Waterproof Bayonet Lock Connector for 50A Power Supply
EM-W Series
Mated condition
Fig.1
Features
Derating Curve
1. High current 4 position connector
(Three-phase power source + ground)
90
Compatible with 50A current 3-position connectors and
cables. (For the relationship between ambient temperature
and current, see the derating curve shown in Fig.2)
2. Easy crimp termination
Crimp contact is user-friendly and the easy-to-assemble
design allows for uniform termination.
3. Uses a standard crimp tool
The crimp contacts can be terminated by using the JIS C
9711-compliant crimp tool.
4. Sequential ground contact
Sequential mating allows the ground contact to mate first.
The ground contact touches the metal shell. (Receptacle)
5. Quick and secure bayonet lock
Easy to operate One-touch Bayonet lock.
6. Waterproof design
IP68 compliant water resistance in mated condition
IP68 : No water intrusion while submerged in 2m water
depth for 14 days in mated condition
7. Safety Standard
TÜV certified
Basic curve
Derating curve
100
80
70
Current (A)
Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
117
60
50
40
30
50 60 70 80 90 100 110 120 130
Ambient temperature
Measurement Condition :
3 contacts connected in series with 8mm2 wire.
Measurement performed with the plug sealed for
air tightness (waterproofness).
Comment : 50A current rating assumes the
connector is used at maximum of 85℃ ambient
temperature. The actual current used should be
determined individually based on the derating
curve. The derating curve is not guaranteed
and will change dependent on factors such as
the cable used. The values in this diagram are
no t guar anteed, but should be used as
reference values. Actual measurement may
vary even when all the measurements are done
under the same conditions.
Fig.2
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2016.5
1
EM-W Series●Waterproof Bayonet Lock Connector for 50A Power Supply
Product Specifications
Rated current
50A
(See the Derating Curve on page 1.)
Operating
temperature range
-40 to +125ç
Rated voltage
AC 250V, DC 250V
Storage
temperature range
-10 to +60ç
Ratings
Item
Specifications
Conditions
1. Contact resistance
1mø max.
Measured at DC 1A
2. Insulation resistance
5000Mø min.
Measured at DC 500V
3. Withstanding voltage
No flashover or breakdown
Apply AC 2210V for 1 minute.
4. Vibration resistance
No electrical discontinuity of 10µs or
more
10 to 50 to 10Hz/cycle, half amplitude of 0.75mm,
5 minutes/cycle, 10 cycles in each of the three axial directions
5. Shock resistance
more
Acceleration : 490m/s2, duration : 11ms,
3 directions, 3 cycles for each
6. Mechanical operation
Contact resistance : 1mø max.
500 times
7. Temperature cycles
Insulation resistance : 5000Mø min.
-55ç : 30 minutes/Room temperature : 2 to 3
minutes/+125ç 30 minutes/Room temperature :
2 to 3 minutes, 5 cycles
8. Humidity resistance
(Steady state)
50Mø min. (at high humidity)
500Mø min. (dry environment)
Left at a temperature of 40°C and in humidity of
90 to 95% for 96 hours.
9. Waterproofness
No water intrusion inside connector
Submerged in 1.8m water depth for 48 days in
mated condition.
Materials / Finish
Item
Outer shell
Insulator
Contact
Waterproof packing
Materials
Aluminum alloy
PBT resin
Copper alloy
Silicon rubber
Finish
Nickel plated
-------------------Tin plated (over nickel under plating)
Remarks
-------------------UL94V-0
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Connector
EM 35 W B P - 4 S C (**)
❶
❷
❸
❹
❺
❻
❼
❽
❾
Code clamp
EM 35 W CC - 23 (**)
❶
❷
❸
❺
❾
Crimp contact
EM - S C - 1 3 3 (**)
❶
❶
❷
❸
❹
❺
❼
❽
❾
Series name : EM
Shell size : 35
Specialty : W=Waterproof
Lock mechanism : B=Bayonet lock
Connector type : P=Plug
R=Receptacle
CC=Code clamp
❻ Number of contacts : 4
❼ Discrimination between contacts : S=Female contact
P=Male contact
❽ Termination method : C=Crimp
2
❾ Specifications : When different types of
specifications are provided, attach
(01), (02), ... for identification.
Applicable cable diameter
Contact shape : 1=Loose piece contact
Change in shape/gender :
When contacts of the same size vary in shape/
gender, discriminate them by attaching a serial
number (1, 2, 3, ...) to each.
Plating : 3=Tin plated
Plug
38
EM35WBP-4SC
Spanner width
M40×1.5
Ø45
Ø34.2
3
1
2
Part No.
HRS No.
EM35WBP-4SC
138-0008-3
EM35WBP-4PC
138-0013-3
Receptacle
EM35WBR-4PC
Ø3
4×
.3
1
45
36.5
Ø40.6
2
3
36.5
45
A
●Diagram indicating panel
mounting slot dimension
HRS No.
A
EM35WBR-4PC
138-0009-6
61.4
EM35WBR-4SC
138-0014-6
55.8
+0.1
Ø37
36.5±0.1
Part No.
36.5±0.1
4×M3×0.5
Code clamp
EM35WCC-23
Ø45
M40×1.5
ØA
98.4
24
42
Spanner width
Part No.
HRS No.
ØA
EM35WCC-23
138-0007-0
23
Ø23±0.5
3
Crimp contact
Male contact
Ø7.9
Retainer
49.4
Type
HRS No.
EM-PC-113(01)
138-0011-8 01
Loose
piece
contacts
Powered by TCPDF (www.tcpdf.org)
Part No.
EM-PC-133
138-0019-0
Applicable wire size
(1) Conductor area : 5.26 to 5.57mm2 (10 AWG equivalent)
(2) Conductor outer dia. : Maximum of Ø3.1
(3) Coating outer dia. : Maximum of Ø8.7 (Applicable wire size shall
satisfy all of conditions (1) to (3).)
(1) Conductor area : 8mm2
(2) Conductor outer dia. : Maximum of Ø3.7
Remarks
Retainer :
Black
Retainer :
White
Note : This product is sold per packages (4 pcs).
Female contact
Ø7.9
Retainer
41.6
Type
Part No.
HRS No.
EM-SC-113(01)
138-0010-5 01
Loose
piece
contacts
EM-SC-133
138-0018-7
Remarks
Retainer :
Black
Retainer :
White
Tool
Type
Part No.
HRS No.
Applicable contact
Manual crimp tools
Note 1
EM-PC-133, EM-SC-133, EM-PC-113(01), EM-SC-113(01)
Contact removal tool
EM-8-TP
150-0249-3
Note 1 : About manual crimp tools
Applicable tool is JIS C 9711-compliant wire termination tool for interior wiring (commercially available).
Please use the recommend crimping tool as the performance may be affected by the type of the tool you are using.
Recommended crimp tools
Tool manufacturer
Part No.
Hozan Tool Industrial Co., Ltd.
P-75
Lobtex Co., Ltd.
AK15A
Nichifu Co., Ltd.
NH1
Manual crimp tool (Example)
EM-8-TP
Notes on use of the connector
1. Always power off and disconnect the power cord before performing this work.
2. To maintain the waterproofness and cable clamp strength at a desired level, use a cable having a diameter within the specified diameter range.
As the cable structure could also affect the performance, confirm the cable performance prior to actual use.
3. For procedure for use of harness, please contact our sales offices or service centers.
4
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 05/2016. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“EM35WBP-4PC”相匹配的价格&库存,您可以联系我们找货
