FRM-25JR-52-220R
FRM-25JR-52-220R
    YAGEO(国巨)
    插件,D3.3xL9mm
    插件电阻 - 220Ω ±5% 1/4W -
FRM-25JR-52-220R 数据手册
NOTICE Ref Nr: LR-20161228 Date: 2016.12.28 TO: All customers FROM: Leaded-R Quality Assurance Dept. HEREWITH YOU ARE INFORMED OF BELOW. DESCRIPTION: 1. 因原材料供貨因素,FRM 系列已不再生產,全面改用特性規格更高階之FKN系列。 FRM series is phased out due to raw material discontinued, alternative one is FKN series with superior characteristics. 2. 生效日期:自2017年7月1日起生效。 Effective date: from Jul.1, 2017. 3. FRM & FKN 比較 Comparison table of FRM and FKN: Series FRM Fusible Metal Film Resistors FKN Fusible Wirewound Resistors Power Range 1/4W~3W 1/4W~7W Function Safety function to protect circuit board Resistance Element Comparison FKN is with wider power range Safety function to protect circuit board Same funtion Metal Film Alloy Wire TCR ±200 ppm /℃ ±300 ppm /℃ (Standard, low T.C.R is on request) Different technics FKN is flexible for customized requirment Resistance Range 1Ω~560Ω 0.1Ω~1KΩ FKN Series is with wider resistance range Fusing Characteristics 1Ω≦R≦2.0Ω Fusing time within 30 seconds at 25 times of rated power R≧2.2Ω Fusing time within 30 seconds at 16 times of rated power Surge Voltage Low High (on request) FKN is capabile to withstand higher surge voltage at the same conditions. Detail as comparison table Load Life Common Excellent FKN performs better in Load Life stability. R≤2.0 Ω Fusing time within 60 seconds FRM cut off with shorter time at the same at 36 times of rated power; R>2.0 Ω Fusing time within 60 seconds at conditions. See attached table 25 times of rated power; Fusing Time and Surge withstanding Voltage difference at the same conditions. Yageo PN Power / Value Fusing Test Method Appraise Fusing Voltage current Fusing time surge Voltage FRM3WSJT-73-1R 3W / 1R 25 times of rated power within 30s 8.66V 8.66A 2.5s~4.7s 400V FKN3WSJT-73-1R 3W / 1R 25 times of rated power within 60s 8.66V 8.66A 21s~24s 1KV FRM3WSJT-73-22R 3W / 22R 25 times of rated power within 30s 40.6V 1.85A 0.7s~1.5s 500V FKN3WSJT-73-22R 3W / 22R 25 times of rated power within 60s 40.6V 1.85A 12s~15s 1.5KV NOTICE SUGGESTION FOR ALTERNATIVE PRODUCTS: Not applicable Quality Manager Signature: Product Manager Nane. Zhou. Date: Sep.22,2016 Dec. 28, 2016 Sales Manager Signature: Flora Shen Signature: Ken Hsu Date: Dec. 28, 2016 Date: Dec. 28, 2016 FOR MORE INFORMATION, CONTACT: Flora Shen e-mail: flora.shen@yageo.com RETURN YOUR COMMENTS BEFORE: Jan.31, 2017 Remarks: Comments Date: Dec. 28, 2016 Function: Marketing Signature: Ken Hsu
FRM-25JR-52-220R
1. 物料型号:FRM系列因原材料供应问题已停产,推荐使用性能更优的FKN系列作为替代。 2. 器件简介:FRM和FKN系列都是用于保护电路板的安全功能电阻器。 3. 引脚分配:文档中未明确提及引脚分配信息。 4. 参数特性: - FKN系列具有更宽的功率范围(1/4W-7W)。 - FKN系列的电阻元件为合金线,而FRM系列为金属膜。 - FKN系列的标准温度系数(TCR)为±300ppm/°C,FRM系列为±200ppm/°C,FKN可定制更低的TCR。 - FKN系列的电阻范围更广(0.1Ω-1KΩ)。 - FKN系列的熔断特性和浪涌电压承受能力更强。 - FKN系列在负载寿命稳定性方面表现更优。 5. 功能详解:FRM和FKN系列具有相同的安全功能,但FKN系列在某些特性上更为灵活和优越。 6. 应用信息:文档中未明确提及具体的应用场景。 7. 封装信息:文档中未提供封装信息
FRM-25JR-52-220R 价格&库存
很抱歉,暂时无法提供与“FRM-25JR-52-220R”相匹配的价格&库存,您可以联系我们找货
