861V509ER6
861V509ER6
    WINCHESTER(温彻斯特)
861V509ER6 数据手册
V-Bite ® PC Edge Mount The V-Bite ® is an industry award winning design PCB connector with all the advantages a designer could want. It edge mounts to the board which offers the lowest profile and utilizes very little PCB real estate. It lends itself to surface mount and through-hole soldering techniques. There are versions for IR and convection reflow soldering. Because the connector locks into place both above and below the PCB it disperses rotational torque relief to the board and not the solder points. The V-Bite ® design offers the lowest VSWR ratings due to the straight through-put contact design. No right angles for reflection. Available in 50 and 75 ohm, threaded and non-threaded. Other options for PCB thickness available. Other interfaces available. See “F”, BNC Twin, TNC and N sections. Part Number Description Imp Contact Fig. Dwg. No. 361V504ER * BNC Jack W/ Teflon For Reflow Solder 361V504ET * BNC Threaded Jack W/ Teflon For Reflow Solder 50 Phos./Gold 39 361V504EFT* BNC Threaded Jack W/ Teflon Insulator/Flange 50 Phos./Gold 39B 361V509E * BNC Jack W/ Polyethylene Insulator 50 Phos./Tin 39A 361V509ET * BNC Threaded Jack W/ Polyethylene Insulator 50 Phos./Tin 39 361V704ER * BNC Jack W/ Teflon For Reflow Solder 75 Phos./Gold 39A 361V704ET * BNC Threaded Jack W/ Teflon For Reflow Solder 75 Phos./Gold 39 361V704EFT * BNC Threaded Jack W/ Teflon Insulator/Flange 75 Phos./Gold 39B 361VH704EFT BNC Threaded Jack W/ Teflon Insulator/Flange 75 Phos./Gold 39B 361V709E * BNC Jack W/ Polyethylene Insulator 361V709ET * BNC Threaded Jack W/ Polyethylene Insulator 75 Phos./Gold 39A --75 Phos./Gold 39 --- 361E704ER * BNC W/Teflon for Reflow Solder, gold plated 75 Phos./Gold 39I 361E704EFT * BNC End launch W/Flnge and Threads, gold plated 75 Phos./Gold --- 361KNT Knurled nut (361 series) NA 3M61V704 * Mini-BNC Jack W/Teflon for Reflow 75 Phos./Gold 39J 461V504E * Twin-BNC Jack W/ Teflon For Reflow Solder 75 Phos./Gold 39N 561V504E * TNC Jack W/ Teflon For Reflow Solder 50 Phos./Gold *** 561V504EFT* TNC Jack W/ Teflon Insulator/Flange 50 Phos./Gold 39M 861V509E * F Edge Mount Jack (RG59) #NCI Phos/Gold 39C 861V509ER * F Edge Mount Jack w/ TFE Insul. for Reflow ( RG59) #NCI Brass/Gold 39C 861V509ER6 * F Jack w/ TFE Insul. for Reflow (RG6, RG59) 75 Brass/Gold 39C 861VH509ER6* F Jack w/ TFE Ins. for Reflow (RG6,59) 5GHZ 75 Brass/Gold 39C 861VUS509ER6* F Jack w/ Under Shield TFE Ins. Rflw (RG6,59) 75 Brass/Gold *** 862V509ER6 * F Edge Mount Plug w/TFE insul for reflow 75 Brass/Gold 39D 161V504E * N Edge Mount Jack w/ TFE Insul for reflow 50 Brass/Gold 39E 161V504EFT * N Edge Mount Jack w/ Flange TFE Insul for reflow 50 Brass/Gold 39F 161VUS504EFT* N Jack w/ Flge Under Shield TFE Ins. for reflow 50 Brass/Gold 39L 162V504E * N Edge Mount Plug (TFE Insul for reflow) 50 Brass/Gold 39G R061V704ER * RCA Edge Mount Jack w?TFE for reflow 75 Brass/Gold 39H * Bomar Patent only constant impedance) 50 Phos./Gold 39A RoHS compliant reflow or wave solder RoHS compliant wave solder only REQUEST DRAWING REQUEST QUOTE V-bite Footprint --- --- Patented V-Bite ®, Snaps Into PCB, Surface Mount Center Contact Fig. 39 Fig. 39A Fig. 39B Fig. 39C 39K Fig.39D Fig. 39E Fig. 39H Fig. 39I Fig. 39L Fig. 39M #NCI ( non Solder Suggestions Back to Index Fig. 39F Fig. 39J Fig. 39N Fig. 39G Fig. 39K
861V509ER6 价格&库存
很抱歉,暂时无法提供与“861V509ER6”相匹配的价格&库存,您可以联系我们找货
