ECC13DKSN-S1354
ECC13DKSN-S1354
    SULLINS
    CONNEDGEDUALFMALE26POS0.100
ECC13DKSN-S1354 数据手册
Sullins Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height Dip Solder/Wire Wrap/Right Angle/Card Extender SPECIFICATIONS Sullins Card Edge • Accommodates .062” ± .008” [1.57 ± .20] PC board (For .093” ±.008” [2.36 ± .20] PCB see page 50-51, 52-53; for .125” ±.008” [3.18 ± .20] PCB see page 50-51) • PBT, PPS or PA9T insulator • Molded-in key available • 3 amp current rating per contact • 30 milli ohm maximum at rated current • UL Flammability Rating: 94V-0 READOUT POLARIZING KEY PLC-K1 .038 [0.97] .285 [7.24] EVEN NUMBER SIDE DUAL (D) .100[2.54] KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) HALF LOADED (H) TERMINATION TYPE HAIRPIN BELLOWS TERMINATION TYPE CW CT CS CM CA CB CC DIP SOLDER DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE LOOP BELLOWS TERMINATION TYPE TK,CK RS RM TA TB TM DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE POST CROSS POST LENGTH SECTION L K .025 [.64] .015 x .025 [.38 x .64] .125 [3.18] .015 x .025 [.38 x .64] .170 [4.32] .025 [.64] SQUARE .160 [4.06] .025 [.64] SQUARE .560 [ 14.20] .025 [.64] SQUARE .100 [2.54] .025 [.64] SQUARE .180 [4.57] .025 [.64] SQUARE .250 [6.35] FITS MIN. HOLE SIZE .035 .035 .040 .040 .043 .043 .043 [0.89] [0.89] [1.02] [1.02] [1.09] [1.09] [1.09] RIGHT ANGLE HAIRPIN BELLOWS K L .200[5.08] L .275 [6.98] ODD NUMBER SIDE K (CW, CT, CS, CM) .150[3.81] (CA, CB, CC, TA, TB, TM, KA, KE, KU, KJ) HAIRPIN or LOOP CARD EXTENDER POST CROSS SECTION K .025 [0.64] ROUND .025 [.64] SQUARE .025 [.64] SQUARE .025 [.64] SQUARE .025 [.64] SQUARE .025 [.64] SQUARE POST LENGTH FITS MIN. L HOLE SIZE .025 [.64] .190 [4.83] .033 [0.84] .190 [4.83] .040 [1.02] .560 [14.20] .040 [1.02 .100 [2.54] .043 [1.09] .180 [4.57] .043 [1.09] .250 [6.35] .043 [1.09] POST CROSS POST LENGTH FITS MIN. SECTION L HOLE SIZE K .025 [.64] KS DIP SOLDER .025 [.64] SQUARE .190 [4.83] .040 [1.02] KD DIP SOLDER .025 [.64] SQUARE .160 [4.06] .043 [1.09] KM WIRE WRAP .025 [.64] SQUARE .560 [14.20] .040 [1.02] *KA RIGHT ANGLE .025 [.64] SQUARE .100 [2.54] .043 [1.09] *KE RIGHT ANGLE .025 [.64] SQUARE .180 [4.57] .043 [1.09] *KU RIGHT ANGLE .025 [.64] SQUARE .250 [6.35] .043 [1.09] *KJ RIGHT ANGLE .025 [.64] SQUARE .500 [12.70] .043 [1.09] *KR CARD EXTENDER .025 [.64] SQUARE .235 [5.97] N/A *KN CARD EXTENDER .025 [.64] SQUARE .605 [15.37] N/A * KA, KE, KJ, KR, KN have no standoffs, unless requested. CANTILEVER TERMINATION TYPE LOOP BELLOWS L - .015[.038] K K L .200[5.08] (TK, CK, RS, RM) CANTILEVER ACCOMMODATES .062 [1.57] PCB (CW, CT, CS, CM,TK, CK, RS,RM) Example P/N: EBC10DCSN-S288 (Requires -S288 Modification Code) CANTILEVER CARD EXTENDER .550 K L .200[5.08] (KS, KD, KM) K L ACCOMMODATES .062 [1.57] PCB (KR, KN) Example P/N: EBC10DKRN (Omit Modification Code) MOUNTING STYLE Ø.125 [3.18] #4-40 .250 [6.35] CLEARANCE HOLE (H) 48 Ø.125 [3.18] .245 [6.22] THREADED INSERT(I) SIDE MOUNTING (S) Ø.125 [3.18] #4-40 D = .250 [6.35] W = .430 [10.92] NO MOUNTING EARS (N) FLUSH MOUNTING (D, W) T = .250 [6.35] X = .430 [10.92] FLUSH MOUNTING WITH THREADED INSERT(T, X) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Sullins Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height Dip Solder/Wire Wrap/Right Angle/Card Extender PART NUMBER OPTIONS E B C 70 D CM H - Sxxx MATERIALS (Insulator/Contact) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult Factory for Other Materials) CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate = = = = S = M = E = Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface .000010” Gold .000030” Gold .000100” Pure Tin, Matte OMIT FORT STANDARD -S189 = .200”[5.08mm] Row to Row on Right Angle -S288* = Card Extender Accepts .062”[1.57] PCB * Not Required on KR or KN Terminations MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts S = Side Mounting N = No Mounting D, W = Flush Mounting T, X = Flush Mounting With Threaded Inserts TERMINATION TYPE (Opposite Page) Hairpin Bellows - Available with B or C plating and Phosphor Bronze Only CS = .025” [.64mm] Square Dip Solder CM = .025 [.64mm] Square Wire Wrap CA, CB, CC = .025” [.64mm] Square Right Angle CW, CT = .015” x .025” [.38 x .64] Dip Solder Loop Bellows RS = .025” [0.64mm] Square Dip Solder CK, TK = .025” [0.64mm] Round Dip Solder RM = .025” [0.64mm] Square Wire Wrap TA, TB, TM = .025” [.64mm] Square Right Angle Cantilever Bellows - Available in Y, B, or C plating Only Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte CONTACT CENTERS C = .100” [2.54mm] NUMBER OF CONTACT POSITIONS See Chart Below Sullins Card Edge B C G Y MODIFICATION CODE (Consult Factory) Not Available with R or A Materials KS, KD KM KA, KE, KU, KJ KR, KN READOUT (Opposite Page) D = Dual H = Half Loaded = = = = .025” [.64mm] Square Dip Solder .025 [.64mm] Square Wire Wrap .025” [.64mm] Square Right Angle .025” [.64mm] Square Card Extender DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .297 [7.54] INSERTION DEPTH C REFER TO MOUNTING STYLE .250 [6.35] A B D E CONTACT MARKINGS 1 3 5 . . . 137 139 2 4 6 . . . 138 140 .370 [9.40] .180[4.57] .060 [1.52] .610 [15.49] .100[2.54] TYP. F .313 [7.95] 1 3 5 7 9 131 133 135137 139 2 4 6 8 10 132 134 136 138 140 REFER TO TERMINATION TYPE Tolerances with PPS Insulator Material may vary slightly due to shrinkage differential; Consult Factory. POSITIONS/ INCHES [MILLIMETERS] A±.008 B±.008 C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 CONTACTS 06/12 0.500 0.700 0.860 1.175 1.435 0.750 12.70 17.78 21.84 29.85 36.45 19.05 07/14* 0.600 0.800 0.960 1.275 1.535 0.850 15.24 20.32 24.38 32.39 38.99 21.59 08/16 0.700 0.900 1.060 1.375 1.635 0.950 17.78 22.86 26.92 34.93 41.53 24.13 10/20 0.900 1.100 1.260 1.575 1.835 1.150 22.86 27.94 32.00 40.01 46.61 29.21 12/24 1.100 1.300 1.460 1.775 2.035 1.350 27.94 33.02 37.08 45.09 51.69 34.29 13/26 1.200 1.400 1.560 1.875 2.135 1.450 30.48 35.56 39.62 47.63 54.23 36.83 15/30 1.400 1.600 1.760 2.075 2.335 1.650 35.56 40.64 44.70 52.71 59.31 41.91 17/34 1.600 1.800 1.960 2.275 2.535 1.850 40.64 45.72 49.78 57.79 64.39 46.99 18/36 1.700 1.900 2.060 2.375 2.635 1.950 43.18 48.26 52.32 60.33 66.93 49.53 20/40 1.900 2.100 2.260 2.575 2.835 2.150 48.26 53.34 57.40 65.41 72.01 54.61 22/44 2.100 2.300 2.460 2.775 3.035 2.350 53.34 58.42 62.48 70.49 77.09 59.69 24/48 2.300 2.500 2.660 2.975 3.235 2.550 58.42 63.50 67.56 75.57 82.17 64.77 25/50 2.400 2.600 2.760 3.075 3.335 2.650 60.96 66.04 70.10 78.11 84.71 67.31 28/56 2.700 2.900 3.060 3.375 3.635 2.950 68.58 73.66 77.72 85.73 92.33 74.93 30/60 2.900 3.100 3.260 3.575 3.835 3.150 73.66 78.74 82.80 90.81 97.41 80.01 31/62 3.000 3.200 3.360 3.675 3.935 3.250 76.20 81.28 85.34 93.35 99.95 82.55 35/70 3.400 3.600 3.760 4.075 4.335 3.650 86.36 91.44 95.50 103.51 110.11 92.71 36/72 3.500 3.700 3.860 4.175 4.435 3.750 88.90 93.98 98.04 106.05 112.65 95.25 40/80 3.900 4.100 4.260 4.575 4.835 4.150 99.06 104.14 108.20 116.21 122.81 105.41 43/86 4.200 4.400 4.560 4.875 5.135 4.450 106.68 111.76 115.82 123.83 130.43 113.03 44/88 4.300 4.500 4.660 4.975 5.235 4.550 109.22 114.30 118.36 126.37 132.97 115.57 49/98* 4.800 5.000 5.160 5.475 5.735 5.050 121.92 127.00 131.06 139.07 145.67 128.27 50/100 4.900 5.100 5.260 5.575 5.835 5.150 124.46 129.54 133.60 141.61 148.21 130.81 55/110 5.400 5.600 5.760 6.075 6.335 5.650 137.16 142.24 146.30 154.31 160.91 143.51 60/120 5.900 6.100 6.260 6.575 6.835 6.150 149.86 154.94 159.00 167.01 173.61 156.21 61/122 6.000 6.200 6.360 6.675 6.935 6.250 152.40 157.48 161.54 169.55 176.15 158.75 65/130 6.400 6.600 6.760 7.075 7.335 6.650 162.56 167.64 171.70 179.71 186.31 168.91 70/140 6.900 7.100 7.260 7.575 7.835 7.150 175.26 180.34 184.40 192.41 199.01 181.61 80/160* 7.900 8.100 8.260 8.575 8.835 8.150 200.66 205.74 209.80 217.81 224.41 207.01 90/180* 8.900 9.100 9.260 9.575 9.835 9.150 226.06 231.14 235.20 243.21 249.81 232.41 100/200* 9.900 10.100 10.260 10.575 10.835 10.150 251.46 256.54 260.60 268.61 275.21 257.81 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 49
ECC13DKSN-S1354 价格&库存
很抱歉,暂时无法提供与“ECC13DKSN-S1354”相匹配的价格&库存,您可以联系我们找货
