ESM08DTAT-S664
ESM08DTAT-S664
    SULLINS
    CONN EDGECARD 16POS R/A .156 SLD
ESM08DTAT-S664 数据手册
Female Card Edge .156” [3.96 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle for .093”[2.36 mm] or .125”[3.18 mm] Mating PCB SPECIFICATIONS • Accommodates .093” ± .008” [2.36 mm ± 0.20 mm] or .125” ± .008” [3.18 mm ± 0.20 mm] mating PCB (Consult factory for .031” ± .006” [0.79 mm ± 0.15 mm] PC boards) • PBT, PPS or PA9T insulator • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 Female Card Edge READOUT DUAL (D) TERMINATION TYPE L TERMINATION TYPE .030” [0.76] .150” [3.81] L .250” [6.35] K LOOP BELLOWS (RS, RM) RIGHT ANGLE DIP SOLDER (TA, TB, TM) POST CROSS SECTION (K) POST LENGTH L ± .025ʺ [0.64] FITS MIN. HOLE SIZE RS Dip Solder .025ʺ [0.64] SQUARE .190ʺ [4.83] .040ʺ [1.02] RM Wire Wrap .025ʺ [0.64] SQUARE .560ʺ [14.20] .040ʺ [1.02] TA Right Angle .025ʺ [0.64] SQUARE .100ʺ [2.54] .043ʺ [1.09] TB Right Angle .025ʺ [0.64] SQUARE .180ʺ [4.57] .043ʺ [1.09] TM Right Angle .025ʺ [0.64] SQUARE .250ʺ [6.35] .043ʺ [1.09] PCB LAYOUT COMPONENT SIDE .156” [3.96] TYP. Ø .040” [1.02] .250” [6.35] 2X Ø .125” [3.18] A .156” [3.96] TYP. Ø .043” [1.09] .150” [3.81] 2X Ø .125” [3.18] .095” [2.41] A D D STRAIGHT PIN TERMINATIONS (RS, RM) RIGHT ANGLE TERMINATIONS (TA, TB, TM) MOUNTING STYLE #4-40 Ø.125” [3.18] .250” [6.35] .250” [6.35] FLUSH MOUNTING (D) 76 NO MOUNTING EARS (N) FLUSH MOUNTING WITH THREADED INSERT (T) Ø.125” [3.18] .250” [6.35] FLUSH MOUNTING WITH SIDE HOLES (Z) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .156” [3.96 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle for .093” [2.36 mm] or .125” [3.18 mm] Mating PCB PART NUMBER OPTIONS E B M 43 D RM D - S273 MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/ Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures MODIFICATION CODE (Consult Factory) -S273 = FOR .093” ± .008” [2.36 mm ± 0.20 mm] THICK MATING PCB -S664 = FOR .125” ± .008” [3.18 mm ± 0.20 mm] THICK MATING PCB MOUNTING STYLE (Opposite Page) N = No Mounting D = Flush Mounting T = Flush Mounting With Threaded Inserts Z = Flush Mounting With Side Holes CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate = = = = Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte TERMINATION TYPE (Opposite Page) RS = .025” [0.64 mm] Square Dip Solder RM = .025” [0.64 mm] Square Wire Wrap TA, TB, TM = .025” [0.64 mm] Square Right Angle READOUT (Opposite Page) D = Dual Female Card Edge Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte CONTACT CENTERS M = .156” [3.96 mm] B C G Y NUMBER OF CONTACT POSITIONS See Chart Below DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .297 [7.54] INSERTION DEPTH C REFER TO MOUNTING STYLE .360 [9.14] .470 [11.94] .610 [15.49] A B D E .060 [1.52] REFER TO TERMINATION TYPE, SEE OPPOSITE PAGE .156 [3.96] TYP. F Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS A±.008 INCHES MILLIMETERS B±.008 C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 06/12 0.780 1.102 1.221 1.534 1.784 1.104 19.81 27.99 31.01 38.96 45.31 28.04 08/16* 1.092 1.414 1.533 1.846 2.096 1.416 27.74 35.92 38.94 46.89 53.24 35.97 10/20 1.404 1.726 1.845 2.158 2.408 1.728 35.66 43.84 46.86 54.81 61.16 43.89 12/24 1.716 2.038 2.157 2.470 2.720 2.040 43.59 51.77 54.79 62.74 69.09 51.82 15/30 2.184 2.506 2.625 2.938 3.188 2.508 55.47 63.65 66.68 74.63 80.98 63.70 18/36 2.652 2.974 3.093 3.406 3.656 2.976 67.36 75.54 78.56 86.51 92.86 75.59 20/40 2.964 3.286 3.405 3.718 3.968 3.288 75.29 83.46 86.49 94.44 100.79 83.52 22/44 3.276 3.598 3.717 4.030 4.280 3.600 83.21 91.39 94.41 102.36 108.71 91.44 24/48* 3.588 3.910 4.029 4.342 4.592 3.912 91.14 99.31 102.34 110.29 116.64 99.37 25/50* 3.744 4.066 4.185 4.498 4.748 4.068 95.10 103.28 106.30 114.25 120.60 103.33 28/56* 4.212 4.534 4.653 4.966 5.216 4.536 106.98 115.16 118.19 126.14 132.49 115.21 30/60* 4.524 4.846 4.965 5.278 5.528 4.848 114.91 123.09 126.11 134.06 140.41 123.14 31/62* 4.680 5.002 5.121 5.434 5.684 5.004 118.87 127.05 130.07 138.02 144.37 127.10 32/64 4.836 5.158 5.277 5.590 5.840 5.160 122.83 131.01 134.04 141.99 148.34 131.06 36/72 5.460 5.782 5.901 6.214 6.464 5.784 138.68 146.86 149.89 157.84 164.19 146.91 40/80* 6.084 6.406 6.525 6.838 7.088 6.408 154.53 162.71 165.74 173.69 180.04 162.76 43/86* 6.552 6.874 6.993 7.306 7.556 6.876 166.42 174.60 177.62 185.57 191.92 174.65 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 77
ESM08DTAT-S664
物料型号:SULLINS
器件简介:Female Card Edge连接器,具有.156” [3.96 mm]接触中心,.610” [15.49 mm]绝缘体高度,适用于.093” [2.36 mm]或.125” [3.18 mm]配合PCB的Dip Solder/Wire Wrap/Right Angle。
引脚分配:文档中提供了不同终止类型的引脚分配,例如RS(Dip Solder)和RM(Wire Wrap)的引脚分配
参数特性: - 可配合.093” ± .008” [2.36 mm ± 0.20 mm]或.125” ± .008” [3.18 mm ± 0.20 mm]的PCB。 - 绝缘体材料包括PBT, PPS或PA9T。 - 电流额定值为3安培,单个接触点的最大电阻为30毫欧姆。 - UL阻燃等级:94V-0。
功能详解:文档详细描述了不同终止类型的特点,例如Dip Solder、Wire Wrap和Right Angle。
应用信息:适用于需要高密度、高可靠性连接的应用。
封装信息:提供了不同安装风格的详细信息,包括无耳安装、带螺纹插入的平齐安装和带侧孔的平齐安装。
ESM08DTAT-S664 价格&库存
很抱歉,暂时无法提供与“ESM08DTAT-S664”相匹配的价格&库存,您可以联系我们找货
