ECC50DJCN
ECC50DJCN
    SULLINS
    CONN EDGECARD 100PS .100 PRESSFT
ECC50DJCN 数据手册
Press Fit .100” [2.54 mm] Contact Centers, .550” [13.97 mm] or .610” [15.49 mm] Profile, Press Fit SPECIFICATIONS • UL Flammability Rating: 94V-0 • Designed to meet specifications of Bellcore specification TR-TSY-00078. • Flat rock installation eliminates the need for any special installation tool. • Integrally molded scoops available to assist daughter card entry. • Molded-in key available FEATURES COMPLIANT SECTION INSERTION FORCE 40 lbs maximum per contact COMPLIANT SECTION WITHDRAWAL FORCE 10 lbs minimum per contact Press Fit HOLE SIZE REQUIREMENTS Drilled Hole Diameter: .0453” ± .0010” [1.150 mm ± 0.025 mm] Plating: .001” [0.03 mm] to .003” [0.08 mm] Copper and .0003” [0.008 mm] Minimum Tin FINISHED HOLE DIAMETER .040” ± .003” [1.02 mm ± 0.08 mm] SUITABLE FOR .062” [1.57] DAUGHTER CARD RECOMMENDED MOTHERBOARD THICKNESS .093” to .125” [2.36 mm to 3.18 mm] UL-CUL RECOGNIZED DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. ACCEPTS .054 [1.37] TO .071 [1.80] P.C. BOARD OPTIONAL SCOOPS .050 [1.27] .415 [10.54] .150 [3.81] P.C. BOARD .025 [0.64] SQ. ROW SPACING SEE TERMINATION TYPE (Opposite Page) .100 [2.54] REFER TO TERMINATION TYPE (Opposite Page) -S1136 (WITH SCOOPS) SHOWN ABOVE C B A .100 [2.54] TYP. .100 [2.54] 84 .370 [9.40] .550 [13.97] WITHOUT STANDOFFS .078 [1.98] TYP. .610 [15.49] WITH STANDOFFS STANDOFF VIEWS WITH NO SCOOPS SHOWN www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Press Fit .100” [2.54 mm] Contact Centers, .550” [13.97 mm] or .610” [15.49 mm] Profile, Press Fit PART NUMBER OPTIONS E C C 43 D JB N - Sxxx MODIFICATIONS (Consult Factory) OMIT FOR STANDARD Special Number assigned for specials such as: - Scoops (-S1136) - Other Card Slot Depths MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze Refer to Page 7 for Operating/Processing Temperatures CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface C = .000030” Gold Termination .000100” Pure Tin, Matte MOUNTING STYLE N = No Mounting TERMINATION TYPE Standoffs Row Spacing JB = No* .200” [5.08 mm] JC = No* .200” [5.08 mm] JW = Yes .200” [5.08 mm] JX = Yes .200” [5.08 mm] JF = No* .100” [2.54 mm] JG = No* .100” [2.54 mm] JY = Yes .100” [2.54 mm] JZ = Yes .100” [2.54 mm] CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS See Chart Below READOUT D = Dual Tail Length .190” [4.83 mm] .625” [15.88 mm] .190” [4.83 mm] .565” [14.35 mm] .190” [4.83 mm] .625” [15.88 mm] .190” [4.83 mm] .565” [14.35 mm] * Consult factory for availability. POSITIONS/ CONTACTS A±.008[0.20] B±.008[0.20] C±.015[0.38] POSITIONS/ CONTACTS A±.008[0.20] B±.008[0.20] C±.015[0.38] mm in mm in mm in mm in mm in mm 0.400 10.16 0.600 15.24 0.756 19.20 33/66* 3.200 81.28 3.400 86.36 3.556 90.32 06/12 0.500 12.70 0.700 17.78 0.856 21.74 34/68 3.300 83.82 3.500 88.90 3.656 92.86 07/14 0.600 15.24 0.800 20.32 0.956 24.28 35/70 3.400 86.36 3.600 91.44 3.756 95.40 08/16* 0.700 17.78 0.900 22.86 1.056 26.82 36/72 3.500 88.90 3.700 93.98 3.856 97.94 09/18* 0.800 20.32 1.000 25.40 1.156 29.36 37/74* 3.600 91.44 3.800 96.52 3.956 100.48 10/20 0.900 22.86 1.100 27.94 1.256 31.90 38/76* 3.700 93.98 3.900 99.06 4.056 103.02 11/22* 1.000 25.40 1.200 30.48 1.356 34.44 39/78* 3.800 96.52 4.000 101.60 4.156 105.56 12/24 1.100 27.94 1.300 33.02 1.456 36.98 40/80 3.900 99.06 4.100 104.14 4.256 108.10 13/26 1.200 30.48 1.400 35.56 1.556 39.52 41/82* 4.000 101.60 4.200 106.68 4.356 110.64 14/28* 1.300 33.02 1.500 38.10 1.656 42.06 42/84* 4.100 104.14 4.300 109.22 4.456 113.18 15/30 1.400 35.56 1.600 40.64 1.756 44.60 43/86 4.200 106.68 4.400 111.76 4.556 115.72 16/32 1.500 38.10 1.700 43.18 1.856 47.14 44/88 4.300 109.22 4.500 114.30 4.656 118.26 17/34 1.600 40.64 1.800 45.72 1.956 49.68 45/90* 4.400 111.76 4.600 116.84 4.756 120.80 18/36 1.700 43.18 1.900 48.26 2.056 52.22 46/92* 4.500 114.30 4.700 119.38 4.856 123.34 19/38* 1.800 45.72 2.000 50.80 2.156 54.76 47/94* 4.600 116.84 4.800 121.92 4.956 125.88 20/40 1.900 48.26 2.100 53.34 2.256 57.30 48/96* 4.700 119.38 4.900 124.46 5.056 128.42 21/42* 2.000 50.80 2.200 55.88 2.356 59.84 49/98* 4.800 121.92 5.000 127.00 5.156 130.96 22/44 2.100 53.34 2.300 58.42 2.456 62.38 50/100 4.900 124.46 5.100 129.54 5.256 133.50 23/46 2.200 55.88 2.400 60.96 2.556 64.92 51/102* 5.000 127.00 5.200 132.08 5.356 136.04 24/48 2.300 58.42 2.500 63.50 2.656 67.46 52/104* 5.100 129.54 5.300 134.62 5.456 138.58 25/50 2.400 60.96 2.600 66.04 2.756 70.00 53/106* 5.200 132.08 5.400 137.16 5.556 141.12 26/52 2.500 63.50 2.700 68.58 2.856 72.54 54/108* 5.300 134.62 5.500 139.70 5.656 143.66 27/54* 2.600 66.04 2.800 71.12 2.956 75.08 55/110 5.400 137.16 5.600 142.24 5.756 146.20 28/56 2.700 68.58 2.900 73.66 3.056 77.62 56/112* 5.500 139.70 5.700 144.78 5.856 148.74 29/58* 2.800 71.12 3.000 76.20 3.156 80.16 57/114* 5.600 142.24 5.800 147.32 5.956 151.28 30/60 2.900 73.66 3.100 78.74 3.256 82.70 58/116* 5.700 144.78 5.900 149.86 6.056 153.82 31/62 3.000 76.20 3.200 81.28 3.356 85.24 59/118* 5.800 147.32 6.000 152.40 6.156 156.36 32/64* 3.100 78.74 3.300 83.82 3.456 87.78 60/120 5.900 149.86 6.100 154.94 6.256 158.90 Press Fit in 05/10 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 85
ECC50DJCN
1. 物料型号:文档中没有明确列出具体的物料型号,但提到了“E C C 43 D JB N - Sxxx”和“C43 DJB”作为可能的型号选项。
2. 器件简介:Press Fit连接器设计用于符合Bellcore规格TR-TSY-00078,具有UL 94V-0的可燃性等级,安装时不需要特殊工具,且有集成成型的勺形结构帮助子卡进入。
3. 引脚分配:文档中提到了不同的接触中心距离和配置,例如0.100英寸(2.54毫米)接触中心,0.550英寸(13.97毫米)或0.610英寸(15.49毫米)轮廓。
4. 参数特性: - 钻孔直径:0.0453英寸(1.150毫米)±0.0010英寸(0.025毫米) - 电镀:0.001英寸(0.03毫米)至0.003英寸(0.08毫米)铜和0.0003英寸(0.008毫米)最小锡 - 推荐的主板厚度:0.093英寸(2.36毫米)至0.125英寸(3.18毫米)
5. 功能详解: - 插入力:每个接触最大40磅 - 拔出力:每个接触最小10磅
6. 应用信息:适用于0.062英寸(1.57毫米)厚的子卡。
7. 封装信息: - 材料:绝缘体/接触材料为PBT/磷青铜,符合RoHS标准 - 接触表面镀层:无铅,有0.000050英寸镍底层和0.000030英寸金0.000100英寸纯锡,哑光
8. 其他信息:文档还提供了关于安装、尺寸、终止类型和可选配件的详细信息。
ECC50DJCN 价格&库存
很抱歉,暂时无法提供与“ECC50DJCN”相匹配的价格&库存,您可以联系我们找货
