CONSMA012
CONSMA012
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    SMA
CONSMA012 数据手册
Description Body Pin Insulation Washer Gasket Crimp Ring Insulator Cover Heat Shrink Material Brass Brass PTFE Be Cu Si Rubber Brass PTFE Brass Polyolefin Finish Nickel Gold N/A Nickel Rubber Nickel N/A Nickel Black REVISIONS REV Ø0.146 [3.70] 1. Strip the cable to the recommended dimensions. 2. Slip heat shrink and crimp ring onto stripped cable. 2. Slide the cable into the body until the center conductor is centered in the fork. 3. Push the braided shield over the barrel. 4. Solder the center conductor into the center of the fork. 5. Slide the crimp ring over the shield and crimp with a 0.128” hex crimp tool (or one labeled for use with RG-174 cable). 6. Trim off any excess shield wire sticking out from the ring. 7. Slip the heat shrink over the crimp ring until it is against the body and shrink. 8. Insert insulator into body. 9. Push the cover into the opening. 0.197 [5.00] Add Heat Shrink to Drawing C Updated dimensions; Added new title block D Updated cable stripping dimensions APPV 28-JUL-09 CJ 2-JUL-12 SAH 24-MAY-16 SAH Ø0.154 [3.90] 0.374 [9.50] CRIMP RING 0.287 [7.30] 1/4-36UNS-2B THREADS Ø0.197 [5.00] INSULATOR CONSMA012 ASSEMBLY INSTRUCTIONS 0.098 0.118 [2.50] [3.00] B 0.331 [8.40] 0.287 [7.30] 0.055 [1.40] COVER DATE 0.650 [16.50] 0.051 [1.30] Ø0.185 [4.70] DESCRIPTION 0.197 [5.00] RG-174 Cable BARREL 0.787 [20.00] Ø0.106 [2.70] Ø0.260 [6.60] SIDE VIEW NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: BRAIDED SHIELD RECOMMENDED CABLE STRIPPING DIMENSIONS HEAT SHRINK FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: 159 ORT LANE MERLIN, OR 97532 SMA MALE RIGHT ANGLE CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 2-JUL-12 ENGR: S.HOGAN DT: 24-MAY-16 SCALE: 2:1 REV CONSMA012 DO NOT SCALE DRAWING D SHEET 1 OF 1 LDCFDLT_A
CONSMA012 价格&库存
很抱歉,暂时无法提供与“CONSMA012”相匹配的价格&库存,您可以联系我们找货
