Code W 18 0.125 CFF18 0.166 14 0.25 12 0.5 1 1 2 2 2 Tolerance Code Tol G 2% J 5% J T Code Description T A B(*) Tape and Reel Ammo Bulk 1 0 0 Packaging Product Code CF18, CFQ18, CFF18 CF14, CFM14, CFF14, CFFM14 CFQ14, CFQM14, PCF14 CF12, CFM12, CFF12, CFFM12 CFQ12, CFQM12, PCFM12 CFM1, CFQM1 CF1, CFQ1 CF2, CFQ2 CF18, CFQ18, CFF18 CF14, CFF14, CFFM14, CFM14 CFQ14, CFQM14 CFM12, CFFM12, CFQM12 CF12, CFF12, CFQ12, PCFM12 CF1, CFM1, CFQ1, CFQM1 PCF14 CF2 All Sizes K Resistance Value Qty 5000 2500 2000 1000 Four characters with the multiplier used as the decimal holder. 10 ohm = 10R0 10.2 Kohm = 10K2 1 Mohm = 1M00 5000 2000 1000 1000 (*) Bulk packaging may be subject to 25Kpc MOQ Rev Date: 3/3/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 11 www.seielect.com marketing@seielect.com
CF14GT120R
物料型号: - CF系列:通用碳膜电阻器,适用于商业/工业应用 - CFM系列:迷你型碳膜电阻器,适合尺寸受限的应用 - CFF系列:防火版本,提供额外的安全性 - CFQ系列:100%无铅且符合RoHS标准 - PCF系列:适用于自动排序/插入
器件简介: - 碳膜电阻器,具有阻燃涂层,部分型号提供防火版本 - 兼容自动插入设备,部分尺寸提供Panasert选项 - 引脚材料为铜镀钢,表面100%镀锡或100%镀锡铜线
引脚分配: - 标准引脚长度(散装)和引脚直径详细列出 - 不同型号的引脚长度和直径有细微差别
参数特性: - 包括功率等级、最大工作电压、最大过载电压、耐电压、温度系数等 - 提供了详细的电气规格表格,包括不同尺寸和类型的电阻器
功能详解: - 描述了电阻器的一般用途和特定应用场景 - 包括对环境政策和冲突矿产的承诺
应用信息: - 电阻器适用于一般商业和工业用途,以及尺寸受限的场合 - 提供了操作温度范围和功率降额曲线
封装信息: - 机械规格详细列出,包括身体长度、直径、引脚长度等 - 提供了包装规格和卷轴包装的详细信息
CF14GT120R 价格&库存
很抱歉,暂时无法提供与“CF14GT120R”相匹配的价格&库存,您可以联系我们找货
CF14GT120R
  • 25000+0.0923925000+0.01191
