CONREVSMA002-G
CONREVSMA002-G
    LINXTECHNOLOGIES(灵思)
    RF-CONN-5P_15.2X7MM_TM
    RP-SMA
CONREVSMA002-G 数据手册
8 7 DESCRIPTION MATERIAL FINISH BODY PIN INSULATION GOLD GOLD N/A BRASS BeCu PTFE 5 6 4 2 3 1 REVISIONS REV DESCRIPTION A INITIAL RELEASE OF LINX INTERNAL DRAWING DATE APPV 11-JUN-13 SAH D D 0.598 15.20 0.102 2.60 2X Ø0.018 DIMPLE(S) EQUALLY SPACED C 4X S 0.039 1.00 4X S 0.057 1.45 0.100 2.55 0.210 5.34 0.260 6.60 0.047 1.20 1/4-36UNS-2A THREADS C 0.201 5.10 0.049 1.24 0.547 13.90 0.100 2.55 0.055 1.40 4X S 0.276 7.00 0.059 1.50 RECOMMENDED FOOTPRINT 0.154 3.90 B B SIDE VIEW BOTTOM VIEW NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. A MATERIAL: INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. 32 FINISH: 8 7 6 5 4 TITLE: RP-SMA FEMALE RIGHT ANGLE PCB MOUNT PROJECTION: SURFACE FINISH: ANGLES: 1 TOLERANCES: .X .1 .XX .01 .XXX .005 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. B 2 REV A DRAWN: B.MURPHY DT: 3-APR-13 CONREVSMA002-G ENGR: S.HOGAN DT: 11-JUN-13 SCALE: 6:1 DO NOT SCALE DRAWING 3 A SHEET 1 OF 1 1 LDCFDFB_C
CONREVSMA002-G 价格&库存
很抱歉,暂时无法提供与“CONREVSMA002-G”相匹配的价格&库存,您可以联系我们找货
CONREVSMA002-G
    • 1+49.26960
    • 200+19.07280
    • 500+18.40320
    • 1000+18.06840
    CONREVSMA002-G
    • 50+51.9740050+6.75530
    库存:400
