142-9404-011
142-9404-011
    CINCH
    SMA
142-9404-011 数据手册
SMA Type Straight Plugs, Straight Jacks, and Straight Bulkhead Jacks for Flexible Cable – Crimp or Solder Contacts 1. Identify connector parts. (3 piece parts – except bulkhead) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. When stripping LMR-100 low loss cable, remove foil back to where cable jacket is stripped. A wire stripper of correct size is recommended for this step. Slide heat shrink (as applicable) and crimp sleeve onto jacket of cable. 3. Assemble contact onto cable as shown. Solder Attachment: Solder contact to center conductor through solder hole using .020 (0.51) diameter solder. Use a minimum amount of solder for a good joint. Crimp Attachment: Crimp contact to center conductor using Johnson Hand Tool 144-0000-910, setting #2, with positioner 141-0000-907. Crimp location should be centered between end of contact and X-hole. Crimp attachment to solid center conductor cables is not recommended. 4. Flare braid and slide body assembly over contact and under braid. Then seat body assembly firmly onto contact. The cable may have to be held in a clamping fixture. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using recommended crimp tool. Slide heat shrink forward and shrink (as applicable). 238 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17 SMA Type Straight Plugs, Straight Jacks, and Straight Bulkhead Jacks for Flexible Cable – Crimp or Solder Contacts (cont’d from last page ) Cable Group RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-179/U, 187 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-179/U, 187 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/u, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 18 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 239 Part No. “A” “B” Crimp Hex 141-0303-412 141-0304-412 141-0307-412 141-0308-412 141-0403-012 141-0404-012 141-0407-012 141-0408-012 142-0303-011/016 142-0303-411/416 142-9303-411 142-0304-011/016 142-0304-411/416 142-0307-011/016 142-0307-411/416 142-0308-011/016 142-0308-411/416 142-0333-011/016 142-0333-411/416 142-0403-011/016 142-0404-011/016 142-0407-011/016 142-0408-011/016 142-0433-011/016 142-1403-001/006 142-1404-001/006 142-1407-001/006 142-1408-001/006 142-4303-401/406 142-4304-401/406 142-4307-401/406 142-4308-401/406 142-4403-001/006 142-4404-001/006 142-4407-001/006 142-4408-001/006 142-5303-401/406 142-5304-401/406 142-5307-401/406 142-5308-401/406 142-5403-001/006 142-5404-001/006 142-5407-001/006 142-5408-001/006 142-9403-011 142-9404-011 142-9407-011 .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .270 (6.86) .295 (7.49) .105 (2.67) .128 (3.25) .151 (3.83) .128 (3.25) .105 (2.67) .128 (3.25) .151 (3.83) .213 (5.41) .215 (5.46) .215 (5.46) .278 (7.06) .278 (7.06) .128 (3.25) .128 (3.25) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .280 (7.11) .280 (7.11) .280 (7.11) .280 (7.11) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .215 (5.46) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .715 (18.16) .715 (18.16) .715 (18.16) .715 (18.16) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .278 (7.06) .151 (3.83) .151 (3.83) .213 (5.41) .213 (5.41) .213 (5.41) .213 (5.41) .128 (3.25) .128 (3.25) .128 (3.25) .151 (3.83) 213 (5.41) .213 (5.41) .128 (3.25) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) 213 (5.41) Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-9404-011
1. 物料型号:文档列出了多种型号的SMA连接器,包括不同尺寸和适用电缆类型的型号,例如RG-316/U、RG-58/U、RG-55/U等。
2. 器件简介:介绍了SMA连接器的组装方法,包括剥线、压接或焊接接触、组装接触体、压接套筒等步骤。
3. 引脚分配:文档中没有明确提到引脚分配,但提到了接触体的压接位置,应位于接触体末端和X孔之间的中心位置。
4. 参数特性:提供了连接器的物理尺寸和压接尺寸,例如压接六角头的直径、压接套筒的内径等。
5. 功能详解:详细描述了连接器的组装过程,包括剥线、压接或焊接接触体、组装接触体到电缆、压接套筒等。
6. 应用信息:文档主要关注于连接器的组装和物理特性,没有提供具体的应用场景。
7. 封装信息:提供了连接器的尺寸信息,但没有提供封装类型的详细信息。
142-9404-011 价格&库存
很抱歉,暂时无法提供与“142-9404-011”相匹配的价格&库存,您可以联系我们找货
  • 10+137.48739
  • 24+134.94104
库存:25
142-9404-011
  • 1+277.414171+36.05068
