High Density Card Edge
1.00 mm [.039”] Contact Centers, 21.84 mm [.860”] Insulator Height,
Right Angle
SPECIFICATIONS
Sullins High Density
Accommodates 1.57 mm ± 0.20 mm [.062” ± .008”] PC board
PA9T or PPS insulator
Molded-in key available
High reliability/high cycle hairpin bellow contacts
1 Amp current rating per contact for contacts fully energized
150 grams normal force minimum
UL Flammability Rating: 94V-0
READOUT
TERMINATION TYPE
9.40 [.370”]
15.11
[.595”]
3X 2.00 [.079”]
HA = 2.54 ± 0.64
[.100” ± .025”]
HB = 4.32 ± 0.64
[.170” ± .025”]
DUAL (D)
PCB LAYOUT
2.00 [0.079”]
1.00 [0.039”]
3X 2.00 [0.079”]
PIN A1
3.00 [0.118”]
F
A
Ø 1.02 [0.040”]MIN.
2X Ø 2.64 [0.104”]MIN.
FOR 'R' MOUNTING
PIN A2
2X Ø 3.18 [0.125”]
FOR 'S' MOUNTING
2.79 [0.110”]
PIN B1
PIN B2
D
MOUNTING STYLE
Ø 3.18 [.125”]
Ø 3.18 [.125”]
6.35 [.250”]
6.35 [.250”]
#4-40
6.35 [.250”]
4.41 [.174”]
BOARD LOCK (R)
(with no mounting ears)
10
SIDE MOUNTING (S)
NO MOUNTING EARS (N)
CLEARANCE HOLE (D)
THREADED INSERT (T)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Right Angle
PART NUMBER OPTIONS
G B E 50 D HA D - Sxxx
MATERIALS (INSULATOR/CONTACT)
G = PA9T/Phosphor Bronze
R = PPS/Phosphor Bronze
J = PA9T/Beryllium Copper
A = PPS/Beryllium Copper
Refer to Page 7 for Operating/Processing Temperatures
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
B = .000010” Gold
C = .000030” Gold
Termination
.000100” Pure Tin, Matte
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
MOUNTING STYLE (Opposite Page)
D = Flush Mounting
N = No Mounting
R = Metal Board Lock
S = Side Mounting
T = Flush Mounting -Threaded Insert
TERMINATION TYPE (Opposite Page)
HA = 2.54 mm [.100”] Tail Length
CONTACT CENTERS
E = 1 mm [.039”]
NUMBER OF CONTACT POSITIONS
See Chart Below
HB = 4.32 mm [.170”] Tail Length
READOUT (Opposite Page)
D = Dual
DIMENSIONS Dimensions in [ ] are in inches, all others are in millimeters.
FIRST POSITION
INDICATOR
PIN A1
4X Ø 3.18 [.125]
PIN A2
9.14[.360]
9.40
[.370]
PAD WIDTH
0.76[.030]
C
A
B
D
E
6.35
[.250]
0.36 X 0.30 [.014 X .012] POST
1.00
[.039],TYP.
1.90
[.075]
MAX.
6.35
[.250]
MIN.
F
(S) MOUNTING SHOWN
REFER TO TERMINATION TYPE
7.62
[.300]
MIN.
7.62[.300]
21.84
[.860]
PIN B1
PIN B2
2X R 0.76
[. 030]MAX.
MILLIMETERS
1.00[.039]
60°
A
(B - 0.36 [.014])
±0.13[.005]
0.51
[.020]
1.57 ± 0.20
[.062 ± .008]
INCHES
POSITIONS/
CONTACTS
A±0.13
B±0.13
C±0.38
D±0.25
E±0.51
F±0.25
A±.005
B±.005
C±.015
D±.010
E±.020
F±.010
02/04*
03/06*
04/08*
05/10
06/12*
07/14*
08/16*
09/18*
10/20
11/22*
12/24
13/26*
14/28*
15/30
16/32
17/34*
18/36*
19/38*
20/40
21/42*
22/44*
23/46*
24/48*
25/50
26/52*
27/54*
28/56*
29/58*
30/60
31/62*
32/64*
33/66*
34/68*
35/70
36/72*
37/74*
38/76*
39/78*
40/80
41/82*
42/84*
43/86*
44/88*
45/90
46/92*
47/94*
48/96*
49/98*
50/100
1.00
2.00
3.00
4.00
5.00
6.00
7.00
8.00
9.00
10.00
11.00
12.00
13.00
14.00
15.00
16.00
17.00
18.00
19.00
20.00
21.00
22.00
23.00
24.00
25.00
26.00
27.00
28.00
29.00
30.00
31.00
32.00
33.00
34.00
35.00
36.00
37.00
38.00
39.00
40.00
41.00
42.00
43.00
44.00
45.00
46.00
47.00
48.00
49.00
4.32
5.32
6.32
7.32
8.32
9.32
10.32
11.32
12.32
13.32
14.32
15.32
16.32
17.32
18.32
19.32
20.32
21.32
22.32
23.32
24.32
25.32
26.32
27.32
28.32
29.32
30.32
31.32
32.32
33.32
34.32
35.32
36.32
37.32
38.32
39.32
40.32
41.32
42.32
43.32
44.32
45.32
46.32
47.32
48.32
49.32
50.32
51.32
52.32
9.89
10.89
11.89
12.89
13.89
14.89
15.89
16.89
17.89
18.89
19.89
20.89
21.89
22.89
23.89
24.89
25.89
26.89
27.89
28.89
29.89
30.89
31.89
32.89
33.89
34.89
35.89
36.89
37.89
38.89
39.89
40.89
41.89
42.89
43.89
44.89
45.89
46.89
47.89
48.89
49.89
50.89
51.89
52.89
53.89
54.89
55.89
56.89
57.89
17.15
18.15
19.15
20.15
21.15
22.15
23.15
24.15
25.15
26.15
27.15
28.15
29.15
30.15
31.15
32.15
33.15
34.15
35.15
36.15
37.15
38.15
39.15
40.15
41.15
42.15
43.15
44.15
45.15
46.15
47.15
48.15
49.15
50.15
51.15
52.15
53.15
54.15
55.15
56.15
57.15
58.15
59.15
60.15
61.15
62.15
63.15
64.15
65.15
25.13
26.13
27.13
28.13
29.13
30.13
31.13
32.13
33.13
34.13
35.13
36.13
37.13
38.13
39.13
40.13
41.13
42.13
43.13
44.13
45.13
46.13
47.13
48.13
49.13
50.13
51.13
52.13
53.13
54.13
55.13
56.13
57.13
58.13
59.13
60.13
61.13
62.13
63.13
64.13
65.13
66.13
67.13
68.13
69.13
70.13
71.13
72.13
73.13
5.25
6.25
7.25
8.25
9.25
10.25
11.25
12.25
13.25
14.25
15.25
16.25
17.25
18.25
19.25
20.25
21.25
22.25
23.25
24.25
25.25
26.25
27.25
28.25
29.25
30.25
31.25
32.25
33.25
34.25
35.25
36.25
37.25
38.25
39.25
40.25
41.25
42.25
43.25
44.25
45.25
46.25
47.25
48.25
49.25
50.25
51.25
52.25
53.25
0.039
0.079
0.118
0.157
0.197
0.236
0.276
0.315
0.354
0.394
0.433
0.472
0.512
0.551
0.591
0.630
0.669
0.709
0.748
0.787
0.827
0.866
0.906
0.945
0.984
1.024
1.063
1.102
1.142
1.181
1.220
1.260
1.299
1.339
1.378
1.417
1.457
1.496
1.535
1.575
1.614
1.654
1.693
1.732
1.772
1.811
1.850
1.890
1.929
0.170
0.210
0.249
0.288
0.328
0.367
0.407
0.446
0.485
0.525
0.564
0.603
0.643
0.682
0.722
0.761
0.800
0.840
0.879
0.918
0.958
0.997
1.037
1.076
1.115
1.155
1.194
1.233
1.273
1.312
1.351
1.391
1.430
1.470
1.509
1.548
1.588
1.627
1.666
1.706
1.745
1.785
1.824
1.863
1.903
1.942
1.981
2.021
2.060
0.389
0.429
0.468
0.507
0.547
0.586
0.626
0.665
0.704
0.744
0.783
0.822
0.862
0.901
0.941
0.980
1.019
1.059
1.098
1.137
1.177
1.216
1.256
1.295
1.334
1.374
1.413
1.452
1.492
1.531
1.570
1.610
1.649
1.689
1.728
1.767
1.807
1.846
1.885
1.925
1.964
2.004
2.043
2.082
2.122
2.161
2.200
2.240
2.279
0.675
0.715
0.754
0.793
0.833
0.872
0.912
0.951
0.990
1.030
1.069
1.108
1.148
1.187
1.227
1.266
1.305
1.345
1.384
1.423
1.463
1.502
1.542
1.581
1.620
1.660
1.699
1.738
1.778
1.817
1.856
1.896
1.935
1.975
2.014
2.053
2.093
2.132
2.171
2.211
2.250
2.290
2.329
2.368
2.408
2.447
2.486
2.526
2.565
0.989
1.029
1.068
1.107
1.147
1.186
1.226
1.265
1.304
1.344
1.383
1.422
1.462
1.501
1.541
1.580
1.619
1.659
1.698
1.737
1.777
1.816
1.856
1.895
1.934
1.974
2.013
2.052
2.092
2.131
2.170
2.210
2.249
2.289
2.328
2.367
2.407
2.446
2.485
2.525
2.564
2.604
2.643
2.682
2.722
2.761
2.800
2.840
2.879
0.207
0.246
0.285
0.325
0.364
0.404
0.443
0.482
0.522
0.561
0.600
0.640
0.679
0.719
0.758
0.797
0.837
0.876
0.915
0.955
0.994
1.033
1.073
1.112
1.152
1.191
1.230
1.270
1.309
1.348
1.388
1.427
1.467
1.506
1.545
1.585
1.624
1.663
1.703
1.742
1.781
1.821
1.860
1.900
1.939
1.978
2.018
2.057
2.096
* Consult factory for availability.
11
很抱歉,暂时无法提供与“RBE05DHAS”相匹配的价格&库存,您可以联系我们找货
