EBC13DSXI
EBC13DSXI
    SULLINS
    CONNEDGEDUALFMALE26POS0.100
EBC13DSXI 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 1750 INITIAL RELEASE 7-10-08 MNH E F D F B A .100 2.54 E 2X E .075[1.90] CARDSLOT .125 3.18 C F A D .186 4.72 .265 6.73 INSERTION DEPTH D .431 10.95 .245 6.22 FITS .043 MIN HOLE .025 0.64 .032 0.81 .160±.025 4.06±0.64 TAIL LENGTH C C _ _C_ _ DSXH A SECTION A - A CONTACT MARKINGS B 1 2 3 ... 60 B A 1 2 3 ... 60 A B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING CONTACT ID 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING SCALE 2:1 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. VOLTAGE RATING: 600 VDC MINIMUM AT SEA LEVEL. 8. CURRENT RATING: 3 AMP PER CONTACT 9. VOLTAGE DROP: 30 MILLI VOLT AT RATED CURRENT 10. INSULATION RESISTANCE: 5000 MEGA OHM 11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND BARCODE 12. BOARD THICKNESS ACCOMMODATED: .062 .008" 13. BOARD INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062" TEST BLADE. INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION W17.3-01. 14. BOARD WITHDRAWAL FORCE: 1 OUNCE MINIMUM PER CONTACT PAIR USING .062" PCB 8 7 6 5 CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 30' .XX= .02 [.508] .XXX= .005 [.1270] .XXXX= .0005 [.0127] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 4 DRAWN NAME MNH A CONNECTOR, .100 CC LP _ _ C _ _ DSX _ SIZE DWG. NO. INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE 7-10-08 THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. C REV C11127 SCALE: 2:1 2 A SHEET 1 OF 3 1 FILE NAME: Z:\COMPONENTS\Part Assemblies\Customer Drawings\Customer Drawings for Catalog\C11127, _ _C_ _DSX _ PRINT: 7/10/2008 8 7 5 6 4 1 2 3 F F D C 4X .125 3.18 E E .135 3.43 _ _C_ _DSXN _ _C_ _DSXS 2X FLOATING BOBBIN .116 [2.95] CLEARANCE FOR # 4 SCREW D D D D 2X #4-40 THREADED INSERTS C C .280 7.11 _ _C_ _ DSXF _ _C_ _ DSXI B B CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: Pb A DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 30' .XX= .02 [.508] .XXX= .005 [.1270] .XXXX= .0005 [.0127] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 8 7 6 5 4 DRAWN NAME MNH A CONNECTOR, .100 CC LP _ _ C _ _ DSX _ SIZE DWG. NO. INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE 7-10-08 THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. C REV C11127 SCALE: 2:1 2 A SHEET 2 OF 3 1 FILE NAME: Z:\COMPONENTS\Part Assemblies\Customer Drawings\Customer Drawings for Catalog\C11127, _ _C_ _DSX _ PRINT: 7/10/2008 8 F E D C 7 NO. OF A ±.008[0.20] PA RT POS. NUMBER IN MM _ _ C04DSX _ * 4 0.300 7.62 _ _ C05DSX _ 5 0.400 10.16 _ _ C06DSX _ 6 0.500 12.70 _ _ C07DSX _ 7 0.600 15.24 _ _ C08DSX _ 8 0.700 17.78 _ _ C10DSX _ 10 0.900 22.86 _ _ C12DSX _ 12 1.100 27.94 _ _ C13DSX _ 13 1.200 30.48 _ _ C15DSX _ 15 1.400 35.56 _ _ C17DSX _ 17 1.600 40.64 _ _ C18DSX _ 18 1.700 43.18 _ _ C19DSX _ 19 1.800 45.72 _ _ C20DSX _ 20 1.900 48.26 _ _ C22DSX _ 22 2.100 53.34 _ _ C23DSX _ * 23 2.200 55.88 _ _ C25DSX _ 25 2.400 60.96 _ _ C26DSX _ 26 2.500 63.50 _ _ C28DSX _ 28 2.700 68.58 _ _ C30DSX _ 30 2.900 73.66 _ _ C31DSX _ 31 3.000 76.20 _ _ C35DSX _ 35 3.400 86.36 _ _ C36DSX _ 36 3.500 88.90 _ _ C40DSX _ 40 3.900 99.06 _ _ C43DSX _ 43 4.200 106.68 _ _ C44DSX _ 44 4.300 109.22 _ _ C49DSX _ 49 4.800 121.92 _ _ C50DSX _ 50 4.900 124.46 _ _ C52DSX _ * 52 5.100 129.54 _ _ C60DSX _ 60 5.900 149.86 _ _ C65DSX _ 65 6.400 162.56 * CONSULT FACTORY FOR AVAILABILITY 4 5 6 B±.008[0.20] IN MM 0.500 12.70 0.600 15.24 0.700 17.78 0.800 20.32 0.900 22.86 1.100 27.94 1.300 33.02 1.400 35.56 1.600 40.64 1.800 45.72 1.900 48.26 2.000 50.80 2.100 53.34 2.300 58.42 2.400 60.96 2.600 66.04 2.700 68.58 2.900 73.66 3.100 78.74 3.200 81.28 3.600 91.44 3.700 93.98 4.100 104.14 4.400 111.76 4.500 114.30 5.000 127.00 5.100 129.54 5.300 134.62 6.100 154.94 6.600 167.64 C±.015[0.38] IN MM 0.675 17.15 0.775 19.69 0.875 22.23 0.975 24.77 1.075 27.31 1.275 32.39 1.475 37.47 1.575 40.01 1.775 45.09 1.975 50.17 2.075 52.71 2.175 55.25 2.275 57.79 2.475 62.87 2.575 65.41 2.775 70.49 2.875 73.03 3.075 78.11 3.275 83.19 3.375 85.73 3.775 95.89 3.875 98.43 4.275 108.59 4.575 116.21 4.675 118.75 5.175 131.45 5.275 133.99 5.475 139.07 6.275 159.39 6.775 172.09 D±.010[0.25] IN MM 0.975 24.77 1.075 27.31 1.175 29.85 1.275 32.39 1.375 34.93 1.575 40.01 1.775 45.09 1.875 47.63 2.075 52.71 2.275 57.79 2.375 60.33 2.475 62.87 2.575 65.41 2.775 70.49 2.875 73.03 3.075 78.11 3.175 80.65 3.375 85.73 3.575 90.81 3.675 93.35 4.075 103.51 4.175 106.05 4.575 116.21 4.875 123.83 4.975 126.37 5.475 139.07 5.575 141.61 5.775 146.69 6.575 167.01 7.075 179.71 0.330 8.38 E D 0.400 10.16 C H = .125" DIA. CLEARANCE HOLES (PAGE 1) NUMBER OF POSITIONS (CONTACTS PER ROW) OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C FOR 10 SECS MAX I = #4-40 THREADED INSERT (PAGE 2) S = .125" DIA. SIDE MOUNTING (PAGE 2) R = PPS/PHOSPHOR BRONZE N = NO MOUNTING EARS (PAGE 2) OPERATING TEMP: -65°C TO +125°C F = FLOATING BOBBIN (PAGE 2) PROCESSING TEMP: 260°C FOR 120 SECS MAX G = PA 9T/PHOSPHOR BRONZE PLATING ALL PLATINGS HAVE .000050" NICKEL UNDERPLATE OPERATING TEMP: -65°C TO +125°C CONTACT SURFACE PROCESSING TEMP: 260°C FOR 120 SECS MAX H = PBT/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C FOR 10 SECS MAX A = PPS/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C FOR 120 SECS MAX 7 TERMINATION G = .000010" GOLD .000005" GOLD Y = .000030" GOLD .000005" GOLD B = .000010" GOLD .000100" PURE TIN, MATTE C = .000030" GOLD .000100" PURE TIN, MATTE B **E = .000100" PURE TIN, MATTE, OVERALL S = .000010" GOLD OVERALL M = .000030" GOLD .000010" GOLD OVERALL J = PA9T/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C FOR 120 SECS MAX F = PPS/SPINODAL (CONSULT FACTORY) OPERATING TEMP: -65°C TO +200°C PROCESSING TEMP: 260°C FOR 120 SECS MAX AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) C = PPS/BERYLLIUM NICKEL (CONSULT FA CTORY) OPERATING TEMP: -65°C TO +200°C PROCESSING TEMP: 260°C FOR 120 SECS MAX AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) W = PEEK/BERYLLIUM NICKEL (CONSULT FA CTORY) OPERATING TEMP: -65°C TO +250°C AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) 8 F MOUNTING STYLE E = PBT/PHOSPHOR BRONZE A F±.005[0.13] IN MM PART NUMBER CODING _ _ C _ _ DSX _ MATERIAL (INSULATOR/CONTACT) B E±.020[0.51] IN MM 1.275 32.39 1.375 34.93 1.475 37.47 1.575 40.01 1.675 42.55 1.875 47.63 2.075 52.71 2.175 55.25 2.375 60.33 2.575 65.41 2.675 67.95 2.775 70.49 2.875 73.03 3.075 78.11 3.175 80.65 3.375 85.73 3.475 88.27 3.675 93.35 3.875 98.43 3.975 100.97 4.375 111.13 4.475 113.67 4.875 123.83 5.175 131.45 5.275 133.99 5.775 146.69 5.875 149.23 6.075 154.31 6.875 174.63 7.375 187.33 1 2 3 CUSTOMER COPY ** OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R AND G A LL PLATINGS A RE LEA D FREE UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 30' .XX= .02 [.508] .XXX= .005 [.1270] .XXXX= .0005 [.0127] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 6 5 4 DRAWN NAME MNH A CONNECTOR, .100 CC LP _ _ C _ _ DSX _ SIZE DWG. NO. INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE 7-10-08 THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. C REV C11127 SCALE: 2:1 2 A SHEET 3 OF 3 1 FILE NAME: Z:\COMPONENTS\Part Assemblies\Customer Drawings\Customer Drawings for Catalog\C11127, _ _C_ _DSX _ PRINT: 7/10/2008
EBC13DSXI 价格&库存
很抱歉,暂时无法提供与“EBC13DSXI”相匹配的价格&库存,您可以联系我们找货
