CONREVSMA002-L
CONREVSMA002-L
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA002-L 数据手册
REVISIONS REV DESCRIPTION A INITIAL RELEASE OF LINX INTERNAL DRAWING 4.10 0.161 CLL 4.10 0.161 7.00 0.276 1.24 0.049 NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN mm [INCHES]. 3.90 2. DIMENSIONS APPLY AFTER FINISHING. 0.154 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES 0.5 MAXIMUM. 5 SEE TABLE I FOR ELECTRICAL SPECIFICATIONS. (SHEET 2) 13.90 6 SEE TABLE II FOR ENVIRONMENTAL SPECIFICATIONS. (SHEET 2) 0.547 7 SEE TABLE III FOR MECHANICAL SPECIFICATIONS. (SHEET 2) 0.50 8. SEE PARTSLIST. "*" INDICATES FINISH TYPE. 0.020 WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE MERLIN, OR 97532 TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS 7.00 0.276 1.60 0.063 NUT 01/MAR/19 1/4"-36UNS-2A THREADS 19.50 0.768 SCALE 1 : 1 1.00 0.039 1.20 0.047 11.40 0.449 HEX 8.0 APPV 1.45 0.057 6.60 0.260 FLAT 5.8 DATE 10.20 0.402 WASHER DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: TOLERANCES: 0.50 [.020]-5.00 [.200]= 0.20 [.008] 5.00 [.200]-30.00 [1.200]= 0.40 [.016] 30.0 [1.20]-120.0 [4.75]= 0.60 [0.24] 120.0 [4.75]-315.0 [12.40]= 1.0 [.040] DRAWN: M. SCHULTE PROJECTION: ANGLES: 1 DT: 21/JAN/19 ENGR: D. VARATHARAJAN DT: 08/MAR/19 TITLE: RP-SMA FEMALE RIGHT ANGLE PCB MOUNT, EXTENDED SIZE DWG. NO. A REV CONREVSMA002-L-* SCALE: 3:1 DO NOT SCALE DRAWING A SHEET 1 OF 2 LDCFDAL_C 5 SEE SHEET 1 FOR REVISIONS TABLE I 5.10 0.201 6 4X 5.10 0.201 1.50 0.059 1.40 0.055 TABLE II RECOMMENDED FOOTPRINT 6.00 0.236 7 TABLE III 6.50 0.256 RECOMMENDED MOUNTING HOLE SIZE DWG. NO. A REV CONREVSMA002-L-* SCALE: 4:1 DO NOT SCALE DRAWING A SHEET 2 OF 2 LDCFDAL_A
CONREVSMA002-L
物料型号: - 型号:CONREVSMA002-L 和 CONREVSMA002-L-G
器件简介: - 连接器类型:RP-SMA Jack(公头) - 端接方式:PCB 通孔安装 - 材料:主体、螺母和垫圈有黄铜材质,表面处理有镍和金
引脚分配: - 中心接触:黄铜镀金 - 绝缘体:PTFE
参数特性: - 阻抗:50欧姆 - 频率范围:0至18GHz - 绝缘电阻:至少5000MΩ - 电压额定值:1000V RMS(CONREVSMA002-L)和500V RMS(CONREVSMA002-L-G) - 接触电阻:中心接触小于3.0毫欧,外接触小于2.5毫欧(CONREVSMA002-L);中心接触小于2.0毫欧,外接触小于2.0毫欧(CONREVSMA002-L-G) - VSWR:小于1.3(6GHz)
功能详解: - 连接器耐用性:至少500次循环 - 重量:5.4克 - 推荐扭矩:0.57牛顿米 - 耦合螺母保持力:至少60磅
应用信息: - 环境合规性:符合RoHS指令 - 温度范围:-55°C至+155°C - 环境测试:包括盐雾测试、热冲击、振动、机械冲击
封装信息: - 安装类型:面板安装,通孔,直角 - 紧固类型:1/4-36螺纹耦合
CONREVSMA002-L 价格&库存
很抱歉,暂时无法提供与“CONREVSMA002-L”相匹配的价格&库存,您可以联系我们找货
CONREVSMA002-L
    • 1+129.74040
    • 200+50.20920
    • 500+48.44880
    • 1000+47.57400
