SBH11-NBPC-D17-ST-BK
    SULLINS
    34 位 接头,有罩 连接器 0.100"(2.54mm) 通孔 金
SBH11-NBPC-D17-ST-BK 数据手册
8 7 4 5 6 F 1 2 3 REV. A B ECO. NO 1682 1852 C 2103 D E 2337 2537 REVISIONS DESCRIPTION INITIAL RELEASE UPDATE DIM "C", TABLE, NOTE 3 & TOLERANCE BLOCK ADD BOX INSIDE DEPTH 6.40mm, NOTE 10, MATED COMPONENTS & HEIGHT ON SHEET 2. ADD INSULATOR MATERIAL 'NYLON 6T' OPTION UPDATE PROCESSING TEMPERATURE FOR PBT MATERIAL A BY VJ JH 04/08/2010 LH 08/17/2011 02/29/2012 LH LH .039[ .100 2.54 C .012[ 0.30] E DATE 05/08/2008 11/12/2008 F 1.00] E .100 2.54 2x .045 1.15 (REF.) .100 2.54 RECOMMENDED PCB LAYOUT .256 6.50 .177 4.50 ( .098[2.50] FOR POSITION # 3) D D B .012[ 0.30] .252 6.40 .346 8.80 .118[3.00] .358 9.10 C C .025 0.64 .100 2.54 .100 2.54 A .346 8.80 .358 9.10 B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0. COLOR: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: .000030"~.000050" NICKEL UNDERPLATE, GOLD FLASH OVERALL. 4. OPERATING TEMPERATURE: -40° C TO + 85° C. 5. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 6. CURRENT RATING: 3 AMPS PER CONTACT. 7. DIELECTRIC WITHSTANDING: 500 V AC. 8. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 9. MATES WITH SFH11, SFH210 & SFH213 IDC SOCKET SERIES. DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: ANGULAR: RoHS COMPLIANT 8 7 6 5 4 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0040 [.100] 3 DATE NAME 05/08/2008 VJ THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE BOX HEADER, .100[2.54] CC/RS, ST PART NUMBER SIZE C CAGE CODE 54453 SCALE: 4:1 2 SBH11-_BPC-D_ _-ST-_ _ DWG. NO. 11091 SHEET 1 OF 2 1 REV E FILE NAME: Z:\ECO PENDING\2537, BOX HEADER -- REMOVE PBT PROCESSING TEMP\11091\11091, SBH11-_BPC-D_ _-ST-_ _ PRINT: 4/19/2012 A 8 7 4 5 6 1 2 3 F F 2 .441 11.20 1 2 2 E E FLAT CABLE FLAT CABLE .722 18.35 * .526 13.35 * 1 1 .380 9.65 .380 9.65 D D 2 C C 1 .441 11.20 B B DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: ANGULAR: RoHS COMPLIANT 8 7 6 5 4 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0040 [.100] 3 DATE NAME 05/08/2008 VJ THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE BOX HEADER, .100[2.54] CC/RS, ST PART NUMBER SIZE C CAGE CODE 54453 SCALE: 2:1 2 SBH11-_BPC-D_ _-ST-_ _ DWG. NO. 11091 SHEET 2 OF 2 1 REV E FILE NAME: Z:\ECO PENDING\2537, BOX HEADER -- REMOVE PBT PROCESSING TEMP\11091\11091, SBH11-_BPC-D_ _-ST-_ _ PRINT: 4/19/2012 A
SBH11-NBPC-D17-ST-BK 价格&库存
很抱歉,暂时无法提供与“SBH11-NBPC-D17-ST-BK”相匹配的价格&库存,您可以联系我们找货
