8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
644
INITIAL RELEASE
6/15/2005
TT
B
1071
6/22/2006
MV
C
1811
ADD DIMENSION
UPDATE VIEWS, P/N CODING, POSI. CHART,
TOLERANCE & GUIDE POST LENGTH DIM.
1/15/2009
JH
F
F
B±.020 [ .35]
E
E
.157 4.00
A±.010 [ .25]
.079±.002 2.00±0.05
D
D
.079±.002 2.00±0.05
.020±.002 0.50±0.05
.157±.008 4.00±0.20
.059 1.50
.087±.008 2.20±0.20
.089 2.25
C
C
.039 1.00 ,
OPTIONAL
.256±.012 6.50±0.30
2X
C±.008 [ .20]
A±.004 [ .10]
C±.004 [ .10]
02-20, 0.15mm MAX.
21-40, 0.25mm MAX.
.079±.002 2.00±0.05
.035 0.89
.106±.002 2.70±0.05
B
A
.006 [0.15]
NOTES:
1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: GOLD FLASH OVERALL.
4. CURRENT RATING: 1 AMP.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: AC 500V.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
9. *PROCESSING TEMP.: 260° C FOR 10 SECS MAX.
.276±.004 7.00±0.10
7
B
.063 1.60
RECOMMENDED PCB LAYOUT
UNLESS OTHERWISE SPECIFIED:
Pb
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
.039±.002 1.00±0.05
6
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR: 5
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
5
4
DRAWN
NAME
1/15/09
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
HEADER, MALE 2mm CC, 2 ROWS, SMT
NRPNxx2MAMx-RC
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
REV
10495
SCALE: 16:1
2
C
SHEET 1 OF 1
1
FILE NAME: Z:\COMPONENTS\Taiwan\10495, NRPNxx2MAMx-RC PRINT: 3/4/2009
A
很抱歉,暂时无法提供与“NRPN032MAMS-M81RC”相匹配的价格&库存,您可以联系我们找货
