MPSL-0156-18-DSE-4K
MPSL-0156-18-DSE-4K
    SULLINS
    CONNEDGEDUALFMALE36POS0.156
MPSL-0156-18-DSE-4K 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO A 2416 B 2687 DESCRIPTION DATE INITIAL RELEASE 07/29/11 UPDATE NOTE FORMAT, INSULATOR VIEW FOR '2' MTG, PROCESSING TEMP 10/10/2012 FOR PBT MTL BY SE JH F F CONTACT MARKING: (LETTERS G, I, O & Q NOT USED SIZE 02 THRU 25 1 2 3 . . . 23 24 25 A B C . . . AA BB CC SIZE 28 & 44 1 2 3 . . . 23 24 25 A B C... A B C SIZE 36 & 43 A B C...A B C 1 2 3 . . . 23 24 25 E D B E 2X .125 3.18 THRU A .075 1.91 CARD SLOT SEE NOTE 13 CONTACT ID. SCALE 4 : 1 E TYP .156 3.96 D D F C .030 0.76 A .025 0.64 .431 10.95 .245 6.22 .061 1.55 X.007[0.18] C A MP_ _ - _ 156 - _ _ - DSE - 1_ _ _ .265 6.73 INSERTION DEPTH .125 3.16 CONTACT POINT ACCEPTS .062" PCB SECTION A-A .210±.025 5.33±0.64 TAIL LENGTH C B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: .SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 RoHS 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 8 7 6 5 REF: _ _M_ _DRK_-P13, P69, S1077, S1165 CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= COMPLIANT 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 07/29/11 SE THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A CARD EDGE, .156 CC LP PART NUMBER SIZE C MP_ _-_156-_ _-DSE-_ _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11853 SHEET 1 OF 3 1 REV B FILE NAME: C11853, MP_ _-_ 156-_ _-DSE-_ _ _ _ , _ _M_ _DRK_-P13, P69, S1077, S1165 8 F 7 4 5 6 1 2 3 F 2X #4-40 THREADED INSERT (D) E E 2X MP_ _ - _ 156 - _ _ - DSE - 2_ _ _ D .125 3.18 THRU D D 2X C C D .125 3.18 THRU C 2X .135 3.43 MP_ _ - _ 156 - _ _ - DSE - 8_ _ _ B B MP_ _ - _ 156 - _ _ - DSE - 4_ _ _ CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 07/29/11 SE THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A CARD EDGE, .156 CC LP PART NUMBER SIZE C MP_ _-_156-_ _-DSE-_ _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11853 SHEET 2 OF 3 1 REV B FILE NAME: C11853, MP_ _-_ 156-_ _-DSE-_ _ _ _ , _ _M_ _DRK_-P13, P69, S1077, S1165 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 07/29/11 SE THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A CARD EDGE, .156 CC LP PART NUMBER SIZE C MP_ _-_156-_ _-DSE-_ _ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11853 SHEET 3 OF 3 1 REV B FILE NAME: C11853, MP_ _-_ 156-_ _-DSE-_ _ _ _ , _ _M_ _DRK_-P13, P69, S1077, S1165
MPSL-0156-18-DSE-4K 价格&库存
很抱歉,暂时无法提供与“MPSL-0156-18-DSE-4K”相匹配的价格&库存,您可以联系我们找货
