8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
2024
9/17/2009
JH
E
2673
HEAD HEIGHT 3.60MM WAS 4.00MM, UDATE WARP
TOLERANCE
UPDATE NOTE 4(WAS 1 AMP)
9/14/2012
LH
F
E
E
.079±.008 2.00±0.20
D
D
B±.020 [ .50]
A±.008[ .20]
.079±.002 2.00±0.05
.142±.008 3.60±0.20
C
C
.079 2.00
.110±.008 2.80±0.20
.020±.002 0.50±0.05
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS.
5. VOLTAGE RATING: 150V AC/DC.
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500V AC.
9. OPERATING TEMPERATURE: -40° C TO +105° C.
10. *PROCESSING TEMP.: 260° C FOR 10 SECS MAX.
02-20, 0.20mm MAX.
21-30, 0.30mm MAX.
31-40, 0.40mm MAX.
7
6
B
.079±.002 2.00±0.05
.031±.002 0.80±0.05
RECOMMENDED PCB LAYOUT
Pb
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
A±.004 [ .10]
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
5
4
3
DATE
NAME
12/17/08
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
HEADER MALE 2mm CC, 1 ROW, ST
5
DECIMALS
X.X= .01 [0.3]
.XX= .008 [.20]
.XXX= .0060 [.15]
RoHS COMPLIANT
DRAWN
NRPNxx1PAEN-RC
SIZE DWG. NO.
C
REV
10531
SCALE: 16:1
2
E
SHEET 1 OF 1
1
FILE NAME: Z:\ECO PENDING\2673, taiwan DWG update\10531, NRPNxx1PAEN-RC PRINT: 11/19/2012
A
很抱歉,暂时无法提供与“NRPN081PAEN-RC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 75+1.1364575+0.14194
- 250+1.13114250+0.14128
- 750+1.13111750+0.14128
- 2500+1.131092500+0.14127
- 7500+1.131067500+0.14127
