Female Card Edge
.125” [3.18 mm] Contact Centers, .431” [10.95 mm] Insulator Height,
Dip Solder/Eyelet/Right Angle for .062” [1.57 mm] or .031” [0.79 mm] Mating PCB
Sullins Female Card Edge
SPECIFICATIONS
• Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
or .031” ± .006” [0.79 mm ± 0.15 mm] PC board
• Molded-in key available
• 3 Amps current rating for one contact energized
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
READOUT
POLARIZING KEY
.265” [6.73] INSERTION DEPTH
FULL BELLOWS
PLA-K1
KEY IN BETWEEN CONTACTS
(ORDER SEPARATELY)
BACK-UP
SPRINGS
.230” [5.84]
.030” [0.76]
LETTER SIDE
.200” [5.08]
CONSULT FACTORY FOR MOLDED-IN KEY
HALF LOADED (H)
DUAL (D)
TERMINATION TYPE
EYELET ACCEPTS
3-#26 AWG
.200” [5.08] (RT)
.440” [11.19] (RY)
.225”
[5.72]
.165” [4.19] (RJ)
.185” [4.70] (RX)
.140” [3.56]
NARROW DIP SOLDER
(RT, RY)
.007” [0.18] THICK
.250” [6.35] (RJ)
.200” [5.08] (RX)
FITS Ø .043” [1.09]
WIDE DIP SOLDER
(RJ, RX)
EYELET
(RE)
.125” [3.18]
.275”
[6.98]
.185” [4.70]
.210” [5.33] (RE)
.185” [4.70] (RT)
.425” [10.80] (RY)
.050”
[1.27]
NUMBER SIDE
ACCEPTS .062” [1.57] PCB
.014” [0.36] THICK
CARD EXTENDER
REQUIRES -S13 MODIFICATION CODE
(RE,RT,RY TERMINATIONS ONLY)
EYELET
(TE)
.156” [3.96]
FITS Ø .043” [1.09]
RIGHT ANGLE
(RA)
MOUNTING STYLE
Ø.125”
[3.18]
CLEARANCE
HOLE (H)
62
#4-40
THREADED
INSERT(I)
Ø.116” [2.95]
CLEARANCE
FOR #4 SCREW
Ø.125”
[3.18]
.135”
[3.43]
FLOATING
BOBBIN (F)
NO MOUNTING EARS
(N)
SIDE MOUNTING
(S)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
-S13 = Card Extender Accepts .062” [1.57 mm] PCB
(RE, RT, RY Terminations Only)
-S734 = .031” ± .006” [0.79 mm ± 0.15 mm] Thick PCB
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
*F = PPS/Spinodal (Overall Gold Plating Only)
Consult factory for special soldering guidelines.
*C = PPS/Beryllium Nickel (Overall Gold Plating Only)
*W = PEEK/Beryllium Nickel (Overall Gold Plating Only)
*Consult factory for availability.
Refer to Page 7 for Operating/Processing Temperatures
MOUNTING STYLE (Opposite Page)
H = .125” [3.18 mm] Clearance Holes
N = No Mounting
S = Side Mounting
I = Threaded Insert
F = Floating Bobbin
TERMINATION TYPE (Opposite Page)
RA = Right Angle
RE = Eyelet (Standard)
TE = Eyelet (Overall Plated Only)
RT = .140” [3.56 mm] X .200” [5.08 mm] Dip Solder
RY = .140” [3.56 mm] X .440” [11.19 mm] Dip Solder
RX = .200” [5.08 mm] X .185” [4.70 mm] Dip Solder
RJ = .250” [6.35 mm] X .165” [4.19 mm] Dip Solder
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
CONTACT CENTERS
A = .125” [3.18 mm]
B
C
G
Y
E B A 43 D RE H - Sxxx
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
READOUT (Opposite Page)
D = Dual
H = Half Loaded
NUMBER OF CONTACT POSITIONS
See Chart Below
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
REFER TO
MOUNTING STYLE
B
A
.265 [6.73]
INSERTION DEPTH
C
.245 [6.22]
.431 [10.95]
CONTACT MARKINGS
(LETTERS G,I,O & Q NOT USED)
1 2 3 ... 23 24 ... 45 46 ...
A B C ... a b ... AA BB ...
.025
[0.64]
F
D
E
.125 [3.18] TYP.
1
2
3
A
B
C DD EE FF
48 49 50
REFER TO TERMINATION TYPE
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
POSITIONS/
CONTACTS
06/12
10/20
14/28
15/30
18/36
22/44
28/56
30/60
31/62
35/70
36/72
37/74
40/80
43/86
44/88
49/98
50/100
INCHES
MILLIMETERS
A±.008 B±.008 C±.015 D±.010 E±.020
0.625
1.125
1.625
1.750
2.125
2.625
3.375
3.625
3.750
4.250
4.375
4.500
4.875
5.250
5.375
6.000
6.125
0.875
1.375
1.875
2.000
2.375
2.875
3.625
3.875
4.000
4.500
4.625
4.750
5.125
5.500
5.625
6.250
6.375
1.035
1.535
2.035
2.160
2.535
3.035
3.785
4.035
4.160
4.660
4.785
4.910
5.285
5.660
5.785
6.410
6.535
1.295
1.795
2.295
2.420
2.795
3.295
4.045
4.295
4.420
4.920
5.045
5.170
5.545
5.920
6.045
6.670
6.795
1.575
2.075
2.575
2.700
3.075
3.575
4.325
4.575
4.700
5.200
5.325
5.450
5.825
6.200
6.325
6.950
7.075
F+.005/-.015
0.330
0.370
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
15.88
28.58
41.28
44.45
53.98
66.68
85.73
92.08
95.25
107.95
111.13
114.30
123.83
133.35
136.53
152.40
155.58
22.23
34.93
47.63
50.80
60.33
73.03
92.08
98.43
101.60
114.30
117.48
120.65
130.18
139.70
142.88
158.75
161.93
26.29
38.99
51.69
54.86
64.39
77.09
96.14
102.49
105.66
118.36
121.54
124.71
134.24
143.76
146.94
162.81
165.99
32.89
45.59
58.29
61.47
70.99
83.69
102.74
109.09
112.27
124.97
128.14
131.32
140.84
150.37
153.54
169.42
172.59
40.01
52.71
65.41
68.58
78.11
90.81
109.86
116.21
119.38
132.08
135.26
138.43
147.96
157.48
160.66
176.53
179.71
F+0.13/-0.38
8.38
9.40
63
很抱歉,暂时无法提供与“EBA10DREN-S13”相匹配的价格&库存,您可以联系我们找货
