DF5A-8P-5DSA(35)
DF5A-8P-5DSA(35)
    HRS(广濑)
    CONNHDR8POS5MM
DF5A-8P-5DSA(35) 数据手册
5mm Pitch Miniature Potting Connectors for Secondary Power Supply DF5 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Single row type Fig.1-1 ■Features Double row type 1. Potting Product This connector is capable of potting 9mm maximum, and 22.5mm mounting height is a low profile. (Fig.1) 2. Prevent Mis-insertion When the socket and pin header are mated, this connector is equipped with a mechanism to prevent reverse insertion or dissimilar contact insertion. 3. Means to Prevent Solder Cracks The pin header employs glass enforced resin, and takes countermeasures to prevent solder cracks due to heat Fig.1-2 shrinkage. 4. Prevent Reverse Insertion in Printed Board Boss is added to the pin header, and prevents reverse insertion in the printed board. 5. Full Lock Mechanism The outer lock system employs full lock mechanism. 6. Current Capacity of 8A Power can be supplied at 8A maximum. Specification will change according to applicable cable, number of contacts, number of rows. For further information, refer to product specifications as listed on next page. 7. UL and C-UL Certified 8. Glow Wire Compliance (Compliant with IEC 60695-2-11) B123 DF5 Series●5mm Pitch Miniature Potting Connectors for Secondary Power Supply ■Product Specifications Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No. of rows Single row No. of contacts 18 AWG 20 AWG 22 AWG 2 to 10 Operating Temperature Range –35 to +85ç(Note 1) 4 8A Operating Moisture Range 40 to 80% 6 5A 6A Current rating 8 Rating Double row 10 12 7A 14 4A Storage Temperature Range –10 to +60ç(Note 2) 5A 16 Storage Humidity Range 40 to 70%(Note 2) Specification AC/DC 500V UL/C-UL File No. and Recognition No. UL : E52653 Voltage rating UL/C-UL AC/DC 500V C-UL : E52653 Item Specification Condition 500V DC 1. Insulation Resistance 1000MΩ min. 1500V AC/1 minute 2. Withstanding voltage No flashover or insulation breakdown. 3. Contact Resistance 30mΩ max. 100mA 4. Single Insertior/ 0.3N (30gt) min., 4.5N (450gt) max. Measured with 1.14±0.002mm steel pin Extraction Force 5. Vibration No electrical discontinuity of 10μs or more Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 6. Humidity (Steady state) Contact resistance : 30mΩ max., Insulation resistance : 500M Ω min. 96 hours at temperature of 40ç and humidity of 90% to 95% 7. Temperature Cycle Contact resistance : 30mΩ max., Insulation resistance : 1000M Ω min. (–55ç : 30 minutes➝15 to 35ç : 10 minutes➝85ç : 30 minutes➝5 to 35ç : 10 minutes ) 5 cycles 8. Durability (Mating/un-mating) Contact resistance : 30mΩ max. 30 cycles 9.Resistance to No deformation of Flow : 260ç for 10 seconds Soldering heat components affecting performance. Manual soldering : 350ç for 3 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. ■Materials / Finish Product Part Crimping Socket Insulator Crimping Contact for Socket Contact Insulator Contact Pin header Finish Remarks Polyamide White UL94V-0 Phosphor bronze Tin plated -------------------- Polyamide Beige UL94V-0 Brass Tin plated -------------------- Material ■Product Number Structure ●Connector DF5A - *S - 5 C 1 1 2 3 ●Contact 2 Series Name : DF5A Number of contacts : Single row : 2 to 10 Double row : 4 to 16 Connector type S : Single row socket DS : Double row socket P : Single row header DP : Double row header 4 5 4 5 Contact Pitch : 5mm Contact type C : Crimping Socket DSA : Straight pin header DF5A - 1822 SCF 1 1 2 B124 3 Applicable cable type None : UL 1007 equivalent (jacket diameter 1.5 to 2.2mm) A: UL 1015 equivalent (jacket diameter 2.2 to 2.9mm) Applicable cable size 1822 : 18 to 22 AWG 2 3 3 packaging type SCF : Socket contact / reel SC : Socket contact / pack DF5 Series●5mm Pitch Miniature Potting Connectors for Secondary Power Supply ■Single Row Socket Contact No. indicator Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact Inserted Part No. DF5A- 2S-5C DF5A- 3S-5C DF5A- 4S-5C DF5A- 5S-5C DF5A- 6S-5C DF5A- 7S-5C DF5A- 8S-5C DF5A- 9S-5C DF5A-10S-5C HRS No. 676-0007-8 676-0008-0 676-0009-3 676-0010-2 676-0011-5 676-0012-8 676-0013-0 676-0014-3 676-0015-6 No. of Contacts 2 3 4 5 6 7 8 9 10 A 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 B RoHS 10.5 15.5 20.5 25.5 30.5 YES 35.5 40.5 45.5 50.5 Note : A packaging quantity is delivered by the bag unit (100 pcs.). ■Single Row Pin Header Polarity mark Part No. DF5A- 2P-5DSA(35) DF5A- 3P-5DSA(35) DF5A- 4P-5DSA(35) DF5A- 5P-5DSA(35) DF5A- 6P-5DSA(35) DF5A- 7P-5DSA(35) DF5A- 8P-5DSA(35) DF5A- 9P-5DSA(35) DF5A-10P-5DSA(35) HRS No. 676-0016-9 35 676-0017-1 35 676-0018-4 35 676-0019-7 35 676-0020-6 35 676-0021-9 35 676-0022-1 35 676-0023-4 35 676-0024-7 35 No. of Contacts 2 3 4 5 6 7 8 9 10 C 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 D RoHS 12.5 17.5 22.5 27.5 32.5 YES 37.5 42.5 47.5 52.5 Note : A packaging quantity is delivered by the bag unit (100 pcs.). BPCB mounting pattern (Board thickness = 1.6±0.1) B125 DF5 Series●5mm Pitch Miniature Potting Connectors for Secondary Power Supply Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Double Row Socket Contact No. indicator Contact Inserted Part No. DF5A- 4DS-5C DF5A- 6DS-5C DF5A- 8DS-5C DF5A-10DS-5C DF5A-12DS-5C DF5A-14DS-5C DF5A-16DS-5C HRS No. 676-0025-0 676-0026-2 676-0027-5 676-0028-8 676-0036-6 676-0037-9 676-0038-1 No. of Contacts 4 6 8 10 12 14 16 E 5.0 10.0 15.0 20.0 25.0 30.0 35.0 F RoHS 10.5 15.5 20.5 25.5 YES 30.5 35.5 40.5 Note : A packaging quantity is delivered by the bag unit (100 pcs.). ■Double Row Pin Header Polarity mark Part No. DF5A- 4DP-5DSA(35) DF5A- 6DP-5DSA(35) DF5A- 8DP-5DSA(35) DF5A-10DP-5DSA(35) DF5A-12DP-5DSA(35) DF5A-14DP-5DSA(35) DF5A-16DP-5DSA(35) HRS No. 676-0029-0 35 676-0030-0 35 676-0031-2 35 676-0032-5 35 676-0033-8 35 676-0034-0 35 676-0035-3 35 No. of Contacts 4 6 8 10 12 14 16 G 5.0 10.0 15.0 20.0 25.0 30.0 35.0 H RoHS 12.5 17.5 22.5 27.5 YES 32.5 37.5 42.5 Note : A packaging quantity is delivered by the bag unit (100 pcs.). BPCB mounting pattern (Board thickness = 1.6±0.1) B126 DF5 Series●5mm Pitch Miniature Potting Connectors for Secondary Power Supply Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BSocket Crimping Contact Part No. HRS No. DF5-1822SCF 676-0001-1 DF5-1822SC 676-0002-4 DF5A-1822SCF 676-0003-7 DF5A-1822SC 676-0004-0 Applicable Cable Packaging ULStyle Jacket Diameter Wire Size Stranded Wire Conductor 18 AWG 43/0.18mm 5,000 / reel 1007 Ø1.5 to 2.2mm 20 AWG 21/0.18mm 22 AWG 17/0.16mm Ø2.1mm 18 AWG 43/0.18mm 100 / pack Ø1.8mm 1007 20 AWG 21/0.18mm Ø1.6mm 22 AWG 17/0.16mm 18 AWG 43/0.18mm 5,000 / reel 1015 Ø2.2 to 3.2mm 20 AWG 21/0.18mm 22 AWG 17/0.16mm Ø2.9mm 18 AWG 43/0.18mm 100 / pack Ø2.6mm 1015 20 AWG 21/0.18mm Ø2.4mm 22 AWG 17/0.16mm J K 2.8 3 RoHS Yes 3.8 4 Note 1 : Applicable wire with tin plated solid soft conductor. Note 2 : When using other than the recommended wire, contact your nearest Hirose representative. Note 3 : Strip length : 3.0 to 4.0mm BApplicable Crimping Tools Type Item Press unit Automatic Applicator Manual Manual crimping tool ----- Extraction tool HRS No. Applicable Contact CM-105C Part No. 901-0001-0 ------------------------------ AP105-DF5-1822S 901-4542-5 DF5-1822SCF AP105-DF5A-1822S 901-4546-6 DF5A-1822SCF DF5-1822/CR-HT 550-0264-0 DF5-1822SC DF5A-1822/CR-HT 550-0265-2 DF5A-1822SC RP13-PC-TP 150-0021-5 DF5/DF5A-1822SCF Note 1 : If any trouble has been caused due to other tools, which are not designated by Hirose, Hirose won't guarantees any product. Note 2 : For the crimping process, refer to "crimping quality standards" and "crimping condition". BApplication Pattern BPrecautions 1. Recommended soldering condition 2. Cleaning condition 3. Connecting condition 4. Cautions 5. Precautions Flow : 260ç for 10 seconds Manual soldering : 350ç for 3 seconds Refer to the "Wire-to-Board Connector Use Hand book" Refer to the "Wire-to-Board Connector Use Hand book" ■The color phase of this product may be slightly differ from that of the formed product according to the manufacturing lot, and consequent storage condition, however, the difference affects no performance. Refer to the "Wire-to-Board Connector Use Hand book" B127
DF5A-8P-5DSA(35)
物料型号: - 该文档描述的是HIROSE ELECTRIC CO., LTD.生产的DF5系列5mm间距的次级电源灌封连接器。
器件简介: - DF5系列连接器是一种小型化的灌封连接器,具有多种特性,包括防误插、防止焊接裂纹、全锁定机制、最大8A的电流容量等。
引脚分配: - 引脚分配包括单排和双排配置,单排从2到10个接触点,双排从4到16个接触点。
参数特性: - 包括电流额定值、电压额定值、绝缘电阻、接触电阻、插入/拔出力、振动测试、湿度测试、温度循环测试、耐焊接热测试等。
功能详解: - 连接器具备灌封能力,最大灌封高度为9mm,具有低轮廓设计。同时,还具备防止反向插入和不同接触插入的机制。
应用信息: - 应用信息包括推荐的焊接条件、清洁条件、连接条件以及注意事项。
封装信息: - 封装信息包括绝缘体材料为聚酰胺,颜色为白色或米色,符合UL94V-0标准,接触材料为磷青铜或黄铜,表面处理为镀锡。
DF5A-8P-5DSA(35) 价格&库存
很抱歉,暂时无法提供与“DF5A-8P-5DSA(35)”相匹配的价格&库存,您可以联系我们找货
