MPSL-5100-22-DS-4X9K
    SULLINS
    CONNEDGEDUALFMALE44POS0.100
MPSL-5100-22-DS-4X9K 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO A 2334 B 2402 C 2443 F DESCRIPTION DATE INITIAL RELEASE 5/3/2011 UPDATED P/N CODING TO INCLUDE MTL & PLATING OPTIONS, TAIL LENGTH CHANGED TO .185, DELETE #3 MOUNTING 7/08/2011 STYLE, OBSOLETE DWG# 10554 ADDED MPP SPINODAL CONTACT OPTION 9/12/2011 BY JH JH F JH E .020[ .51] 2X .125 3.18 THRU D C B A .010[ .015[ .008[ .008[ .25] .38] .20] .20] CONTACT MARKINGS B 1 2 3 ... 58 59 60 B A 1 2 3 ... 58 59 60 A .075 1.91 CARDSLOT SEE NOTE 13 E E +.005 [0.13] F - .015 [0.38] .030±.010 0.76±0.25 A .431 10.95 .245 6.22 .025 0.64 D .265 6.73 INSERTION DEPTH A .032 0.81 .185±.025 4.70±0.64 .007 0.18 .100 2.54 MP_ _ - _100 - _ _ - DS - 1X9_ _ _ D .200 5.08 ROW SPACING SECTION A-A D A .100 2.54 C 2X .125 3.18 FOR MOUNTING STYLE '1 OR '2' .200 5.08 PCB LAYOUT RECOMMENDED B A .043 1.09 MIN NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. DIELECTRIC WITHSTANDING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMP PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB B REF : _ _C _ _ DRX _ (-P, P1, P2, P3, P5, P6, P7) CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 C 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 5/3/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A CONNECTOR, .100 CC LP PART NUMBER SIZE C MP_ _ - _100 - _ _ - DS - _ X9_ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11640 SHEET 1 OF 3 1 REV C FILE NAME: C11640, MP_ _-_100-_ _-DS-_X9_ _ _, _ _C_ _DRX_ (-P, P1, P2, P3, P5, P6, P7) 8 7 4 5 6 1 2 3 F F D 2X #4-40 THREADED INSERT E E MP_ _ - _100 - _ _ - DS - 2X9_ _ _ D 2X .125 3.18 THRU D 2X D D .125 3.18 THRU C C C 2X .135 3.43 MP_ _ - _100 - _ _ - DS - 8X9_ _ _ B B MP_ _ - _100 - _ _ - DS - 4X9_ _ _ CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 5/3/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A CONNECTOR, .100 CC LP PART NUMBER SIZE C MP_ _ - _100 - _ _ - DS - _ X9_ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11640 SHEET 2 OF 3 1 REV C FILE NAME: C11640, MP_ _-_100-_ _-DS-_X9_ _ _, _ _C_ _DRX_ (-P, P1, P2, P3, P5, P6, P7) 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 5/3/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A CONNECTOR, .100 CC LP PART NUMBER SIZE C MP_ _ - _100 - _ _ - DS - _ X9_ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11640 SHEET 3 OF 3 1 REV C FILE NAME: C11640, MP_ _-_100-_ _-DS-_X9_ _ _, _ _C_ _DRX_ (-P, P1, P2, P3, P5, P6, P7)
MPSL-5100-22-DS-4X9K 价格&库存
很抱歉,暂时无法提供与“MPSL-5100-22-DS-4X9K”相匹配的价格&库存,您可以联系我们找货
