CONMCX007-R178
CONMCX007-R178
    LINXTECHNOLOGIES(灵思)
CONMCX007-R178 数据手册
Description Body Pin Insulation Boyd Chuck Spacer Support Heat Shrink Material Brass Brass PTFE BE CU PTFE Brass Polyolefin Finish Gold Gold N/A Gold N/A Gold Black REVISIONS REV B DESCRIPTION DATE APPV Added new title block and heat shrink; Updated instructions 12-JUL-12 SAH SIDE VIEW BOYD CHUCK PIN 0.3x3.9x5 GROOVE Ø0.148 (3.75) Ø0.102 (2.60) 0.165 (4.20) 0.126 (3.20) Ø0.020 (0.5) Ø0.197 (5.00) Ø0.019 (0.48) 0.232 (5.90) SPACER SUPPORT Ø0.037 (0.95) 0.197 (5.00) HEAT SHRINK 0.488 (12.40) Ø0.118 (3.00) CONMCX007-R178 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. 7. 8. Strip the cable to the recommended dimensions. Slip heat shrink onto stripped cable. Solder the support onto the braid. Place the spacer onto the center conductor. Solder or crimp the pin onto the center conductor. Insert the pin, center conductor, spacer, and support into the body until the pin snaps in. Crimp the tail of the body onto the support with a 0.093” hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. RECOMMENDED CABLE STRIPPING DIMENSIONS 0.118 0.071 (3.00) (1.80) 0.157 (4.00) RG-178 Cable 0.787 (20.00) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 159 ORT LANE MERLIN, OR 97532 TITLE: MCX MALE CABLE END CRIMP FOR RG178 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 12-JUL-12 ENGR: S.HOGAN DT: 12-JUL-12 SCALE: 2:1 REV CONMCX007-R178 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONMCX007-R178 价格&库存
很抱歉,暂时无法提供与“CONMCX007-R178”相匹配的价格&库存,您可以联系我们找货
