CONSMA001
CONSMA001
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    SMA
CONSMA001 数据手册
8 DESCRIPTION MATERIAL FINISH BODY SOCKET INSULATION NICKEL GOLD N/A BRASS BeCu PTFE 5 6 7 4 2 3 1 REVISIONS REV B DESCRIPTION DATE APPV 2-JUL-12 SAH 3-JUN-13 SAH 29-NOV-17 CLL UPDATED FOOTPRINT AND DIMENSIONS; ADDED NEW TITLE BLOCK C ADDED DIMPLE TO PART D ADDED OUTER BARREL DIMENSION; UPDATED NOTE 3 D D 1/4-36UNS-2A THREADS 4X S 0.059 1.50 4X Ø 0.018 DIMPLE(S) EQUALLY SPACED 4X S 0.041 1.04 0.100 2.55 0.100 2.55 0.050 1.27 C 0.212±0.004 5.38±0.10 0.198 5.04 C 0.201 5.10 0.055 1.40 4X 0.310 7.87 0.370 9.40 0.150 3.81 0.198 5.04 RECOMMENDED FOOTPRINT S 0.276 7.00 0.535 13.60 B SIDE VIEW B BACK VIEW NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. A MATERIAL: INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. 32 FINISH: 8 7 6 5 4 0.059 1.50 TITLE: SIZE DWG. NO. REV B D DRAWN: B.MURPHY DT: 11-MAR-13 CONSMA001 ENGR: S.HOGAN DT: 3-JUN-13 SCALE: 6:1 DO NOT SCALE DRAWING 3 A SMA FEMALE PCB MOUNT PROJECTION: SURFACE FINISH: ANGLES: 1 TOLERANCES: .X .1 .XX .01 .XXX .005 159 ORT LANE MERLIN, OR 97532 2 SHEET 1 OF 1 1 LDCFDFB_C
CONSMA001 价格&库存
很抱歉,暂时无法提供与“CONSMA001”相匹配的价格&库存,您可以联系我们找货
