CONREVSMA001-SMD-G
CONREVSMA001-SMD-G
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA001-SMD-G 数据手册
8 6 7 DESCRIPTION MATERIAL FINISH BODY PIN INSULATION GOLD GOLD N/A BRASS BeCu PTFE 5 4 2 3 1 REVISIONS REV DATE APPV 5-MAR-12 SAH C UPDATED MATERIALS 10-JUL-12 SAH D ADDED DIMPLE TO PART 3-JUN-13 SAH 3-MAY-16 SAH 29-NOV-17 CLL B D DESCRIPTION ADDED NEW TITLE BLOCK; UPDATED DIMENSIONS AND FOOTPRINT E ADDED CONTANT TO STANDOFF DIMENSION; UPDATED NOTE 3 F ADDED OUTER BARREL DIMENSION D 4X Ø 0.018 DIMPLE(S) EQUALLY SPACED 0.180 4.56 4X S 0.059 1.50 1/4-36UNS-2A THREADS 0.113 2.88 A C 0.050 1.27 0.212±0.004 5.38±0.10 0.306 7.76 0.157 4.00 0.081 2.05 C 0.153 3.88 0.157 4.00 0.039 1.00 0.310 7.87 0.409 10.40 0.096 2.44 S 0.276 7.00 0.057 1.44 RECOMMENDED FOOTPRINT B B SIDE VIEW BOTTOM VIEW NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION A DETAIL A SCALE 12 : 1 8 7 THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. 0.004 CENTER CONTACT TO MOUNTING PLANE STAND-OFF 0.000 0.10 0.00 MATERIAL: 32 FINISH: 6 5 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. 4 TITLE: A RP-SMA FEMALE PCB MOUNT SURFACE MOUNT PROJECTION: SURFACE FINISH: ANGLES: 1 TOLERANCES: .X .1 .XX .01 .XXX .005 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. REV B DRAWN: B.MURPHY DT: 11-MAR-13 CONREVSMA001-SMD-G F ENGR: S.HOGAN DT: 3-JUN-13 SCALE: 6:1 DO NOT SCALE DRAWING SHEET 1 OF 1 3 2 1 LDCFDFB_C
CONREVSMA001-SMD-G 价格&库存
很抱歉,暂时无法提供与“CONREVSMA001-SMD-G”相匹配的价格&库存,您可以联系我们找货
