Press Fit
.100” [2.54 mm] Contact Centers, .550” [13.97 mm] or .610” [15.49 mm] Profile,
Press Fit
SPECIFICATIONS
Sullins Press Fit
• UL Flammability Rating: 94V-0
• Designed to meet specifications of Bellcore specification
TR-TSY-00078.
• Flat rock installation eliminates the need for any special
installation tool.
• Integrally molded scoops available to assist daughter card entry.
• Molded-in key available
FEATURES
COMPLIANT SECTION INSERTION FORCE
40 lbs maximum per contact
COMPLIANT SECTION WITHDRAWAL FORCE
10 lbs minimum per contact
HOLE SIZE REQUIREMENTS
Drilled Hole Diameter: .0453” ± .0010” [1.150 mm ± 0.025 mm]
Plating: .001” [0.03 mm] to .003” [0.08 mm] Copper and .0003” [0.008 mm] Minimum Tin
FINISHED HOLE DIAMETER
.040” ± .003” [1.02 mm ± 0.08 mm]
SUITABLE FOR .062” [1.57] DAUGHTER CARD
RECOMMENDED MOTHERBOARD THICKNESS
.093” to .125” [2.36 mm to 3.18 mm]
UL-CUL RECOGNIZED
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
ACCEPTS .054 [1.37]
TO .071 [1.80]
P.C. BOARD
OPTIONAL SCOOPS .050 [1.27]
.415 [10.54]
.150 [3.81]
P.C. BOARD
.025 [0.64] SQ.
ROW SPACING
SEE TERMINATION TYPE (Opposite Page)
.100 [2.54]
REFER TO TERMINATION TYPE (Opposite Page)
-S1136 (WITH SCOOPS) SHOWN ABOVE
C
B
A
.370
[9.40]
.550
[13.97]
WITHOUT STANDOFFS
.100 [2.54] TYP.
.100 [2.54]
80
.078 [1.98] TYP.
.610
[15.49]
WITH STANDOFFS
STANDOFF VIEWS WITH NO SCOOPS SHOWN
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Press Fit
Press Fit
PART NUMBER OPTIONS
E C C 43 D JB N - Sxxx
MODIFICATIONS (Consult Factory)
OMIT FOR STANDARD
Special Number assigned for specials such as:
- Scoops (-S1136)
- Other Card Slot Depths
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze
Refer to Page 7 for Operating/Processing Temperatures
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
C = .000030” Gold
Termination
.000100” Pure Tin, Matte
CONTACT CENTERS
C = .100” [2.54 mm]
NUMBER OF CONTACT POSITIONS
See Chart Below
READOUT
D = Dual
Tail Length
.190” [4.83 mm]
.625” [15.88 mm]
.190” [4.83 mm]
.565” [14.35 mm]
.190” [4.83 mm]
.625” [15.88 mm]
.190” [4.83 mm]
.565” [14.35 mm]
Sullins Press Fit
MOUNTING STYLE
N = No Mounting
TERMINATION TYPE
Standoffs
Row Spacing
JB = No*
.200” [5.08 mm]
JC = No*
.200” [5.08 mm]
JW = Yes
.200” [5.08 mm]
JX = Yes
.200” [5.08 mm]
JF = No*
.100” [2.54 mm]
JG = No*
.100” [2.54 mm]
JY = Yes
.100” [2.54 mm]
JZ = Yes
.100” [2.54 mm]
* Consult factory for availability.
POSITIONS/
CONTACTS
A±.008[0.20]
B±.008[0.20]
C±.015[0.38]
in
mm
in
mm
in
mm
POSITIONS/
CONTACTS
05/10
0.400
10.16
0.600
15.24
0.756
19.20
06/12
0.500
12.70
0.700
17.78
0.856
07/14
0.600
15.24
0.800
20.32
0.956
08/16*
0.700
17.78
0.900
22.86
09/18*
0.800
20.32
1.000
25.40
10/20
0.900
22.86
1.100
11/22*
1.000
25.40
1.200
12/24
1.100
27.94
13/26
1.200
14/28*
15/30
A±.008[0.20]
B±.008[0.20]
C±.015[0.38]
in
mm
in
mm
in
mm
33/66*
3.200
81.28
3.400
86.36
3.556
90.32
21.74
34/68
3.300
83.82
3.500
88.90
3.656
92.86
24.28
35/70
3.400
86.36
3.600
91.44
3.756
95.40
1.056
26.82
36/72
3.500
88.90
3.700
93.98
3.856
97.94
1.156
29.36
37/74*
3.600
91.44
3.800
96.52
3.956
100.48
27.94
1.256
31.90
38/76*
3.700
93.98
3.900
99.06
4.056
103.02
30.48
1.356
34.44
39/78*
3.800
96.52
4.000
101.60
4.156
105.56
1.300
33.02
1.456
36.98
40/80
3.900
99.06
4.100
104.14
4.256
108.10
30.48
1.400
35.56
1.556
39.52
41/82*
4.000
101.60
4.200
106.68
4.356
110.64
1.300
33.02
1.500
38.10
1.656
42.06
42/84*
4.100
104.14
4.300
109.22
4.456
113.18
1.400
35.56
1.600
40.64
1.756
44.60
43/86
4.200
106.68
4.400
111.76
4.556
115.72
16/32
1.500
38.10
1.700
43.18
1.856
47.14
44/88
4.300
109.22
4.500
114.30
4.656
118.26
17/34
1.600
40.64
1.800
45.72
1.956
49.68
45/90*
4.400
111.76
4.600
116.84
4.756
120.80
18/36
1.700
43.18
1.900
48.26
2.056
52.22
46/92*
4.500
114.30
4.700
119.38
4.856
123.34
19/38*
1.800
45.72
2.000
50.80
2.156
54.76
47/94*
4.600
116.84
4.800
121.92
4.956
125.88
124.46
20/40
1.900
48.26
2.100
53.34
2.256
57.30
48/96*
4.700
119.38
4.900
5.056
128.42
21/42*
2.000
50.80
2.200
55.88
2.356
59.84
49/98*
4.800
121.92
5.000
127.00
5.156
130.96
22/44
2.100
53.34
2.300
58.42
2.456
62.38
50/100
4.900
124.46
5.100
129.54
5.256
133.50
23/46
2.200
55.88
2.400
60.96
2.556
64.92
51/102*
5.000
127.00
5.200
132.08
5.356
136.04
24/48
2.300
58.42
2.500
63.50
2.656
67.46
52/104*
5.100
129.54
5.300
134.62
5.456
138.58
25/50
2.400
60.96
2.600
66.04
2.756
70.00
53/106*
5.200
132.08
5.400
137.16
5.556
141.12
139.70
26/52
2.500
63.50
2.700
68.58
2.856
72.54
54/108*
5.300
134.62
5.500
5.656
143.66
27/54*
2.600
66.04
2.800
71.12
2.956
75.08
55/110
5.400
137.16
5.600
142.24
5.756
146.20
28/56
2.700
68.58
2.900
73.66
3.056
77.62
56/112*
5.500
139.70
5.700
144.78
5.856
148.74
29/58*
2.800
71.12
3.000
76.20
3.156
80.16
57/114*
5.600
142.24
5.800
147.32
5.956
151.28
30/60
2.900
73.66
3.100
78.74
3.256
82.70
58/116*
5.700
144.78
5.900
149.86
6.056
153.82
31/62
3.000
76.20
3.200
81.28
3.356
85.24
59/118*
5.800
147.32
6.000
152.40
6.156
156.36
32/64*
3.100
78.74
3.300
83.82
3.456
87.78
60/120
5.900
149.86
6.100
154.94
6.256
158.90
81
很抱歉,暂时无法提供与“ECC10DJFN”相匹配的价格&库存,您可以联系我们找货
