3110-12-991-11-99
3110-12-991-11-99
    CNC
    CONN IDC HEADER 0.079 12 POS
3110-12-991-11-99 数据手册
CnC Tech Soldering Recommendations for the 3X10 Series Wave Soldering Recommended temperature and time periods for the soldering process Series Soldering method Temperature in the furnace (lead -free) Plastic Furnace time Soldering time 3X10 WAVE soldering 220°C to 230°C PBT 1 to 3 minutes 0.3 to 3 seconds The temperature for wave solder machine needs to be set, and then place the IDC with the board into the wave solder machine. The tin contact temperature is 140°C - 180°C soldered to the IDC pin. There is no standard temperature for the board, because it is only 3 seconds when the tin contact the part, and then the tin attach the product, so 140°C to 230°C degree is allowed. Below is the graph for wave soldering, based on factory self-testing: The yellow line (5) shows the temp/seconds for the bottom board, the purple line (6) for above of board.
3110-12-991-11-99 价格&库存
很抱歉,暂时无法提供与“3110-12-991-11-99”相匹配的价格&库存,您可以联系我们找货
