Applicable standard
Operating
temperature range
Operating
humidity range
Rating
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
Applicable
-35 C to +85C (Note1)
40% to 80% (Note2)
DF5A-*S-5C
connector
Voltage
500
V
Storage
temperature range
Storage
humidity range
-10 C to +60C (Note3)
40% to 70%
Current
(Note3)
AWG 18 : 8.0 A
AWG 20 : 6.0 A
AWG 22 : 5.0 A
AC/DC
Specifications
Item
Test method
Requirements
QT
AT
X
X
X
X
30 m MAX.
X
X
X
Construction
General examination
Visually and by measuring instrument.
Marking
Confirmed visually.
According to drawing.
Electric characteristics
Contact resistance
Millivolt level method
100mA (DC or 1000Hz).
Insulation resistance
500 V DC.
1000 M MIN.
Voltage proof
1500 V AC for 1 min.
No flashover or breakdown.
Mechanical characteristics
Mechanical operation
30 times insertion and extraction.
①Contact resistance: 30 mΩ MAX.
②No damage, crack or looseness of parts.
X
Vibration
Frequency 10 to 55Hz, single amplitude
0.75 mm, at 2h, for 3 directions.
①No electrical discontinuity of 10μs.
X
Shock
490 m/s2 duration of pulse 11 ms at 3 times for 3 directions.
X
Environmental characteristics
Damp heat
(Steady state)
Exposed at 40 ± 2℃ , 90 to 95 %, 96 h.
(After leaving the room temperature for
1-2h.)
②Insulation resistance: 500 M MIN.
③No damage, crack or looseness of parts.
X
Rapid change of temperature
Temperature -55 →5 to 35→ 85 →5 to 35 c
Time
30 → 5 → 30 → 5 min
Under 5 cycles.
②Insulation resistance: 1000 M MIN.
X
Resistance to soldering heat
[Recommended temperature profile]
Solder temperature 260±3℃ for immersing
duration 10±1s.
[Recommended manual soldering condition]
Soldering iron temperature:350±5℃
for within 3±1s
No strength on contact.
No deformation on case or excessive
looseness of the terminals.
X
Solderability
Soldered at solder temperature : 235c
For in immersing duration : 5s.
New uniform coating of solder shall
cover minimum of 95 of the surface
being immersed.
X
Remarks
Note 1:Include the temperature rising by current.
Note 2:No condensing
Note 3:Apply to the condition of long term storage for unused products before pcb on board,
after pcb on board, operating temperature and humidity range is applied for interim storage during transportation.
Count
Description of revisions
Designed
Checked
Date
Unless otherwise specifid , refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
Approved
KI.AKIYAMA
15.08.19
Checked
TS.FUKUSHIMA
15.08.19
Designed
MI.SAKIMURA
15.08.19
Drawn
MI.SAKIMURA
15.08.19
Drawing no.
ELC-160242-35-00
Specification sheet
Part no.
DF5A-*P-5DSA(35)
Hirose electric co., ltd.
Code no.
CL676-
很抱歉,暂时无法提供与“DF5A-6P-5DSA(35)”相匹配的价格&库存,您可以联系我们找货
