Female Card Edge
.100” [2.54 mm] Contact Centers, .610” [15.49 mm] Insulator Height,
[ISA] Dip Solder/Wire Wrap/Right Angle
Sullins Female Card Edge
SPECIFICATIONS
Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
PBT or PA9T insulator
Molded-in key available
3 Amps current rating for one contact energized
30 milli Ohms maximum at rate current
UL Flammability Rating: 94V-0
READOUT
POLARIZING KEY
PLC-K1
.038”
[0.97]
.285”
[7.24]
.100” [2.54]
DUAL (D)
HALF LOADED (H)
KEY IN BETWEEN CONTACTS
(ORDER SEPARATELY)
TERMINATION TYPE
HAIRPIN BELLOWS
LOOP BELLOWS
L
.275” [6.98]
L
K
.200” [5.08]
HAIRPIN BELLOWS
(CS,CM,CW,CT)
L
K
.200” [5.08]
K
LOOP BELLOWS
(TK,RS,RM)
.150” [3.81]
RIGHT ANGLE, DIP SOLDER
(CA,CB,CC,TA,TB,TM)
-S605 MODIFICATION
POST CROSS SECTION
K
POST LENGTH
L
.025”ʺ [0.64]
FITS MIN.
HOLE SIZE
DIP SOLDER
.025ʺ [0.64] ROUND
.190ʺ [4.83]
.033ʺ [0.84]
DIP SOLDER
.025ʺ [0.64] SQUARE
.190ʺ [4.83]
.040ʺ [1.02]
RM
WIRE WRAP
.025ʺ [0.64] SQUARE
.560ʺ [14.20]
.040ʺ [1.02]
TA
RIGHT ANGLE
.025ʺ [0.64] SQUARE
.100ʺ [2.54]
.043ʺ [1.09]
CB
TB
RIGHT ANGLE
.025ʺ [0.64] SQUARE
.180ʺ [4.57]
.043ʺ [1.09]
CC
TM
RIGHT ANGLE
.025ʺ [0.64] SQUARE
.250ʺ [6.35]
.043ʺ [1.09]
CW
DIP SOLDER
.015ʺ X .025ʺ [0.38 X 0.64]
.125ʺ [3.18]
.035ʺ [0.89]
CT
DIP SOLDER
.170ʺ [4.32]
.035ʺ [0.89]
CS
DIP SOLDER
.025ʺ [0.64] SQUARE
.160ʺ [4.06]
.040ʺ [1.02]
HAIRPIN
BELLOWS
LOOP
TERMINATION
TYPE
TK, CK
RS
CM
CA
MOUNTING STYLE
Ø.125"
[3.18]
#4-40
Ø.125”
[3.18]
.250"
[6.35]
CLEARANCE
HOLE (H)
56
Ø.125” [3.18]
.245”
[6.22]
THREADED
INSERT(I)
SIDE MOUNTING
(S)
D = .250” [6.35]
W = .430” [10.92]
NO MOUNTING
EARS (N)
FLUSH MOUNTING
(D, W)
#4-40
T = .250” [6.35]
X = .430” [10.92]
FLUSH MOUNTING WITH
THREADED INSERT(T, X)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B C 49 D CW N - S420
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
B
C
G
Y
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
MODIFICATION CODE (Consult Factory)
ISA WITH RETENTION FEATURE
-S524 = 18 Positions
-S524 = 31 Positions
-S518 = 49 Positions (31/18)
ISA WITHOUT RETENTION FEATURE
-S371 = 18 Positions
-S371 = 31 Positions
-S420 = 49 Positions (31/18) Dip Solder or Wire Wrap
-S605 = 49 Positions (31/18) Right Angle**
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
G = PA9T/Phosphor Bronze
H = PBT/Beryllium Copper
J = PA9T/Beryllium Copper
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
CONTACT FINISH - RoHS Compliant
MOUNTING STYLE (Opposite Page)
H = Clearance Holes
I = Threaded Inserts
S = Side Mounting
N = No Mounting
D, W = Flush Mounting
T, X = Flush Mounting With Threaded Inserts
TERMINATION TYPE (Opposite Page)
Hairpin Bellows *
CS = .025” [0.64 mm] Square Dip Solder
CM = .025” [0.64 mm] Square Wire Wrap
CA, CB, CC = .025” [0.64 mm] Square Right Angle
CW, CT = .015” X .025” [0.38 mm X 0.64 mm] Dip Solder
Loop Bellows
RS = .025” [0.64 mm] Square Dip Solder
TK = .025” [0.64 mm] Round Dip Solder
RM = .025” [0.64 mm] Square Wire Wrap
TA, TB, TM = .025” [0.64 mm] Square Right Angle
* Available in B or C Plating and Phosphor Bronze only
Consult Factory for Cantilever Terminations
CONTACT CENTERS
C = .100” [2.54 mm]
NUMBER OF CONTACT POSITIONS
18, 31 or 49 (31/18)
READOUT (Opposite page)
D = Dual
H = Half Loaded
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
2.635 [66.93]
2.375 [60.32]
2.060 [52.32]
1.900 [48.26]
1.700 [43.18]
.370 [9.40]
Ø .043 [1.09]
.062[ 1.57] PCB
.610
[15.49]
MOUNTING STYLE,
OPTIONAL
EBC18DCWN-S371
3.935 [99.95]
3.675 [93.34]
3.360 [85.34]
3.200 [81.28]
3.000 [76.20]
REFER TO
TERMINATION TYPE
(Opposite Page)
RETENTION FEATURE ON MIDDLE
TERMINALS FOR PART NUMBERS
EBC18DCWN-S524
EBC31DCWN-S524
EBC49DCWN-S518
MOUNTING STYLE,
OPTIONAL
EBC31DCWN-S371
TOP VIEW: 5.775 [146.68] / SIDE VIEW 5.750 [146.05]**
1.700 [43.18]
3.000 [76.20]
.400 [10.16]
.200 [5.08]
2.000 [50.80]
3.300 [83.82]
MOUNTING STYLE,
OPTIONAL
6.040 [153.42]
5.460 [138.68]
.297 [7.54] INSERTION DEPTH
.100 [2.54] TYP.
.060 [1.52]
REFER TO TERMINATION TYPE
31 POSITIONS
18 POSITIONS
EBC49DCWN-S420 (DIP SOLDER OR WIRE WRAP)
EBC49DCAN-S605 (RIGHT ANGLE)
** 5.750 [146.05] ONLY APPLIES IF P/N ENDS WITH -S605 AND HAS SIDE MOUNTING (MTG CODE 'S')
57
很抱歉,暂时无法提供与“ECC18DCAD-S371”相匹配的价格&库存,您可以联系我们找货
