GBC22DRST-S273
GBC22DRST-S273
    SULLINS
    CONN EDGECARD 44POS DIP .100 SLD
GBC22DRST-S273 数据手册
Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Profile, .470” [11.94 mm] Wide Body, Dip Solder/Wire Wrap/Right Angle/Card Extender for .093”or .125” Mating PCB Sullins Female Card Edge SPECIFICATIONS • Accommodates .093” ± .008” [2.36 mm ± 0.20 mm] or .125” ± .008” [3.18 mm ± 0.20 mm] mating PCB (Consult Factory for .031” ± .006” [0.79 mm ± 0.15 mm] PC Board) • PBT, PPS or PA9T insulator • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 READOUT DUAL (D) HALF LOADED (H) TERMINATION TYPE L TERMINATION TYPE .030” [0.76] .150” [3.81] L K .250” [6.35] LOOP BELLOWS (RS, RM) RIGHT ANGLE DIP SOLDER (TA, TB, TM) POST CROSS SECTION (K) POST LENGTH L ±.025ʺ[0.64] FITS MIN. HOLE SIZE RS Dip Solder .025ʺ [0.64] SQ. .190ʺ [4.83] .040ʺ [1.02] RM Wire Wrap .025ʺ [0.64] SQ. .560ʺ [14.20] .040ʺ [1.02] TA Right Angle .025ʺ [0.64] SQ. .100ʺ [2.54] .043ʺ [1.09] TB Right Angle .025ʺ [0.64] SQ. .180ʺ [4.57] .043ʺ [1.09] TM Right Angle .025ʺ [0.64] SQ. .250ʺ [6.35] .043ʺ [1.09] PCB LAYOUT .250” [6.35] COMPONENT SIDE .100” [2.54] TYP. Ø .040” [1.02] A .150” [3.81] 2X Ø.125” [3.18] 'D' or 'T' MOUNTING Ø .043” [1.09] 2X Ø .125” [3.18] 'Z' MOUNTING .095” [2.41] D .100” [2.54] TYP. A D RIGHT ANGLE (TA, TB, TM) TERMINATIONS STRAIGHT PIN (RS, RM) TERMINATIONS MOUNTING STYLE NO MOUNTING EARS (N) 54 Ø.125” [3.18] #4-40 Ø.125” [3.18] .250” [6.35] .250” [6.35] .250” [6.35] FLUSH MOUNTING (D) FLUSH MOUNTING WITH THREADED INSERT (T) FLUSH MOUNTING WITH SIDE HOLES (Z) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Profile, .470” [11.94 mm] Wide Body, Dip Solder/Wire Wrap/Right Angle/Card Extender for .093”or .125” Mating PCB PART NUMBER OPTIONS E B C 70 D RM D - S273 CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y = = = = Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte Sullins Female Card Edge MODIFICATION CODE (Consult Factory) -S273 = FOR .093” ± .008” [ 2.36 mm ± 0.20 mm] THICK MATING PCB -S664 = FOR .125” ± .008” [3.18 mm ± 0.20 mm] THICK MATING PCB MOUNTING STYLE (Opposite Page) N = No Mounting D = Flush Mounting T = Flush Mounting With Threaded Inserts Z = Flush Mounting With Side Holes TERMINATION TYPE (Opposite Page) RS = .025” [0.64 mm] Square Dip Solder RM = .025” [0.64 mm] Square Wire Wrap TA, TB, TM = .025” [0.64 mm] Square Right Angle READOUT (Opposite Page) D = Dual H = Half Loaded NUMBER OF CONTACT POSITIONS See Chart Below CONTACT CENTERS C = .100” [2.54 mm] MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .297 [7.54] INSERTION DEPTH C REFER TO MOUNTING STYLE .470 [11.94] .360[9.14] A B D E .060 [1.52] .610 [15.49] REFER TO TERMINATION TYPE, SEE OPPOSITE PAGE .100 [2.54] TYP. F Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS A±.008 B±.008 06/12 0.500 0.700 07/14* 0.600 0.800 08/16* 0.700 0.900 10/20 0.900 1.100 12/24 1.100 1.300 15/30* 1.400 1.600 17/34 1.600 1.800 18/36 1.700 1.900 20/40* 1.900 2.100 22/44 2.100 2.300 24/48* 2.300 2.500 25/50* 2.400 2.600 28/56 2.700 2.900 30/60 2.900 3.100 31/62* 3.000 3.200 35/70 3.400 3.600 36/72 3.500 3.700 40/80* 3.900 4.100 43/86 4.200 4.400 44/88* 4.300 4.500 49/98* 4.800 5.000 50/100 4.900 5.100 55/110 5.400 5.600 60/120* 5.900 6.100 61/122 6.000 6.200 65/130* 6.400 6.600 70/140 6.900 7.100 * Consult factory for availability. INCHES C±.015 0.860 0.960 1.060 1.260 1.460 1.760 1.960 2.060 2.260 2.460 2.660 2.760 3.060 3.260 3.360 3.760 3.860 4.260 4.560 4.660 5.160 5.260 5.760 6.260 6.360 6.760 7.260 D±.010 1.175 1.275 1.375 1.575 1.775 2.075 2.275 2.375 2.575 2.775 2.975 3.075 3.375 3.575 3.675 4.075 4.175 4.575 4.875 4.975 5.475 5.575 6.075 6.575 6.675 7.075 7.575 MILLIMETERS E±.020 1.435 1.535 1.635 1.835 2.035 2.335 2.535 2.635 2.835 3.035 3.235 3.335 3.635 3.835 3.935 4.335 4.435 4.835 5.135 5.235 5.735 5.835 6.335 6.835 6.935 7.335 7.835 F±.015 0.750 0.850 0.950 1.150 1.350 1.650 1.850 1.950 2.150 2.350 2.550 2.650 2.950 3.150 3.250 3.650 3.750 4.150 4.450 4.550 5.050 5.150 5.650 6.150 6.250 6.650 7.150 A±0.20 12.70 15.24 17.78 22.86 27.94 35.56 40.64 43.18 48.26 53.34 58.42 60.96 68.58 73.66 76.20 86.36 88.90 99.06 106.68 109.22 121.92 124.46 137.16 149.86 152.40 162.56 175.26 B±0.20 17.78 20.32 22.86 27.94 33.02 40.64 45.72 48.26 53.34 58.42 63.50 66.04 73.66 78.74 81.28 91.44 93.98 104.14 111.76 114.30 127.00 129.54 142.24 154.94 157.48 167.64 180.34 C±0.38 21.84 24.38 26.92 32.00 37.08 44.70 49.78 52.32 57.40 62.48 67.56 70.10 77.72 82.80 85.34 95.50 98.04 108.20 115.82 118.36 131.06 133.60 146.30 159.00 161.54 171.70 184.40 D±0.25 29.85 32.39 34.93 40.01 45.09 52.71 57.79 60.33 65.41 70.49 75.57 78.11 85.73 90.81 93.35 103.51 106.05 116.21 123.83 126.37 139.07 141.61 154.31 167.01 169.55 179.71 192.41 E±0.51 36.45 38.99 41.53 46.61 51.69 59.31 64.39 66.93 72.01 77.09 82.17 84.71 92.33 97.41 99.95 110.11 112.65 122.81 130.43 132.97 145.67 148.21 160.91 173.61 176.15 186.31 199.01 F±0.38 19.05 21.59 24.13 29.21 34.29 41.91 46.99 49.53 54.61 59.69 64.77 67.31 74.93 80.01 82.55 92.71 95.25 105.41 113.03 115.57 128.27 130.81 143.51 156.21 158.75 168.91 181.61 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 55
GBC22DRST-S273
物料型号:Sullins Female Card Edge
器件简介:这是一种女性卡边连接器,具有2.54毫米的接触中心距离,15.49毫米的外形轮廓,11.94毫米的宽体,适用于0.093英寸或0.125英寸的配合PCB板。它支持浸锡、绕线和直角卡延长器。
引脚分配:文档中提供了详细的引脚分配和PCB布局信息,包括引脚的直径、位置和间距。
参数特性: - 接触中心距离:2.54毫米 - 外形轮廓:15.49毫米 - 宽体:11.94毫米 - 电流额定:单个接触点3安培 - 最大电阻:30毫欧姆 - UL阻燃等级:94V-0
功能详解:连接器支持多种终止类型,包括浸锡、绕线和直角,以及不同的安装方式,如无耳安装、齐平安装、带螺纹插入件的齐平安装和带侧孔的齐平安装。
应用信息:适用于需要卡边连接的应用,如电子设备中的PCB板连接。
封装信息:提供了不同材料选项,包括PBT、PPS或PA9T绝缘体,以及不同的接触材料,如铍铜和磷青铜。还提供了不同的镀层选项,包括金和锡。
GBC22DRST-S273 价格&库存
很抱歉,暂时无法提供与“GBC22DRST-S273”相匹配的价格&库存,您可以联系我们找货
