GRPB022VWQS-M81RC
GRPB022VWQS-M81RC
    SULLINS
    CONN HEADER .050" 4POS DL SMD AU
GRPB022VWQS-M81RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 1837 INITIAL RELEASE 09/06/2010 LH F F PIN 1 E B E .050 1.27 .134 3.40 A D D .236 6.00 .050 1.27 .197 5.00 .016 0.40 .118 3.00 .236 6.00 .079 2.00 .004[0.10] .039 1.00 C C .201 5.10 A .050 1.27 PIN 1 .030 0.76 .087 2.20 .232 5.90 B .059 1.50 NOTES: 1. INSULATOR MATERIAL: NYLON 9T. *PROCESSING TEMPERATURE: 230° C FOR 60 SECONDS MAX. (260° C FOR 10 SECONDS MAX.) 2. CONTACT MATERIAL: BRASS. 3. PLATING: GOLD FLASH OVERALL. 4. OPERATING TEMPERATURE: -40° C TO +105° C. 5. INSULATOR RESISTANCE: 5000 MEGA OHM MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. UL FLAMMABILITY RATING: 94V-0. 9. CURRENT RATING: 1 AMP. A B RECOMMENDED PCB LAYOUT DRAWN Pb 10. MODIFICATION: WITH PICK & PLACE CAP IN TAPE & REEL. *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .004 [.10] RoHS COMPLIANT 6 5 4 30' INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 9/6/2010 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE .050" DUAL ROW MALE HEADER, SMT T&R PART NUMBER SIZE C 54453 SCALE: 8:1 3 2 GRPB_ _2VWQS-M81RC CAGE CODE DWG. NO. 11575 SHEET 1 OF 2 1 REV A FILE NAME: 11575, GRPB_ _2VWQS-M81RC A 8 F 7 4 5 6 1 2 3 F GRPB_ _2VWQS-M81RC NOTE: 1. 10 SPROCKET HOLES PITCH CUMULATIVE TOLERANCE ± 0.20mm. 2. CARRIER CAMBER IS 1mm IN 100mm. 3. A0 AND B0 MEASURED ON A PLANE 0.3mm ABOVE THE BOTTOM OF THE POCKET. 4. K0 MEASURED FROM A PLANE ON THE INSIDE BOTTOM OF THE POCKET TO THE TOP SURFACE OF THE CARRIER. 5. PACKING CONFORMS EIA-481-2 STANDARDS. 6. 13" REEL= 10.5 METER, 800 PIECES. E E 60° 10° P0 D P2 T 2 6.3 K0 P C B0 W 60° 10° F D D E TYP. 2 A0 C T 2.0 81.5±0.2 2.0 A N C B D B G B DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: ANGULAR: .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .004 [.10] RoHS COMPLIANT 8 7 6 5 4 30' INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 9/6/2010 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE .050" DUAL ROW MALE HEADER, SMT T&R PART NUMBER SIZE C 54453 SCALE: 8:1 3 2 GRPB_ _2VWQS-M81RC CAGE CODE DWG. NO. 11575 SHEET 2 OF 2 1 REV A FILE NAME: 11575, GRPB_ _2VWQS-M81RC A
GRPB022VWQS-M81RC 价格&库存
很抱歉,暂时无法提供与“GRPB022VWQS-M81RC”相匹配的价格&库存,您可以联系我们找货
