MMCX Right Angle Plug for .086 (2.18) Semi-Rigid Cable
1. Identify piece parts. (2 piece parts)
2. Strip cable to dimensions shown. Do not nick center conductor.
3. Insert cable into body making certain that jacket bottoms on the connector body.
Fixture cable and assembly to prevent movement during soldering.
4. Solder center conductor to contact as shown. Use a minimum amount of solder for
a good joint.
5. Solder body to cable as shown. Use a minimum amount of heat to minimize cable
insulation movement.
6. Press end cap into body access port using .156 (3.96) diameter flat punch or
Johnson assembly tool 141-0000-910.
Cable Group
RG-405/U (.086 Semi-Rigid)
218
Part No.
135-3693-101
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“135-3693-101”相匹配的价格&库存,您可以联系我们找货
