CONREVSMA001
CONREVSMA001
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA001 数据手册
8 DESCRIPTION MATERIAL FINISH BODY PIN INSULATION NICKEL GOLD N/A BRASS BeCu PTFE 5 6 7 4 2 3 1 REVISIONS REV DESCRIPTION NEW TITLE BLOCK; UPDATED DIMENSIONS AND B ADDED FOOTPRINT C UPDATED MATERIALS D ADDED DIMPLE TO PART OUTER BARREL DIMENSION, WAS Ø0.200 IS E UPDATE Ø0.212; UPDATED NOTE 3 D 1/4-36UNS-2A THREADS 4X S 0.059 1.50 4X Ø 0.018 DIMPLE(S) EQUALLY SPACED 4X S 0.041 1.04 0.100 2.55 DATE APPV 5-MAR-12 SAH 10-JUL-12 3-JUN-13 SAH SAH 29-NOV-17 CLL D 0.100 2.55 0.050 1.27 C 0.198 5.04 0.212±0.004 5.38±0.10 C 0.201 5.10 0.055 1.40 4X 0.150 3.81 0.310 7.87 0.370 9.40 0.198 5.04 B RECOMMENDED FOOTPRINT S 0.276 7.00 0.535 13.60 SIDE VIEW B BOTTOM VIEW NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. A MATERIAL: INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. 32 FINISH: 8 7 6 5 4 0.059 1.50 TITLE: RP-SMA FEMALE PCB MOUNT PROJECTION: SURFACE FINISH: ANGLES: 1 TOLERANCES: .X .1 .XX .01 .XXX .005 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. REV B E DRAWN: B.MURPHY DT: 8-MAR-13 CONREVSMA001 ENGR: S.HOGAN DT: 3-JUN-13 SCALE: 6:1 DO NOT SCALE DRAWING 3 2 A SHEET 1 OF 1 1 LDCFDFB_C
CONREVSMA001 价格&库存
很抱歉,暂时无法提供与“CONREVSMA001”相匹配的价格&库存,您可以联系我们找货
