REVISIONS
REV
DESCRIPTION
A INITIAL RELEASE OF LINX INTERNAL DRAWING
1/4"-36UNS-2B
THREADS
8.40
0.331
5.00
0.197
HEAT
SHRINK
CRIMP
RING
4.70
0.185
1.30
0.051
3.70
0.146
1.40
0.055
COVER INSULATOR
CLL
6.60
0.260
5.00
0.197
2.70
0.106
7.30
0.287
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN mm [INCHES].
9.50
2. DIMENSIONS APPLY AFTER FINISHING.
0.374
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE,
USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES
OF VERY HIGH CONCERN >1000ppm, AND USE DRC
EXPLODED VIEW
CONFLICT-FREE SOURCED MATERIALS.
SCALE 2 : 1
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES 0.5 MAXIMUM.
5 SEE TABLE I FOR ELECTRICAL SPECIFICATIONS. (SHEET 2)
6 SEE TABLE II FOR ENVIRONMENTAL SPECIFICATIONS. (SHEET 2)
7 SEE TABLE III FOR MECHANICAL SPECIFICATIONS. (SHEET 2)
8. SEE PARTSLIST. "*" INDICATES FINISH TYPE.
WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
159 ORT LANE
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
MERLIN, OR 97532
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
SCALE 1 : 1
01/MAR/19
9.24
0.364
7.30
0.287
7.30
0.287
3.90
0.154
APPV
HEX 8.00
0.315
16.50
0.650
20.00
0.787
DATE
TOLERANCES:
0.50 [.020]-5.00 [.200]= 0.20 [.008]
5.00 [.200]-30.00 [1.200]= 0.40 [.016]
30.0 [1.20]-120.0 [4.75]= 0.60 [0.24]
120.0 [4.75]-315.0 [12.40]= 1.0 [.040]
DRAWN: M. SCHULTE
PROJECTION:
ANGLES: 1
DT: 21/JAN/19
ENGR: D. VARATHARAJAN DT: 08/MAR/19
TITLE:
RP-SMA MALE RIGHT-ANGLE CABLE END
CRIMP FOR RG-174 CABLE
SIZE DWG. NO.
A
REV
CONREVSMA012-*
SCALE: 3:1
DO NOT SCALE DRAWING
A
SHEET 1 OF 2
LDCFDAL_C
5
TABLE I
6
TABLE II
7
TABLE III
SEE SHEET 1 FOR REVISIONS
ASSEMBLY INSTRUCTIONS
1.
Strip the cable to the recommended dimensions.
2.
Slip heat shrink and crimp ring onto stripped cable.
3.
Slide the cable into the body until the centerconductor is centered in the fork.
4.
Push the braided shield over the barrel.
5.
Solder the center-conductor into the center of the
fork.
6.
Slide the crimp ring over the shield and crimp using
a 0.128" hex crimp tool (or one labeled for use with
RG-174 cable).
7.
Trim off any excess shield wire sticking out from
the ring.
8.
Slip the heat shrink over the crimp ring until it is
against the body and shrink.
9.
Insert insulator into the body.
10. Push the cover into the opening.
2.50
0.098
3.00
0.118
5.00
0.197
RG-174
CABLE
RECOMMENDED CABLE STRIPPING DIMENSIONS
CAN ALSO BE USED WITH:
RG-188A & RG-316
SIZE DWG. NO.
A
REV
CONREVSMA012-*
SCALE: 4:1
A
SHEET 2 OF 2
LDCFDAL_A
很抱歉,暂时无法提供与“CONREVSMA012”相匹配的价格&库存,您可以联系我们找货
