Female Card Edge
.125” [3.18 mm] Contact Centers, .610” [15.49 mm] Insulator Height,
Dip Solder/Wire Wrap/Right Angle for .093” [2.36 mm] or .125” [3.18 mm] Mating PCB
Sullins Female Card Edge
SPECIFICATIONS
• Accommodates .093” ± .008” [2.36 mm 0.20 mm] PC board
or .125” ± .008” [3.18 mm ± 0.20 mm] mating PCB
• PBT, PPS or PA9T insulator
• Molded-in key available
• 3 Amps current rating for one contact energized
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
READOUT
HALF LOADED (H)
DUAL (D)
TERMINATION TYPE
L
POST CROSS
SECTION (K)
POST LENGTH
L ± .025”ʺ [0.64]
FITS MIN.
HOLE SIZE
RS DIP SOLDER
.025ʺ [0.64] SQ.
.190ʺ [4.83]
.040ʺ [1.02]
RM WIRE WRAP
.025ʺ [0.64] SQ.
.560ʺ [14.20]
.040ʺ [1.02]
TA RIGHT ANGLE
.025ʺ [0.64] SQ.
.100ʺ [2.54]
.043ʺ [1.09]
TB RIGHT ANGLE
.025ʺ [0.64] SQ.
.180ʺ [4.57]
.043ʺ [1.09]
TM RIGHT ANGLE
.025ʺ [0.64] SQ.
.250ʺ [6.35]
.043ʺ [1.09]
TERMINATION TYPE
.030” [0.76]
.150” [3.81]
L
.250” [6.35]
K
LOOP
BELLOWS
(RS, RM)
RIGHT ANGLE
DIP SOLDER
(TA, TB, TM)
PCB LAYOUT
COMPONENT SIDE
.125” [3.18] TYP.
.250” [6.35]
.150” [3.81]
Ø .040” [1.02]
2X Ø .125” [3.18]
FOR (D) OR (T)
MOUNTING
A
D
.125” [3.18] TYP.
Ø .043” [1.09]
.095” [2.41]
A
D
2X Ø .125” [3.18]
FOR (Z) MOUNTING
RIGHT ANGLE TERMINATIONS
(TA, TB, TM)
STRAIGHT PIN TERMINATIONS
(RS, RM)
MOUNTING STYLE
Ø.125” [3.18]
#4-40
.250” [6.35]
NO MOUNTING EARS
(N)
66
FLUSH MOUNTING
(D)
.250” [6.35]
FLUSH MOUNTING WITH
THREADED INSERT
(T)
Ø.125” [3.18]
.250” [6.35]
FLUSH MOUNTING WITH SIDE HOLES
(Z)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B A 50 D RM D - S273
MODIFICATION CODE (Consult Factory)
-S273 = FOR .093” ± .008” [2.36 mm ± 0.20 mm]
THICK MATING PCB
-S664 = FOR .125” ± .008” [3.18 mm ± 0.20 mm]
THICK MATING PCB
MOUNTING STYLE (Opposite Page)
N = No Mounting
D = Flush Mounting
T = Flush Mounting With Threaded Inserts
Z = Flush Mounting With Side Holes
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
B
C
G
Y
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze(Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT & Beryllium Copper
A = PPS & Beryllium Copper
J = PA9T & Beryllium Copper
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
TERMINATION TYPE (Opposite Page)
RS = .025” [0.64 mm] Square Dip Solder
RM = .025” [0.64 mm] Square Wire Wrap
TA, TB, TM = .025” [0.64 mm] Square Right Angle
READOUT (Opposite Page)
D = Dual
H = Half Loaded
NUMBER OF CONTACT POSITIONS
See Chart Below
CONTACT CENTERS
A = .125” [3.18 mm]
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
.297 [7.54] INSERTION DEPTH
C
REFER TO MOUNTING STYLE
.360
[9.14]
.470 [11.94]
.610
[15.49]
A
B
D
C
.060
[1.52]
REFER TO
TERMINATION TYPE,
SEE OPPOSITE PAGE
.125 [3.18] TYP.
F
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
INCHES
MILLIMETERS
POSITIONS/
CONTACTS
A±.008
B±.008
C±.015
D±.010
E±.020
F±.015
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
F±0.38
06/12*
08/16*
10/20*
14/28*
15/30*
18/36*
22/44*
24/48*
25/50
28/56*
30/60
31/62*
32/64
35/70*
36/72
40/80*
43/86*
44/88*
49/98*
50/100
0.625
0.875
1.125
1.625
1.750
2.125
2.625
2.875
3.000
3.375
3.625
3.750
3.875
4.250
4.375
4.875
5.250
5.375
6.000
6.125
0.875
1.125
1.375
1.875
2.000
2.375
2.875
3.125
3.250
3.625
3.875
4.000
4.125
4.500
4.625
5.125
5.500
5.625
6.250
6.375
1.035
1.285
1.535
2.035
2.160
2.535
3.035
3.285
3.410
3.785
4.035
4.160
4.285
4.660
4.785
5.285
5.660
5.785
6.410
6.535
1.295
1.545
1.795
2.295
2.420
2.795
3.295
3.545
3.670
4.045
4.295
4.420
4.545
4.920
5.045
5.545
5.920
6.045
6.670
6.795
1.555
1.805
2.055
2.555
2.680
3.055
3.555
3.805
3.930
4.305
4.555
4.680
4.805
5.180
5.305
5.805
6.180
6.305
6.930
7.055
0.915
1.165
1.415
1.915
2.040
2.415
2.915
3.165
3.290
3.665
3.915
4.040
4.165
4.540
4.665
5.165
5.540
5.665
6.290
6.415
15.88
22.23
28.58
41.28
44.45
53.98
66.68
73.03
76.20
85.73
92.08
95.25
98.43
107.95
111.13
123.83
133.35
136.53
152.40
155.58
22.23
28.58
34.93
47.63
50.80
60.33
73.03
79.38
82.55
92.08
98.43
101.60
104.78
114.30
117.48
130.18
139.70
142.88
158.75
161.93
26.29
32.64
38.99
51.69
54.86
64.39
77.09
83.44
86.61
96.14
102.49
105.66
108.84
118.36
121.54
134.24
143.76
146.94
162.81
165.99
32.89
39.24
45.59
58.29
61.47
70.99
83.69
90.04
93.22
102.74
109.09
112.27
115.44
124.97
128.14
140.84
150.37
153.54
169.42
172.59
39.50
45.85
52.20
64.90
68.07
77.60
90.30
96.65
99.82
109.35
115.70
118.87
122.05
131.57
134.75
147.45
156.97
160.15
176.02
179.20
23.24
29.59
35.94
48.64
51.82
61.34
74.04
80.39
83.57
93.09
99.44
102.62
105.79
115.32
118.49
131.19
140.72
143.89
159.77
162.94
* Consult factory for availability.
67
很抱歉,暂时无法提供与“GBA30DTBD-S664”相匹配的价格&库存,您可以联系我们找货
