Description
Body
Pin
Insulation
Crimp Ring
Lock Washer
Heat Shrink
Material
Brass
Brass
PTFE
Brass
Be Cu
Polyolefin
Finish
Gold
Gold
N/A
Gold
Gold
Black
REVISIONS
REV
B
C
D
Ø0.157
[4.00] Ø0.093
[2.35]
Ø0.102
[2.60]
0.104
[2.65]
0.224
[5.70]
0.177
[4.50]
DESCRIPTION
DATE
New frame; added heat shrink
APPV
1/13/10
CJ
Added new title block; Updated instructions
12-JUL-12
BPM
Updated body finish from Nickel to Gold; Updated note 3
3-MAY-16
SAH
Ø0.016
[0.40]
0.104
[2.65]
Ø0.15
[3.8]
Ø0.031
[0.80]
0.276
[7.00]
0.228
[5.80]
CRIMP RING
0.508
[12.90]
Ø0.197
[5.00]
PIN
SIDE VIEW
0.787
[20.00]
CONMMCX007 ASSEMBLY INSTRUCTIONS
1.
2.
3.
4.
5.
6.
HEAT SHRINK
Strip the cable to the recommended dimensions.
Slip heat shrink and crimp ring over stripped cable.
Solder the pin to the center conductor.
Insert the pin, center conductor and insulator into the
body until the top of the pin is even with the body.
Wrap the braid around the tail of the body and crimp the ring with a
0.128” hex crimp tool (or one labeled for use with RG-174 cable).
Use heat shrink to cover crimp.
RECOMMENDED CABLE STRIPPING DIMENSIONS
0.091
[2.30]
0.102
[2.60]
0.228
[5.80]
RG-174 Cable
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE
MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY
HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE
SOURCED MATERIALS.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM,
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
DRAWN: CJ
ENGR: S.HOGAN
159 ORT LANE
MERLIN, OR 97532
TITLE:
MMCX MALE CABLE END CRIMP
FOR RG174 CABLE
SIZE DWG. NO.
DT: 1/13/10
DT: 3-MAY-16 SCALE: 2:1
REV
CONMMCX007
DO NOT SCALE DRAWING
D
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONMMCX007”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+39.30120
- 200+15.68160
- 500+15.16320
- 1000+14.90400
