GCE82DHFN-T951
GCE82DHFN-T951
    SULLINS
    CONNPCIEXPFEMALE164POS0.039
GCE82DHFN-T951 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO B 2069 C BY LH F LH +0.20 +.008 B - 0.15 , - .006 1.73±0.08 .068±.003 A 0.15[.006] 11.65±0.25 .459±.010 E 2740 DESCRIPTION DATE ADD I/O PANEL SECONDARY SIDE VIEW AND TABLE"G", UPDATE DRAWING AND TABLE OF 05/17/2010 TOLERANCE ADD CAP ON PARTS AND UPDATE SHAPE, 3 - VIEWS & NOTES, CARD SLOT WIDE 1.80mm(WAS 1.77mm) & 1.73mm(WAS 1.78mm, BETWEEN BOTH CARD 04/18/2013 SLOT THICKNESS), CANCEL DIMENSION TABLE TOLERANCES, SHOW ON THE TOP VIEW. E 1.00 .039 TYP. 10.00±0.15 .394±.006 CL PIN A1 15.00 .591 7.45 .293 8.95 .352 PIN B1 1.50 .059 1.80±0.15 .071±.006 D 11.00 .433 5.93 .233 7.00 .276 1.50 .059 A 14.50 .571 0.90 .035 D 6.80 .268 7.62 .300 11.90 .469 10.90 .429 0.10[.004] 4.10 .161 C 1.35 .053 0.34 .013 1.65 .065 SECTION A-A 1.00 .039 A 2X 1.00±0.10 .039±.004 8.65 .341 C C 3.50 .138 B NOTES: 1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK. D 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. E 4. CURRENT RATING: 1.1 AMP PER CONTACT. 5. VOLTAGE RATING: 50 VAC. 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 30 MILLI OHMS MAX. 8. DIELECTRIC WITHSTANDING: 500V AC. 9. OPERATING TEMPERATURE:-10 C TO +85 C. 10. PROCESSING TEMP.: 260° C FOR 10 SECS MAX. 11. INSERTION FORCE: 117gf (1.15 N) MAX PER CONTACT PAIR USING A 1.70 mm (.067") STEEL CARD. 12. WITHDRAWAL FORCE: 15gf (0.15 N) MIN PER CONTACT PAIR USING A 1.44 mm (.057") STEEL CARD. B DRAWN Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] NAME 02/05/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TOLERANCES: ANGULAR: DATE 3' DECIMALS .X= 0.35 [.014] .XX= 0.25 [.010] .XXX= 0.08 [.0031] TITLE PART NUMBER SIZE C 3 A PCI EXPRESS, 1mm CC, SMT G_E_ _DHFN-T951 CAGE CODE 54453 DWG. NO. 11205 SCALE: 3:1 SHEET 1 OF 2 2 1 REV C FILE NAME: Z:\ECO PENDING\2740, PCI E -- REMOVE NYLON 46, DWG 11205, 11045, 11042, 11043, 11044\11205-C\11205, G_E_ _DHFN-T951 PRINT: 10/31/2013 8 7 4 5 6 1 2 3 1.80 .071 A 2X 4.50 .177 F 9.20 .362 PIN A1 1.20±0.05 .047±.002 F 1.00 .039 TYP. 4.60 .181 CL 5.20 .205 1.65 .065 2.00 .079 E 2X 10.00 .394 5.00 .197 0.70±0.05 .028±.002 E 1.35 .053 3.00 .118 D H RECOMMENDED PCB LAYOUT D D 1.90±0.05 .075±.002 1.50 .059 1.50 .059 PIN A1 1.00 .039 3.20 .126 0.70±0.05 .028±.002 TYP PIN B1 3.20 .126 C 8.40 .331 5.60 .220 C 2.40 .094 10.00 .394 PIN "G" SEE TABLE A 12.15±0.10 .478±.004 2.40 .094 F B 20.0°±5° I/O PANEL DIRECTION . SECONDARY (SOLDER) SIDE B I/O PANEL DIRECTION . PRIMARY (COMPONENT) SIDE 1.40 .055 1.57±0.13 .062±.005 DETAIL A SCALE 10 : 1 Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 3' DECIMALS .X= 0.35 [.014] .XX= 0.25 [.010] .XXX= 0.08 [.0031] DRAWN DATE NAME 02/05/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PCI EXPRESS, 1mm CC, SMT PART NUMBER SIZE C CAGE CODE 54453 SCALE: 1:5 3 2 A G_E_ _DHFN-T951 DWG. NO. 11205 SHEET 2 OF 2 1 REV C FILE NAME: 11205, G_E_ _DHFN-T951
GCE82DHFN-T951 价格&库存
很抱歉,暂时无法提供与“GCE82DHFN-T951”相匹配的价格&库存,您可以联系我们找货
