8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
6/20/2000
JASON
B
2036
INITIAL RELEASE
UPDATE KEY LOCATION & TITLE BLOCK, NEW DWG
# WAS PR12005001
8/27/2009
JH
84.84±0.30
63.25±0.15
F
NOTES:
MATERIAL
INSULATOR: GLASS-REINFORCED THERMOPLASTIC.
CONTACT: COPPER ALLOY.
PLATING: MATING AREA - SELECTED GOLD OVER NICKEL.
SOLDER AREA - TIN/LEAD OVER NICKEL.
F
1.78
ELECTRICAL
VOLATGE RATING: 250 VAC RMS.
CURRENT RATING: 1 AMP.
DIELECTRIC WITHSTANDING VOLTAGE: 500 VAC RMS 60Hz
FOR 1 MINUTE.
INSULATION RESISTANCE: 1000 MEGOHMS MIN AT 500 VDC.
CONTACT RESISTANCE: 30 MILLIOHMS MAX AT 1 AMP DC.
14.99±0.15
60.96
12.70
E
8.88±0.30
E
MECHANICAL
RETENTION FORCE: 460 GRAMS MIN PER CONTACT.
INSERTION FORCE: 230 GRAMS MAX PER CONTACT PAIR.
WITHDRAWAL FORCE: 15 GRAMS MIN PER CONTACT PAIR.
ENVIRONMENTAL
TEMPERATURE RANGE: -55 C TO +85 C.
1.27TYP
3.81
1.90
0.60±0.20
D
D
7.62
14.00
21.35
3*1.90
C
C
2.70±0.40
2.54 TYP
3.81
3*1.90
B
B
1.27 TYP
Ø1.00
60.96
12.70
RECOMMENDED PCB LAYOUT (TOP VIEW)
UNLESS OTHERWISE SPECIFIED:
Pb
A
RoHS COMPLIANT
8
7
6
5
4
DIMENSIONS ARE IN MM
TOLERANCES:
ANGULAR: 30'
.X= 0.30
.XX= 0.20
.XXX= 0.10
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
DATE
DRAWN
A
PCI .050" CC, 60P, RA
TRWB060DKAN-T621
SIZE DWG. NO.
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
NAME
8/27/09 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
C
REV
11392
B
SCALE: 3:1
2
SHEET 1 OF 1
1
FILE NAME: Z:\ECO PENDING\2036\11392, TRWB060DKAN-T621 PRINT: 8/27/2009
很抱歉,暂时无法提供与“TRWB060DKAN-T621RC”相匹配的价格&库存,您可以联系我们找货
