EBC19MMVN-S189
EBC19MMVN-S189
    SULLINS
    CONN EDGECARD 38POS .100"
EBC19MMVN-S189 数据手册
Male Card Edge .100” [2.54 mm] Contact Centers, .540” [13.72 mm] Insulator Height, Male Card Edge, Dip Solder/Right Angle/Card Extender SPECIFICATIONS Sullins Male Card Edge • • • • • • • Compatible with .431” [10.95 mm] or .610” [15.49 mm] Insulator Height Card Edges Mates in place of .062” [1.57 mm] PC board PBT, PA9T or PPS insulator 3 Amps current rating for one contact energized 30 milli Ohms maximum at rated current Consult Factory for other Contact Centers UL Flammability Rating: 94V-0 Operating/Processing Temperature E = PBT & Phosphor Bronze Operating Temperature: -65°C to + 125°C Processing Temperature: Wave only R = PPS & Phosphor Bronze Operating Temperature: -65°C to + 150°C Processing Temperature: 260°C Max. for 20 sec. G = PA9T & Phosphor Bronze Operating Temperature: -65°C to + 150°C Processing Temperature: 260°C Max. for 20 sec. A = PPS & Beryllium Copper Operating Temperature: -65°C to + 200°C Processing Temperature: 260°C Max. for 20 sec. Overall Gold Plating Only (Plating code 'S' or 'M') TERMINATION TYPE MA = .100” [2.54] MV = .130” [3.30] MB = .180” [4.57] MD = .250” [6.35] MJ = .500” [12.70] MK = .560” [14.22] MW = .125” [3.18] MS = .190” [4.83] MM = .560” [14.22] FITS Ø .043” [1.09] .200” [5.08] DIP SOLDER (MW, MS) WIRE WRAP (MM) FITS Ø .043” [1.09] MR = .175” [4.45] MN = .545” [13.84] .150” [3.81] .200” [5.08] (-S189 Modification) ACCOMMODATES .062” [1.57] PCB CARD EXTENDER (MR, MN) RIGHT ANGLE (MA, MV, MB, MD, MJ, MK) MOUNTING STYLE 2X Ø.125” [3.18] 4X Ø.125” [3.18] .125” [3.18] NO MOUNTING (N) 42 FLUSH with CLEARANCE HOLES (D) FLUSH, SIDE MOUNTING with CLEARANCE HOLES (Z) 2X #4-40 2X #4-40 .125” [3.18] FLUSH with THREADED INSERT (T) FLUSH, with SIDE MOUNTED THREADED INSERT (V) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Male Card Edge .100” [2.54 mm] Contact Centers, .540” [13.72 mm] Insulator Height, Male Card Edge, Dip Solder/Right Angle/Card Extender PART NUMBER OPTIONS E B C 25 M MW D - Sxxx MODIFICATIONS (Consult Factory) OMIT FOR STANDARD -S189 = .200” [5.08] Row Spacing (Right Angle Only) MOUNTING STYLE N = No Mounting D = .250” Ears, Flush Mounting, .125” [3.18] Diameter Z = .250” Ears, Flush, Side Mounting T = .250” Ears, Flush Mounting, #4-40 Threaded Insert V = Flush, Side Mounting, #4-40 Threaded Insert TERMINATION TYPE MW, MS = Dip Solder MM = Wire Wrap MA, MV, MB = Right Angle MD, MJ, MK = Right Angle MR, MN = Card Extender CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface B = .000010” Gold C = .000030” Gold Y = .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold Overall Plating .000010” Gold .000010” Gold M = Male Card Edge NUMBER OF CONTACT POSITIONS 04 thru 60 Positions (Contact factory for positions not shown.) CONTACT CENTERS C = .100” [2.54 mm] Sullins Male Card Edge MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze G = PA9T/Phosphor Bronze R = PPS/ Phosphor Bronze A = PPS/Beryllium Copper (Only 'S' or 'M' plating code) Operating & Processing Temperature: See Opposite Page DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. (Dimension 'E' for Mounting Style 'N' Only) E (Dimensions 'D' & 'C' for Mounting Style 'D, Z, T, V' Only) D C B A .540 [13.72] .250 [6.35] .370 [9.40] REFER TO MOUNTING STYLE POSITIONS/ CONTACTS 04/08 05/10 06/12 07/14 08/16 10/20 12/24 13/26 15/30 16/32 17/34 18/36 19/38 20/40 22/44 23/46* 24/48 25/50 26/52 28/56 30/60 31/62 32/64 34/68 35/70 36/72 40/80 43/86* 44/88* 49/98* 50/100 52/104* 55/110* 56/112* 57/114* 58/116* 59/118* 60/120 .030[ 0.76] .025 [0.64] SQ. .100 [2.54] REFER TO TERMINATION TYPE INCHES MILLIMETERS A±.008 B±.008 C±.010 D±.020 0.300 0.400 0.500 0.600 0.700 0.900 1.100 1.200 1.400 1.500 1.600 1.700 1.800 1.900 2.100 2.200 2.300 2.400 2.500 2.700 2.900 3.000 3.100 3.300 3.400 3.500 3.900 4.200 4.300 4.800 4.900 5.100 5.400 5.500 5.600 5.700 5.800 5.900 0.486 0.586 0.686 0.786 0.886 1.086 1.286 1.386 1.586 1.686 1.786 1.886 1.986 2.086 2.286 2.386 2.486 2.586 2.686 2.886 3.086 3.186 3.286 3.486 3.586 3.686 4.086 4.386 4.486 4.986 5.086 5.286 5.586 5.686 5.786 5.886 5.986 6.086 0.975 1.075 1.175 1.275 1.375 1.575 1.775 1.875 2.075 2.175 2.275 2.375 2.475 2.575 2.775 2.875 2.975 3.075 3.175 3.375 3.575 3.675 3.775 3.975 4.075 4.175 4.575 4.875 4.975 5.475 5.575 5.775 6.075 1.236 1.336 1.436 1.536 1.636 1.836 2.036 2.136 2.336 2.436 2.536 2.636 2.736 2.836 3.036 3.136 3.236 3.336 3.436 3.636 3.836 3.936 4.036 4.236 4.336 4.436 4.836 5.136 5.236 5.736 5.836 6.036 6.336 * Consult factory for availability. ‘N’ Mounting Only E±.020 ‘N’ Mtg. Only A±0.20 B±0.20 C±0.25 D±0.51 0.656 0.756 0.856 0.956 1.056 1.256 1.456 1.556 1.756 1.856 1.956 2.056 2.156 2.256 2.456 2.556 2.656 2.756 2.856 3.056 3.256 3.356 3.456 3.656 3.756 3.856 4.256 4.556 4.656 5.156 5.256 5.456 5.756 5.856 5.956 6.056 6.156 6.256 7.62 10.16 12.70 15.24 17.78 22.86 27.94 30.48 35.56 38.10 40.64 43.18 45.72 48.26 53.34 55.88 58.42 60.96 63.50 68.58 73.66 76.20 78.74 83.82 86.36 88.90 99.06 106.68 109.22 121.92 124.46 129.54 137.16 139.70 142.24 144.78 147.32 149.86 12.34 14.88 17.42 19.96 22.50 27.58 32.66 35.20 40.28 42.82 45.36 47.90 50.44 52.98 58.06 60.60 63.14 65.68 68.22 73.30 78.38 80.92 83.46 88.54 91.08 93.62 103.78 111.40 113.94 126.64 129.18 134.26 141.88 144.42 146.96 149.50 152.04 154.58 24.77 27.31 29.85 32.39 34.93 40.01 45.09 47.63 52.71 55.25 57.79 60.33 62.87 65.41 70.49 73.03 75.57 78.11 80.65 85.73 90.81 93.35 95.89 100.97 103.51 106.05 116.21 123.83 126.37 139.07 141.61 146.69 154.31 31.39 33.93 36.47 39.01 41.55 46.63 51.71 54.25 59.33 61.87 64.41 66.95 69.49 72.03 77.11 79.65 82.19 84.73 87.27 92.35 97.43 99.97 102.51 107.59 110.13 112.67 122.83 130.45 132.99 145.69 148.23 153.31 160.93 ‘N’ Mounting Only E±0.51 ‘N’ Mtg. Only 16.66 19.20 21.74 24.28 26.82 31.90 36.98 39.52 44.60 47.14 49.68 52.22 54.76 57.30 62.38 64.92 67.46 70.00 72.54 77.62 82.70 85.24 87.78 92.86 95.40 97.94 108.10 115.72 118.26 130.96 133.50 138.58 146.20 148.74 151.28 153.82 156.36 158.90 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 43
EBC19MMVN-S189
物料型号:Sullins Male Card Edge
器件简介:该连接器是男性卡边缘连接器,具有2.54毫米的接触中心和13.72毫米的绝缘体高度,适用于浸锡/直角/卡扩展器。
引脚分配:提供04至60个接触位置,具体位置数量需要联系工厂确认。
参数特性: - 兼容10.95毫米或15.49毫米的绝缘体高度卡边缘 - 与1.57毫米PCB板配合使用 - 绝缘体材料包括PBT、PA9T或PPS - 单个接触的电流额定值为3安培 - 在额定电流下的最大电阻为30毫欧姆 - UL阻燃等级94V-0
功能详解: - 提供多种操作/加工温度范围,具体取决于绝缘体和接触材料 - 整体镀金,仅镀金
应用信息:适用于需要卡边缘连接器的各种电子应用。
封装信息:提供多种终止类型和安装风格,包括浸锡、直角、卡扩展器等。
EBC19MMVN-S189 价格&库存
很抱歉,暂时无法提供与“EBC19MMVN-S189”相匹配的价格&库存,您可以联系我们找货
