GBE05DHRD
GBE05DHRD
    SULLINS
    CONN CARD EXTEND 10POS 1MM SLD
GBE05DHRD 数据手册
High Density Card Edge 1.00 mm [.039”] Contact Centers, 15.49 mm [.610”] Insulator Height, Dip Solder/Card Extender/SMT SPECIFICATIONS High Density Card Edge • • • • • • READOUT Accommodates 1.57 mm ± 0.20 mm [.062” ± .008”] PC board PPS or PA9T insulator Molded-in key available 1 Amp current rating per contact for contacts fully energized Highly reliable high cycle hairpin bellow contacts UL Flammability Rating: 94V-0 DUAL (D) TERMINATION TYPE 4.06[.160”] 3.18[.125”] 2.54 ± 0.64 [.100” ± .025”] ACCOMMODATES 1.57[.062”] PCB 3X 2.00[.079”] CARD EXTENDER (HR) STAGGERED DIP SOLDER (HH) SURFACE MOUNT (HF) PCB LAYOUT D F PIN 1 D F PIN A1 PIN A2 Ø 0.76[.030”] MIN. 2X Ø 3.18[.125”] FOR 'D' OR 'T' MOUNTING A PIN B1 PIN B2 A 1.00[.039”] TYP. 0.76[.030”] 3X 2.00 [.079”] 2X Ø 2.44[.096”] FOR 'R' MOUNTING 8.00[.315”] 1.57 [.062”] PCB 3.81 [.150”] 2X Ø 2.44 [.096”] FOR 'R' MOUNTING 2X Ø 3.18[.125”] FOR 'D' AND 'T' MOUNTING 1.00[.039”] TYP. CARD EXTENDER (HR) STAGGERED DIP SOLDER (HH) A 5.08 [.200”] 1.00 [.039”] TYP. 0.76 [.030”] MAX. SURFACE MOUNT (HF) MOUNTING STYLE 9.14 [.360”] #4-40 Ø 3.18[.125”] 3.40[.134”] 0.64[.025”] BOARD LOCK (R) (with no mounting ears) 8 6.35[.250”] NO MOUNTING EARS (N) FLUSH MOUNTING (D) 1.57 [.062”] 8.08 [.318”] 3.25 [.128”] 6.35[.250”] THREADED INSERT (T) 4.77 [.188”] 11.18 [.440”] Ø 1.98 [.078”] STRADDLE MOUNT (Q) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com High Density Card Edge 1.00 mm [.039”] Contact Centers, 15.49 mm [.610”] Insulator Height, Dip Solder/Card Extender/SMT PART NUMBER OPTIONS G B E 50 D HH D - Sxxx CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface B = .000010” Gold C = .000030” Gold Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte CONTACT CENTERS E = 1.00 mm [.039”] DIMENSIONS Dimensions in [ ] are in inches, all others are in millimeters. 7.62 [.300] INSERTION DEPTH (D) MOUNTING SHOWN 2X Ø 3.18 [.125] PIN A1 PIN A2 FIRST POSITION INDICATOR High Density Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD MOUNTING STYLE (Opposite Page) D = Flush Mounting N = No Mounting R = Metal Board Locks (HH & HF Termination Only) T = Flush Mounting, #4-40 Threaded Insert Q = Straddle Mount (HR Termination Only)* TERMINATION TYPE (Opposite Page) HH = Staggered Dip Solder HR = Card Extender HF = Surface Mount READOUT (Opposite Page) D = Dual NUMBER OF CONTACT POSITIONS See Chart Below MATERIALS (INSULATOR/CONTACT) G = PA9T/Phosphor Bronze R = PPS/Phosphor Bronze J = PA9T/Beryllium Copper A = PPS/Beryllium Copper Refer to Page 7 for Operating/Processing Temperatures C 6.35[.250] 15.49[.610] 9.40 [.370] A B D E PIN B1 PIN B2 POSITIONS/ CONTACTS A±0.13 02/04* 03/06* 04/08* 05/10 06/12* 07/14* 08/16* 09/18* 10/20 11/22* 12/24 13/26* 14/28* 15/30 16/32 17/34* 18/36* 19/38* 20/40 21/42* 22/44* 23/46* 24/48* 25/50 26/52* 27/54* 28/56* 29/58* 30/60 31/62* 32/64* 33/66* 34/68* 35/70 36/72* 37/74* 38/76* 39/78* 40/80 41/82* 42/84* 43/86* 44/88* 45/90 46/92* 47/94* 48/96* 49/98* 50/100 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 9.00 10.00 11.00 12.00 13.00 14.00 15.00 16.00 17.00 18.00 19.00 20.00 21.00 22.00 23.00 24.00 25.00 26.00 27.00 28.00 29.00 30.00 31.00 32.00 33.00 34.00 35.00 36.00 37.00 38.00 39.00 40.00 41.00 42.00 43.00 44.00 45.00 46.00 47.00 48.00 49.00 1.52 [.060] 1.00[.039] TYP. 0.46 X 0.30 [.018 X .012] POST REFER TO TERMINATION MILLIMETERS INCHES B±0.13 C±0.38 D±0.25 E±0.51 F±0.25 A±.005 B±.005 C±.015 D±.010 E±.020 F±.010 4.32 5.32 6.32 7.32 8.32 9.32 10.32 11.32 12.32 13.32 14.32 15.32 16.32 17.32 18.32 19.32 20.32 21.32 22.32 23.32 24.32 25.32 26.32 27.32 28.32 29.32 30.32 31.32 32.32 33.32 34.32 35.32 36.32 37.32 38.32 39.32 40.32 41.32 42.32 43.32 44.32 45.32 46.32 47.32 48.32 49.32 50.32 51.32 52.32 9.89 10.89 11.89 12.89 13.89 14.89 15.89 16.89 17.89 18.89 19.89 20.89 21.89 22.89 23.89 24.89 25.89 26.89 27.89 28.89 29.89 30.89 31.89 32.89 33.89 34.89 35.89 36.89 37.89 38.89 39.89 40.89 41.89 42.89 43.89 44.89 45.89 46.89 47.89 48.89 49.89 50.89 51.89 52.89 53.89 54.89 55.89 56.89 57.89 17.15 18.15 19.15 20.15 21.15 22.15 23.15 24.15 25.15 26.15 27.15 28.15 29.15 30.15 31.15 32.15 33.15 34.15 35.15 36.15 37.15 38.15 39.15 40.15 41.15 42.15 43.15 44.15 45.15 46.15 47.15 48.15 49.15 50.15 51.15 52.15 53.15 54.15 55.15 56.15 57.15 58.15 59.15 60.15 61.15 62.15 63.15 64.15 65.15 25.13 26.13 27.13 28.13 29.13 30.13 31.13 32.13 33.13 34.13 35.13 36.13 37.13 38.13 39.13 40.13 41.13 42.13 43.13 44.13 45.13 46.13 47.13 48.13 49.13 50.13 51.13 52.13 53.13 54.13 55.13 56.13 57.13 58.13 59.13 60.13 61.13 62.13 63.13 64.13 65.13 66.13 67.13 68.13 69.13 70.13 71.13 72.13 73.13 4.66 5.66 6.66 7.66 8.66 9.66 10.66 11.66 12.66 13.66 14.66 15.66 16.66 17.66 18.66 19.66 20.66 21.66 22.66 23.66 24.66 25.66 26.66 27.66 28.66 29.66 30.66 31.66 32.66 33.66 34.66 35.66 36.66 37.66 38.66 39.66 40.66 41.66 42.66 43.66 44.66 45.66 46.66 47.66 48.66 49.66 50.66 51.66 52.66 0.039 0.079 0.118 0.157 0.197 0.236 0.276 0.315 0.354 0.394 0.433 0.472 0.512 0.551 0.591 0.630 0.669 0.709 0.748 0.787 0.827 0.866 0.906 0.945 0.984 1.024 1.063 1.102 1.142 1.181 1.220 1.260 1.299 1.339 1.378 1.417 1.457 1.496 1.535 1.575 1.614 1.654 1.693 1.732 1.772 1.811 1.850 1.890 1.929 0.170 0.210 0.249 0.288 0.328 0.367 0.407 0.446 0.485 0.525 0.564 0.603 0.643 0.682 0.722 0.761 0.800 0.840 0.879 0.918 0.958 0.997 1.037 1.076 1.115 1.155 1.194 1.233 1.273 1.312 1.351 1.391 1.430 1.470 1.509 1.548 1.588 1.627 1.666 1.706 1.745 1.785 1.824 1.863 1.903 1.942 1.981 2.021 2.060 0.389 0.429 0.468 0.507 0.547 0.586 0.626 0.665 0.704 0.744 0.783 0.822 0.862 0.901 0.941 0.980 1.019 1.059 1.098 1.137 1.177 1.216 1.256 1.295 1.334 1.374 1.413 1.452 1.492 1.531 1.570 1.610 1.649 1.689 1.728 1.767 1.807 1.846 1.885 1.925 1.964 2.004 2.043 2.082 2.122 2.161 2.200 2.240 2.279 0.675 0.715 0.754 0.793 0.833 0.872 0.912 0.951 0.990 1.030 1.069 1.108 1.148 1.187 1.227 1.266 1.305 1.345 1.384 1.423 1.463 1.502 1.542 1.581 1.620 1.660 1.699 1.738 1.778 1.817 1.856 1.896 1.935 1.975 2.014 2.053 2.093 2.132 2.171 2.211 2.250 2.290 2.329 2.368 2.408 2.447 2.486 2.526 2.565 0.989 1.029 1.068 1.107 1.147 1.186 1.226 1.265 1.304 1.344 1.383 1.422 1.462 1.501 1.541 1.580 1.619 1.659 1.698 1.737 1.777 1.816 1.856 1.895 1.934 1.974 2.013 2.052 2.092 2.131 2.170 2.210 2.249 2.289 2.328 2.367 2.407 2.446 2.485 2.525 2.564 2.604 2.643 2.682 2.722 2.761 2.800 2.840 2.879 0.183 0.223 0.262 0.301 0.341 0.380 0.420 0.459 0.498 0.538 0.577 0.616 0.656 0.695 0.735 0.774 0.813 0.853 0.892 0.931 0.971 1.010 1.050 1.089 1.128 1.168 1.207 1.246 1.286 1.325 1.364 1.404 1.443 1.483 1.522 1.561 1.601 1.640 1.679 1.719 1.758 1.798 1.837 1.876 1.916 1.955 1.994 2.034 2.073 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 9
GBE05DHRD
物料型号:文档中没有明确指出具体的物料型号,但提供了多种型号选项,如"D - Sxxx"。
器件简介:高密度卡边连接器,具有1.00mm的接触中心间距和15.49mm的绝缘体高度,支持DIP焊接、卡扩展和SMT。
引脚分配:文档提供了详细的引脚分配图和尺寸,包括PIN 1的位置和不同安装方式的引脚布局。
参数特性:包括1A的电流额定值、高可靠性的高循环发夹弹簧接触、UL阻燃等级94V-0等。
功能详解:文档详细描述了不同终止类型(如HH-交错DIP焊接、HR-卡扩展、HF-表面贴装)的安装方式和特点。
应用信息:适用于需要高密度连接的应用,如PCB板与连接器的连接。
封装信息:提供了多种封装选项,包括材料(如PPS或PA9T绝缘体)、安装风格(如金属板锁、无安装耳等)和接触表面处理。
GBE05DHRD 价格&库存
很抱歉,暂时无法提供与“GBE05DHRD”相匹配的价格&库存,您可以联系我们找货
