8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2714
INITIAL RELEASE
1/3/2013
JH
F
F
E
D
E
E
B
A
2X
.075 1.91
SEE NOTE 13
.125 3.18
D
+.005
+0.13
.370
9.40
- .015
- 0.38
D
C
.180 4.57
.030 0.77
A
.550 13.97
.250 6.35
A
.156 3.96
C
.250±.025 6.35±0.64
.200 5.08
ROW SPACING
.025 0.64
FITS .040[1.02] MIN HOLE
_ _M_ _DSSH
C
SECTION A-A
CONTACT MARKINGS
(LETTERS G, I, O, & Q NOT USED)
B
A
NOTES:
CONTACT ID
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
SCALE 4:1
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB.
16. MODIFICATION: NO STANDOFFS.
RoHS COMPLIANT
Pb
8
7
6
5
4
SIZE 06-25 & 30
1 2 ... 23 24 ... 29 30
A B ... A B ... H J
SIZE 28 & 31
1 2 ... 23 24 ... 30 31
A B ... A B ... J K
SIZE 36 - 43
A B ... A B ... X Y
1 2 ... 23 24 ... 42 43
SIZE 47 & 50
1 3 ... 97 99
2 4 ... 98 100
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
.XX=
.XXX=
.XXXX=
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
B
CUSTOMER COPY
DATE
NAME
1/3/2013
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
A
EDGECARD, .156 CC, HP
PART NUMBER
SIZE
C
_ _M_ _DSS_-(S38, S81, S328)
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C12137
SHEET 1 OF 3
1
REV
A
FILE NAME: C12137, _ _M_ _DSS_-OMIT, S38, S81, S328
8
7
4
5
6
1
2
3
F
F
E
E
D
D
2X #4-40
THREADED
INSERT
D
2X
.125 3.18
C
.245 6.22
_ _M_ _DSSS
_ _M_ _DSSI
A
C
2X .126 3.20
L±.015[0.38]
(L= DIM 'A' + .252[6.40]
B
B
C
_ _M_ _DSSB
CUSTOMER COPY
DRAWN
_ _M_ _DSSN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
1/3/2013
JH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 1.2:1
2
DWG. NO.
C12137
SHEET 2 OF 3
1
REV
A
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
1/3/2013
JH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 1.5:1
2
DWG. NO.
C12137
SHEET 3 OF 3
1
REV
A
很抱歉,暂时无法提供与“ECM15DSSH”相匹配的价格&库存,您可以联系我们找货
