8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
A
2416
B
2687
DESCRIPTION
DATE
INITIAL RELEASE
07/29/11
UPDATE NOTE FORMAT, INSULATOR
VIEW FOR '2' MTG, PROCESSING TEMP 10/10/2012
FOR PBT MTL
BY
SE
JH
F
F
CONTACT MARKING:
(LETTERS G, I, O & Q NOT USED
SIZE 02 THRU 25
1 2 3 . . . 23 24 25
A B C . . . AA BB CC
SIZE 28 & 44
A B C... A B C
SIZE 36 & 43
A B C...A B C
E
D
B
E
2X
.125 3.18
THRU
A
.075 1.91
CARD SLOT
SEE NOTE 13
CONTACT ID.
SCALE 4 : 1
E
TYP .156 3.96
D
D
F
C
.030 0.76
A
.025 0.64
.431 10.95
.245 6.22
.061 1.55 X.007[0.18]
C
A
MP_ _ - _ 156 - _ _ - DSE - 1_ _ _
.265 6.73
INSERTION DEPTH
.125 3.16
CONTACT POINT
ACCEPTS .062" PCB
SECTION A-A
.210±.025 5.33±0.64
TAIL LENGTH
C
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: .SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01
RoHS
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
8
7
6
5
REF: _ _M_ _DRK_-P13, P69, S1077, S1165
CUSTOMER COPY
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES:
.XX=
.XXX=
.XXXX=
COMPLIANT
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
07/29/11
SE
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
A
CARD EDGE, .156 CC LP
PART NUMBER
SIZE
C
MP_ _-_156-_ _-DSE-_ _ _ _
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11853
SHEET 1 OF 3
1
REV
B
FILE NAME: C11853, MP_ _-_ 156-_ _-DSE-_ _ _ _ , _ _M_ _DRK_-P13, P69, S1077, S1165
8
F
7
4
5
6
1
2
3
F
2X #4-40
THREADED
INSERT
(D)
E
E
2X
MP_ _ - _ 156 - _ _ - DSE - 2_ _ _
D
.125 3.18
THRU
D
D
2X
C
C
D
.125 3.18
THRU
C
2X .135 3.43
MP_ _ - _ 156 - _ _ - DSE - 8_ _ _
B
B
MP_ _ - _ 156 - _ _ - DSE - 4_ _ _
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
07/29/11
SE
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11853
SHEET 2 OF 3
1
REV
B
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
07/29/11
SE
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11853
SHEET 3 OF 3
1
REV
B
MPSL-0156-15-DSE-1K 价格&库存
很抱歉,暂时无法提供与“MPSL-0156-15-DSE-1K”相匹配的价格&库存,您可以联系我们找货
