REVISIONS
REV
DESCRIPTION
A INITIAL RELEASE OF LINX INTERNAL DRAWING
9.50
0.374
1/4"36-UNS-2A
THREADS
4.80
0.189
SCALE 1 : 1
10.20
0.402
NUT
01/MAR/19
CLL
0.76
0.030
6.40
0.252
7.50
0.295
1.85
0.073
1.70
0.067
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN mm [INCHES].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE,
USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES
OF VERY HIGH CONCERN >1000ppm, AND USE DRC
CONFLICT-FREE SOURCED MATERIALS.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES 0.5 MAXIMUM.
5 SEE TABLE I FOR ELECTRICAL SPECIFICATIONS. (SHEET 2)
0.50
6 SEE TABLE II FOR ENVIRONMENTAL SPECIFICATIONS. (SHEET 2)
0.020
7 SEE TABLE III FOR MECHANICAL SPECIFICATIONS. (SHEET 2)
8. SEE PARTSLIST. "*" INDICATES FINISH TYPE.
WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
159 ORT LANE
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
MERLIN, OR 97532
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
1.60
0.063
HEX 8.0
25.60
1.008
APPV
1.02
0.040
7.90
0.311
19.20
0.756
DATE
WASHER
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
TOLERANCES:
0.50 [.020]-5.00 [.200]= 0.20 [.008]
5.00 [.200]-30.00 [1.200]= 0.40 [.016]
30.0 [1.20]-120.0 [4.75]= 0.60 [0.24]
120.0 [4.75]-315.0 [12.40]= 1.0 [.040]
DRAWN: M. SCHULTE
PROJECTION:
ANGLES: 1
DT: 21/JAN/19
ENGR: D. VARATHARAJAN DT: 08/MAR/19
TITLE:
SMA FEMALE EDGE MOUNT FOR
0.062" THICK BOARD, EXTENDED
SIZE DWG. NO.
A
REV
CONSMA003.062-L-*
SCALE: 4:1
DO NOT SCALE DRAWING
A
SHEET 1 OF 2
LDCFDAL_C
5
SEE SHEET 1 FOR REVISIONS
TABLE I
1.52
0.060
6
1.57
0.062
0.062" PCB
5.08
0.200
TABLE II
8.48
0.334
4.24
0.167
BOTTOM
4.24
0.167
TOP
RECOMMENDED FOOTPRINT
7
TABLE III
6.50
0.256
RECOMMENDED MOUNTING HOLE
SIZE DWG. NO.
A
REV
CONSMA003.062-L-*
SCALE: 4:1
A
SHEET 2 OF 2
LDCFDAL_A
Solder Reflow Practices - Connectors
Application Note AN-00504
Reflow Soldering
Reflow soldering is the most common method of attaching surface mount electronic components to a
circuit board. The goal of the reflow process is to melt the solder and heat the conductive surfaces, without
overheating or damaging any electrical components. In the conventional reflow soldering process, there are
four distinct stages, or zones, having specific thermal profiles: preheat, thermal soak, reflow, and cooling. For
high-volume assembly, surface mount components are generally auto-placed by machine.
Reflow Temperature Profile
The single most critical stage in the automated assembly process is the reflow stage. The reflow profile for
any given component should be closely followed because excessive temperatures or transport times during
reflow can irreparably damage the component. Assembly personnel need to pay careful attention to the
oven’s profile to ensure that it meets the requirements necessary to successfully reflow all components while
still remaining within the limits mandated by components requiring shorter flow periods.
300
Recommended RoHS Profile
Max RoHS Profile
Recommended Non-RoHS Profile
255°C
250
235°C
217°C
Temperature (°C)
200
185°C
180°C
150
125°C
100
50
60
90
120
150
180
210
240
270
300
330
Time (Seconds)
Copyright © 2018 Linx Technologies
159 Ort Lane, Merlin, OR 97532
Phone: +1 541 471 6256
Fax: +1 541 471 6251
www.linxtechnologies.com
–1–
AN-00504 Reflow Soldering
Revised 7/16/2018
360
很抱歉,暂时无法提供与“CONSMA003.062-L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+84.99600
- 200+32.89680
- 500+31.74120
- 1000+31.16880
