DF33-6DP-3.3DSA(24)
DF33-6DP-3.3DSA(24)
    HRS(广濑)
    CONN HEADER 6POS 3.3MM DL TIN
DF33-6DP-3.3DSA(24) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. 3.3 mm Contact Pitch, Connectors for Internal Power Supplies DF33 Series Complete Locking Function Completely enclosed locking system Protection from shorts circuits between adjacent Contacts ■Features 1. 5 A maximum current Single row connector can carry current of 5 A with #20 AWG conductor. Please refer to Table #1 for current ratings for multiposition connectors using other conductor sizes. Prevention of Incorrect Connections ●Standard Type (Color: natural) 2. Complete Locking Function Reliable interior lock protects mated connectors from accidental disconnection. 3. Prevention of Incorrect Connections To prevent incorrect connection when using multiple connectors having the same Number of contacts, 3 product types having different mating configurations are available. ●R Type (Color: black) 4. Prevention of incorrect board placement Built-in posts assure correct connector placement and orientation on the board. 5. Supports encapsulation Connectors can be encapsulated up to 10 mm without affecting the performance. 6. Prevention of Short Circuits Between Adjacent Contacts *The photographs on the left show header (the board dip side), the photographs on the right show the socket (cable side). *The guide key position is indicated in position facing the mating surface of the header. Each Contact is completely surrounded by the insulator housing electrically isolating it from adjacent contacts. 7. Increased Retention Force of Crimped Contacts and confirmation of complete contact insertion Separate contact retainers are provided for applications where extreme pull-out forces may be applied against the wire or when a visual confirmation of the full contact insertion is required. 2010.9 1 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF33 Series●3.3 mm Contact Pitch, Connectors for Internal Power Supplies ■Product Specifications Ratings Voltage rating AC/DC Item AWG20 5A 5A Number of contacts 2 to 6 4 to 12 Number of rows 1 2 Current rating AWG22 5A 4A Operating temperature range -35ç to 85ç (Note 1) Operating humidity range 40% to 80% Storage temperature range -10ç to 60ç (Note 2) Storage humidity range 40% to 70% (Note 2) 500V Specification Condition 1. Contact resistance Contact resistance(Initial value): 10 m ohms max. 20mV max., 1mA 2. Insulator resistance 1000 M ohms min. 500 V DC 3. Withstanding voltage No flashover or Insulator breakdown 1500 V AC for 1 minute 4. Insertion-Extraction force (per contact) 0.5N min., 4.5N max. Measured with a steel pin of 0.5 x 0.5 ± 0.002 thickness 5. Durability (mating/unmating) Contact resistance of 20 m ohms max. 30 cycles 6. Vibration No electrical discontinuity of 1 µs. min. Frequency 10 to 55 Hz, single amplitude of 0.75 mm, 3 axis, duration of 2 hours 7. Shock No electrical discontinuity of 1 µs. min. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis. 8. Humidity Contact resistance 20 m ohms max. Temperature 40ç ± 2ç, 90% to 95% RH, 96 hours 9. Temperature cycle Contact resistance of 20 m ohms max. (-55ç: 30 minutes➝ 5 to 35ç: 5 minutes➝85ç: 30 minutes➝5 to 35ç: 5 minutes) for 5 cycles 10. Resistance to Soldering heat No deformation of the insulator parts affecting performance Flow solder temperature 260ç, for 10 seconds Manual soldering: Soldering iron temperature 320ç, 3 seconds Note 1: Includes temperature rise caused by the current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation. ■Materials Product Part Material Sockets Insulator Polyamide Crimp contacts Contacts Copper alloy Insulator Polyamide (Glass reinforced) Contacts Copper alloy Insulator PBT Headers Retainer Finish Remarks Color: Natural white (Note 1) UL94V-0 Tin plated (Note 2) ---------- Color: Natural beige (Note 1) UL94V-0 Tin plated (Note 2) ---------- Color: Black UL94V-0 Note 1: Standard Color, colors of the differing coupling forms are black for DF33R. Note 2: Hirose Electric's plating incorporate anti-whisking compounds. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Ordering Information ●Socket, Header ●Contacts DF33 R - 2 S - 3.3 C 1 2 3 4 5 1 Series name: DF33 2 Guide key type Blank : Inside (Color: natural) R : Right side (Color: black) 3 Number of contacts : 2 to 6(Single row) 4 to 12(Double row) 2 DF33A - 2022 SCF 6 1 7 8 4 Connector type 6 Type of housing S DS P DP RS RDS 5 Contact pitch C : Crimp housing DSA : Straight header 7 Applicable conductor 2022 : AWG 20 to AWG 22 8 Packaging SCF : Socket contacts / reel SC : Socket contacts / bag : Single-row socket : Double-row socket : Single-row header : Double-row header : Single-row retainer : Double-row retainer : 3.3 mm The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF33 Series●3.3 mm Contact Pitch, Connectors for Internal Power Supplies ■Single row - Straight header Standard Type R Type Standard Type (Guide Key: Inside, Color: Natural Beige) A B P=3.3 2.6 2.2 5.4 0.5 Cavity No. Lot No. indicator 3 A 8.4 11.7 15.0 18.3 21.6 B 3.3 6.6 9.9 13.2 16.5 Q'ty/tray 135 95 75 60 50 Pat number CL No. No. of contacts DF33R-2P-3.3DSA(24) 676-1043-7-24 2 DF33R-3P-3.3DSA(24) 676-1044-0-24 3 Ø1.25 A 8.4 11.7 B 3.3 6.6 Q'ty/tray 135 95 2.35 0.5 CL No. No. of contacts 676-1016-4-24 2 676-1017-7-24 3 676-1018-0-24 4 676-1019-2-24 5 676-1020-1-24 6 R Type (Guide Key: Right Side, Color: Black) 1.3 11.5 3L09 Polarity mark Pat number DF33-2P-3.3DSA(24) DF33-3P-3.3DSA(24) DF33-4P-3.3DSA(24) DF33-5P-3.3DSA(24) DF33-6P-3.3DSA(24) 1.55 Order by number of tray Q'ty. ■PCB mounting pattern (Board thickens: 1.6±0.1) + 0 0 .1 DF33-*RS-3.3 DF33(R)-*S-3.3C DF33(R)-*P-3.3DSA(24) 7.5 17.6 2.35±0.05 + 0. 0 05 8 0. -Ø * 1.55±0.05 16.3 Ø1 .3 B±0.05 P=3.3±0.05 ■Mating Dimensions Note: Retainer is comment. Standard type and R type. 3 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF33 Series●3.3 mm Contact Pitch, Connectors for Internal Power Supplies ■Double row - Straight header A B P=3.3 R Type Standard Type (Guide Key: Inside, Color: Natural Beige) Pat number DF33-4DP-3.3DSA(24) DF33-6DP-3.3DSA(24) DF33-8DP-3.3DSA(24) DF33-10DP-3.3DSA(24) DF33-12DP-3.3DSA(24) Cavity No. 2.2 10.2 P=5.8 Standard Type Polarity mark CL No. No. of contacts 676-1001-7-24 4 676-1002-0-24 6 676-1003-2-24 8 676-1004-5-24 10 676-1005-8-24 12 A 8.4 11.7 15.0 18.3 21.6 B 3.3 6.6 9.9 13.2 16.5 Q'ty/tray 135 95 75 60 50 Lot No. indicator 3 Please contact your Hirose sales representative for details. 1.3 11.5 3L09 R Type (Guide Key: Right Side, Color: Black) 0.5 Ø1.25 1.55 Order by number of tray Q'ty. ■PCB mounting pattern (Board thickens: 1.6±0.1) ■Mating Dimensions DF33-*RDS-3.3 + 0. 0 05 B±0.05 DF33(R)-*DS-3.3C 16.3 DF33(R)-*DP-3.3DSA(24) 7.5 5.8±0.05 17.6 + 0 0 .1 Ø1 .3 * -Ø 0. 8 P=3.3±0.05 1.55±0.05 Note: Retainer is comment. Standard type and R type. 4 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF33 Series●3.3 mm Contact Pitch, Connectors for Internal Power Supplies ■Single row - Crimp socket R Type Standard Type (Guide Key: Inside, Color: Natural Beige) A B P=3.3 Pat number DF33-2S-3.3C DF33-3S-3.3C DF33-4S-3.3C DF33-5S-3.3C DF33-6S-3.3C 14 9.2 2.6 4.8 2.6 Standard Type CL No. 676-1021-4 676-1022-7 676-1023-0 676-1024-2 676-1025-5 No. of contacts 2 3 4 5 6 A 7.8 11.1 14.4 17.7 21.0 B 3.3 6.6 9.9 13.2 16.5 A 7.8 11.1 B 3.3 6.6 R Type (Guide Key: Right Side, Color: Black) Cavity No. Polarity mark Pat number DF33R-2S-3.3C DF33R-3S-3.3C CL No. 676-1048-0 676-1049-3 No. of contacts 2 3 Contact No.1 indicator Note: bag packaging (100 pieces/bag). Order by number of bags. Refer to next page for retainer. ■Double row - Crimp socket Standard Type R Type Standard Type (Guide Key: Inside, Color: Natural Beige) A B P=3.3 14 9.2 2.6 9.6 5.8 Pat number DF33-4DS-3.3C DF33-6DS-3.3C DF33-8DS-3.3C DF33-10DS-3.3C DF33-12DS-3.3C CL No. 676-1006-0 676-1007-3 676-1008-6 676-1009-9 676-1010-8 No. of contacts 4 6 8 10 12 A 7.8 11.1 14.4 17.7 21.0 B 3.3 6.6 9.9 13.2 16.5 R Type (Guide Key: Right Side, Color: Black) Please contact your Hirose sales representative for details. Polarity mark Contact No.1 indicator Cavity No. Contact No.2 indicator Note: bag packaging (100 pieces/bag). Order by number of bags. Refer to next page for retainer. 5 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF33 Series●3.3 mm Contact Pitch, Connectors for Internal Power Supplies ■Single row - retainer 3.65 A B P=3.3 5.2 Cavity No. Pat number CL No. No. of contacts A B 3.3 6.2 DF33-2RS-3.3 676-1026-8 2 6.6 9.5 DF33-3RS-3.3 676-1027-0 3 9.9 12.8 DF33-4RS-3.3 676-1028-3 4 13.2 16.1 DF33-5RS-3.3 676-1029-6 5 16.5 19.4 DF33-6RS-3.3 676-1030-5 6 Note: Bag packaging (100 pieces/bag). Order by number of bags. ■Double row - retainer 5.2 3.35 A P=3.3 0.65 Pat number CL No. No. of contacts A B 8.0 3.3 DF33-4RDS-3.3 676-1011-0 4 11.3 6.6 DF33-6RDS-3.3 676-1012-3 6 14.6 9.9 DF33-8RDS-3.3 676-1013-6 8 17.9 13.2 DF33-10RDS-3.3 676-1014-9 10 21.2 16.5 DF33-12RDS-3.3 676-1015-1 12 Note: Bag packaging (100 pieces/bag). Order by number of bags. 6 B Cavity No. The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF33 Series●3.3 mm Contact Pitch, Connectors for Internal Power Supplies ■Crimp contact for socket 2.15 0.5 1.3 4 0.8 0.8 15.9 0.4 1.2 1 2 11.1 1.1 Wiresize indicator t=0.2 7.5 Part Number CL No. DF33A-2022SCF 676-1093-5 DF33A-2022SC 676-1094-8 Applicable cable UL Style Jacket diameter 1007 1.5 to 1.9mm Packaging Wire size Stranded wire conductor AWG#20 21/0.18mm 10,000 pcs./reel AWG#22 17/0.16mm 100 pcs./bag Note 1: Applicable wire with tin plated solid soft conductor. Note 2: When using other than the recommended wire, contact your nearest Hirose representative. Note 3: Strip length: 2.7 to 3.5mm ■Tools Type Item Part Number CL No. Applicable contacts Automatic Applicator AP105-DF33-2022S 901-4603-8 DF33A-2022SCF Manual Crimp tool HT102/DF33-2022S 550-0290-0 DF33A-2022SC Contact extraction tool DF33-C-P0 902-4551-2 DF33A-2022SC(F) ---------- ■Contact Extraction ■ Contact extraction tool : DF33-C-PO ■ Intended crimp Contacts : DF33A-2022SC(F) ■ Work Method : DF33-*S-3.3C, DF33A-2022SCF Housing Cross-Sectional Diagram (1) Contact extraction tool 1. Refer to the drawing No. 1. Insert contact extraction tool in the insulator against the lance. Deflect the lance as shown. Contact lance (2) 2. Assure that the lance is deflected to release the contact and pull- out wire with the terminated contact. Cautions Take particular care in removing the contact, thus not being subject to injury at convex portion edge of the crimping contact. 7 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF33 Series●3.3 mm Contact Pitch, Connectors for Internal Power Supplies ■Precautions ●Forcefully unmating the connectors will risk damaging them; therefore, when it is difficult to unmate a connector, first gently press down on it, then release the lock to allow removal. ●When performing a potting process, pay attention to the surface tension of the resin and fill the resin accordingly. ●Depending on the method by which wires have been routed within the equipment, tension may be exerted on the wires and a load applied to the contacts. Use of a retainer is recommended because of this. ●When reusing crimp contacts, raise the lance. ●Depending on the manufacturing lot and the storage conditions that have been used, the shade of the molded parts may change somewhat; however, this will not affect performance. ■Rating The rated current listed in the catalog indicates the nominal current per contact. When all contacts will be carrying current, use a current limited to about one third of the listed rating. Note that even when the rated current of the connector body is 3 A, when the nominal current of the specified wire is 1 A, the connector shall be used to handle 1 A overall. Also, do not mate or unmate by hot plug. (See Note 1) Note 1: The hot wire means that the wires are mated or unmated while electricity is being supplied to them. ■Application Environment Please contact us when the application environment is such that the equipment will be used under repetitively hot and cold temperatures. ® 8 5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN PHONE: 81-3-3491-5300, FAX: 81-3-3495-5230 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of 09/2010. Contents are subject to change without notice for the purpose of improvements.
DF33-6DP-3.3DSA(24)
物料型号:DF33系列,包括多种型号,如DF33-2P-3.3DSA(24)、DF33-3P-3.3DSA(24)等。
器件简介:DF33系列连接器适用于内部电源供应,具有多种特性,包括最大电流5A、防误插设计、支持封装、防短路等。
引脚分配:提供单排和双排引脚配置,接触点从2到12不等。
参数特性: - 电流等级:AWG20时5A,AWG22时4A。 - 电压等级:500V AC/DC。 - 工作温度范围:-35°C至85°C。 - 存储温度范围:-10°C至60°C。
功能详解:包括完全锁定功能、防误插设计、防错板放置、支持封装、防相邻接触点短路、增加压接接触点的保持力等。
应用信息:建议在重复热冷温度变化的应用环境中咨询制造商。
封装信息: - 插座和端子的绝缘体材料为聚酰胺,颜色为自然米色或自然米色(增强玻璃纤维)。 - 接触点材料为铜合金,表面镀锡。
订购信息:提供了详细的订购代码和示例。
注意事项:包括正确卸载连接器、灌封过程中的注意事项、电线布线对接触点可能施加的张力等。
额定值:目录中列出的额定电流是每个接触点的名义电流。如果所有接触点都将承载电流,请使用限制在列出额定值三分之一左右的电流。
DF33-6DP-3.3DSA(24) 价格&库存
很抱歉,暂时无法提供与“DF33-6DP-3.3DSA(24)”相匹配的价格&库存,您可以联系我们找货
