CONSMA013.062
CONSMA013.062
    LINXTECHNOLOGIES(灵思)
    CONN SMA PLUG STR 50OHM EDGE MNT
CONSMA013.062 数据手册
Description Body Pin Insulation Washer Gasket Material Brass BE CU PTFE PH Bronze SI Rubber Finish Nickel Gold N/A Gold Rubber REVISIONS REV B C DESCRIPTION DATE Revised Footprint Dimension Updated footprint and dimensions; Added new title block APPV 30-Jul-09 CJ 10-JUL-12 SAH Ø0.030 [0.75] 0.040 [1.02] 1/4-36UNS-2B THREADS 0.680 [1.73] 0.250 [7.90] 0.074 [1.87] 0.039 [1.00] 0.065 [1.65] 0.500 [12.70] 0.039 [1.00] 0.250 [6.35] 0.187 [4.75] 0.687 [17.45] SIDE VIEW 0.200 [5.08] 0.060 [1.52] 0.200 [5.08] 0.060 [1.52] NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. 0.100 [2.54] 0.200 [5.08] BOTTOM BACK VIEW 0.100 [2.54] TOP : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: RECOMMENDED FOOTPRINT FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: 159 ORT LANE MERLIN, OR 97532 SMA MALE EDGE MOUNT FOR 0.062" THICK BOARD SIZE DWG. NO. DRAWN: B.MURPHY DT: 10-JUL-12 ENGR: S.HOGAN DT: 10-JUL-12 SCALE: 2:1 REV CONSMA013.062 DO NOT SCALE DRAWING C SHEET 1 OF 1 LDCFDLT_A
CONSMA013.062 价格&库存
很抱歉,暂时无法提供与“CONSMA013.062”相匹配的价格&库存,您可以联系我们找货
