MPSL-0125-50-DW-5HK
MPSL-0125-50-DW-5HK
    SULLINS
    CONNEDGEDUALFMALE100POS.125
MPSL-0125-50-DW-5HK 数据手册
8 7 4 5 6 1 2 3 REVISIONS F ECO. NO DESCRIPTION DATE BY A 2554 INITIAL RELEASE 3/05/2012 JH F E D B A FIRST POSITION INDICATOR REV. 2X .125 3.18 THRU .075 1.91 SEE NOTE 13 E E +.005 +0.13 .370 9.40 - .015 - 0.38 .030 0.77 .300 7.62 INSERTION DEPTH C A .180 4.57 D .250 6.35 .020 0.51 .610 15.49 .060 1.52 SEE PN CODING ON PAGE 3 FOR TAIL LENGTH MODIFICATION CODE 'H' = .190±.025 4.83±0.64 OMIT = .560- .025 [14.22 0.64] .250 6.35 ROW SPACING .125 3.18 TYP .025 0.64 FITS .040[1.02] MIN HOLE A SECTION A-A F CONTACT MARKINGS 1 3 5 ... 45 47... 99 2 4 6 ... 46 48... 100 C MP_ _-_125-_ _-DW-5(H)_ _ _ B A C CONTACT ID SCALE 4:1 NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL. 8. CONTACT RATING: 3 AMP PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHM MAX 10. INSULATION RESISTANCE: 5000 MEGA OHM MIN 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062" TEST BLADE. 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062" PCB 8 7 6 5 D B REF: _ _A_ _DRS_-(S38, S81, S328) _ _A_ _DRM_-(S38, S81, S328) CUSTOMER COPY Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 6/24/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C MP_ _-_125-_ _-DW-_ (H)_ _ _ CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD .125" PITCH, HP 2 DWG. NO. C11970 SHEET 1 OF 3 1 REV A FILE NAME: C11970, MP_ _-_125-_ _-DW-_(H)_ _ _, REF_ _A_ _DRS (DRM)_ (OMIT, -S38, S81, S328) 8 7 4 5 6 1 2 3 F F 2X .125 3.18 THRU C E E .250 6.35 MP_ _-_125-_ _-DW-4(H)_ _ _ MP_ _-_125-_ _-DW-1(H)_ _ _ D D 2X #4-40 THREADED INSERTS 2X #4-40 THREADED INSERTS C C .250 6.35 B B MP_ _-_125-_ _-DW-6(H)_ _ _ MP_ _-_125-_ _-DW-2(H)_ _ _ CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 6/24/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C MP_ _-_125-_ _-DW-_ (H)_ _ _ CAGE CODE 54453 SCALE: 1.5:1 3 A EDGECARD .125" PITCH, HP 2 DWG. NO. C11970 SHEET 2 OF 3 1 REV A FILE NAME: C11970, MP_ _-_125-_ _-DW-_(H)_ _ _, REF_ _A_ _DRS (DRM)_ (OMIT, -S38, S81, S328) 8 7 4 5 6 1 2 3 F F E E D D C C B B A CUSTOMER COPY 8 7 6 5 Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 6/24/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C MP_ _-_125-_ _-DW-_ (H)_ _ _ CAGE CODE 54453 SCALE: 2:1 3 A EDGECARD .125" PITCH, HP 2 DWG. NO. C11970 SHEET 3 OF 3 1 REV A FILE NAME: C11970, MP_ _-_125-_ _-DW-_(H)_ _ _, REF_ _A_ _DRS (DRM)_ (OMIT, -S38, S81, S328)
MPSL-0125-50-DW-5HK 价格&库存
很抱歉,暂时无法提供与“MPSL-0125-50-DW-5HK”相匹配的价格&库存,您可以联系我们找货
